Old 09-26-2014, 03:15 PM   #101
jjzepplin
jjzepplin's Avatar
Re: NP 205 Rebuild and Info
You should start your own thread about the issue and PM us the link if you want. You will get more of us looking at it and more suggestions.
We kinda hi-jacked this thread. Just sayin.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-26-2014, 05:02 PM   #102
woodsrat
Started a new one in this section and also brought the one in 1973-1987 Chevy & GMC message board back to the top from last month.
Thanks for any help and I will try to get pics this weekend.
woodsrat is offline   Reply With Quote
Old 10-25-2014, 03:52 PM   #103
engairuph
That's my next project since I also have the T221. Ready for it to byebye after I get new gears the rear and front end. Good details, right on the money
engairuph is offline   Reply With Quote
Old 11-28-2014, 01:13 AM   #104
WhiteWhale
WhiteWhale's Avatar
Are there supposed to be any o rings or seals on the speedometer output shaft and retaining nut?
My 72 case was leaking bad out of the speedo cable and when I removed the nut and shaft there were remnants of two rubber o rings. PO intall or factory? Part numbers or o ring sizes?
WhiteWhale is offline   Reply With Quote
Old 11-28-2014, 01:32 AM   #105
roxxx
YES
Mine to and no idea on part number or size
roxxx is offline   Reply With Quote
Old 09-24-2015, 06:32 PM   #106
harrisoncole4
harrisoncole4's Avatar
This was super helpful thanks!
harrisoncole4 is offline   Reply With Quote
Old 12-28-2015, 05:49 PM   #107
dennis7222
dennis7222's Avatar
This looks like an excellent guide to rebuilding your NP205. The only thing I might do differently is, wait till you get the entire thing back together, then mask off the little stuff, then paint it, thereby protecting everything including the hardware and covers.
dennis7222 is offline   Reply With Quote
Old 01-01-2016, 12:02 AM   #108
1972 Jimmy
1972 Jimmy's Avatar
Great info!! Just a couple of questions:
Are you suppose to apply rtv to any of the gaskets?
Does anyone have the correct needle bearing counts for each bearing?
1972 Jimmy is offline   Reply With Quote
Old 02-04-2017, 10:56 PM   #109
jocko
jocko's Avatar
subscribed
Old 02-05-2017, 08:04 PM   #110
roxxx
Delete if not allowed
Not sure if I can post this here but this is the place to buy master kits for the NP205
http://www.quad4x4.com/catalog/#chevy_gmc
Old 02-05-2017, 11:55 PM   #111
sweetk30
sweetk30's Avatar
sure is the place if you want to get taken for a ride . . . .
$419.xx bucks for a master gasket / bearing kit for a np205 large bearing.
and I have never been a fan of web sites making you click the link to go to another page to see the prices .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-06-2017, 10:27 AM   #112
Redcap
That place sucks.
ORD has rebuild kits for about $200.
http://offroaddesign.com/catalog/NP2...e_Rebuild_Kits
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 02-06-2017, 01:47 PM   #113
sweetk30
sweetk30's Avatar
oh ya I know ord . . . I should have stock in them .
and ever since the guy purchased the site linked above he has go crazy in prices and changing the site all around.
and ord is were I get lots of my stuff . but even some of there prices are high .
some things I get from evilbay . . .
Old 10-18-2018, 12:37 PM   #114
Jack15T
Originally Posted by jbclassix View Post
I'm posting this here in hopes that it helps out others. I am hoping this can be a resource for the mighty New Process 205. I am rebuilding a vintage 1970 NP 205 for my Suburban. I would say this is a "first gen" 205, since my 69 has the Rockwell T221. If anyone has any info to add, please go right ahead. Also if anyone sees anything I did wrong, let me know and I will correct it so I am not spreading bad info. I don't have all the spline counts for all the different 205's so someone else will have to add that.
Outstanding write up. It's greatly appreciated. Cheers, Jack
Jack15T is offline   Reply With Quote
Old 11-08-2018, 11:12 AM   #115
rowdy11
Killer write up! Thank you!!!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 05-04-2020, 07:43 PM   #116
tripton
Just curious, how many needle bearings were there on the rear of the front output shaft?
tripton is offline   Reply With Quote
Old 05-04-2020, 07:54 PM   #117
sweetk30
sweetk30's Avatar
depends on if older FULL needle bearing cup or newer style partial with cage .
if older full setup there should be no space left for another bearing needle .
Old 02-15-2021, 04:33 PM   #118
beanious
Hello all, I just wanted to get a sanity check on what I'm seeing. On the rear output shaft, the rear end where the needle bearings get installed, in I'm seeing vertical stripes. I don't know if this is wear or if they were machined in and are supposed to be there. They look really clean and almost intentional. Also, what helps to complicate things is that I apparently have a weirdo metal drive speedo unit. I removed the snap ring and washer for clarity. I can't find any clear pictures on the internet of what it's supposed to look like. Thanks for your help!
beanious is offline   Reply With Quote
Old 02-15-2021, 07:07 PM   #119
kwmech
Those lines are not supposed to be there
Old 02-15-2021, 08:42 PM   #120
rowdy11
I didn’t have any indentations when I replaced my needle bearings. I’ll try to find a picture.
Lola: My Moon Shot
Old 02-15-2021, 08:43 PM   #121
beanious
Well... I'll be dipped.
Old 02-15-2021, 08:44 PM   #122
beanious
Guess I'm in the market for a new output shaft
Old 02-16-2021, 11:27 PM   #123
sweetk30
sweetk30's Avatar
If it takes the early metal speedo gear i have a few . Send me a pm .
