New member... new project...need info plz
Im new on here so be gentle with me ...lol..... This is my new project its a 1968, C-50, with a 366 engine and a 4 speed tranny and a 2 speed axle.....it has a 189 in. wheelbase and had a PTO but was taken off at some point. The drive is still attached to the transmission though. Ive seen and read so many great ideas on this site...i need a right quarter panel tho .....some cancer....
Re: New member... new project...need info plz
It's a little hard to tell in the picture but the Cab Lights do look like the original type Yankee 77's that GM put on many of their trucks, unless you are talking about the "Fireman's Hat" type, which in that case you will need to change out all or part of the cab roof.
We would also need to see a picture of your sheet metal problem, but many of the pick-up truck replacement panels will work. I've seen Tilt's in pictures, but it will take a fair amount of work to accomplish it. I would have to break out my books to check on the rear Ratio, but you're right, it's probably pretty low. Welcome to the site, by the way.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
Check the glovebox option sheet, then post the RPO code.
thx for the info Bill.....Is there a code book to decipher the glove box #,s......i looked for a ratio but none there.....ill post a pic of the glove box numbers this weekend.....it has original 90 k on it....bought it for 1000 dollars....Glad to be on this site, so many sources of info and wisdom...thx
Good start on a project. Here is some good info on these trucks. This is earlier than yours but Chevy didnt change much over the years. http://chevyc60.com/
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
My 71 C50 with the 2 speed rear is 7.17/9.76:1
Here is my Glovebox decal on the 72 that I sold a few years ago. Currently working on a 67.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
the #'s off my rear axle are....... I M 1101 G running back to front along the top of the rear end .....and the big #,s under the GM stamp are 3873551.....and 2J10DG is the # on the inside of the glovebox.....Your ride is way sharp and im jealous......i would like to restore mine from the back glass forward plus change out the rear end....to achieve a comfortable 65-70 mph.....though. thx. ill post a pic of my glovebox decal as soon as my daughter can help me again...lol....not so tech savy...lol
oh yea the vin# is CE538S131131......model #CE52003
That is one cool truck.
Thanks for the kind words, that was my first C50 (72) and I rebuilt the stock brakes. It started out as a 26' box truck.
I sold it and I am working on my second C50 (67) and replaced the rear frame from a TopKick with Disk Brakes and a better ratio. This one was a grain truck. Currently looking for a P30 front disk brake axle.
and a few others
Love those super singles colgad. You gonna put some aluminum Budds up front?
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Picking up a 10 lug Kodiak front axle tomorrow so I can mount the Aluminum rims up front. Then Ill have 4 wheel disk! Dual piston calipers at each wheel.
Kodiak axle was too wide. Still looking :-(
#15 |
to wide??? just section it in the middle and weld it back together....
--------------------------------------------------------------------------- 72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138 71 Corvette Wide Body 502 Ramjet 83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R 05 MB E55 AMG, 12 45th Camaro SS stick vert |
#16 |
Looks like that's the plan. Cut out the center and move spring mount holes. I am going to run a 3/8 plate from side to side to make sure I have enough area to drill U bolt holes for the outside ones.
thanks!
#17 | |
Welcome to the forum!
#18 |
Trypod1
Cool looking truck! I too just started a project with a 72 C40 wrecker. As far as your cab lights, search the brand "Truck Lite" model 1313A. |
#19 |
Trypod. Here's the info on your axle Its a 15,000 lb 2 speed 6.50/8.58 ratio
#20 |
Front axle sectioned and installed
Alcoa's and disk brakes all around
#21 |
Looking good.
Love how you get the Small Back Glass with the Mediums (even though this one is a '67). Bill
#22 | |
Love it.
#23 |
That thing looks BadA$$ .
