09-30-2014, 04:18 PM | #1 |
Upper Radiator mount (where?)
Hello: I am looking for the bracket that holds the radiator on the top. I already have the U-shaped mounts from the bottom with the pads but I can't seem to find the one from the top ANYWHERE.
Specs: 1965 C10 with a new Champion 2row radiator. I found a picture of what it should look like (from TR65 I think). I have seen them around in this forum but I can't find where to buy them. Junk yard?
1965 C10 350 combo |
09-30-2014, 06:00 PM | #2 |
Re: Upper Radiator mount (where?)
You might need to custom fabricate your if the top of the radiator has a different thickness than the original Harrison radiator.
The original top support has 2 U shaped brackets with rubber inserts. These are spot welded to a flat plate with the proper bends. You could make one up easily enough if you have a metal brake and a welder. True, buying a salvage part would be easier. The pic below are for reference and should be correct for a 1960-1966 C10 with a short-wide V8 radiator and the last photo is for a tall-narrow L6 radiator.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 09-30-2014 at 06:06 PM. |
10-01-2014, 12:59 AM | #3 |
60-66 Nut
There are 2 different upper radiator hold downs as well as the lower saddles for the V8 radiator. There the ones for the 2 and 3 row core radiators and a wider one for the 4 row core radiator.
10-01-2014, 07:15 AM | #4 |
10-01-2014, 08:10 AM | #5 |
I have an extra top part, I also have a champion and mine fit well with some trimming of the rubber or you can use a thinner piece of rubber( this is what I did).
If you want it, Ill place a for sale in the parts section.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-01-2014, 07:57 PM | #6 | |
I have a top mount. If interested, give me a holler.
10-01-2014, 09:21 PM | #7 |
is this what your looking for? if so send me a pm
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
10-14-2014, 11:06 AM | #8 |
thanks for the input guys but I decided to go the route of sheet metal from home depot to bend it up.
10-15-2014, 10:08 PM | #9 |
08-22-2023, 03:36 PM | #10 | |
1965 Suburban Waiting on Time and Money |
08-22-2023, 11:12 PM | #11 |
They are reproduced now, but if you want an original, please post a new thread in the 60-66 parts board
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-23-2023, 02:58 PM | #12 |
Thanks! I saw some originals on eBay but didn't realize the were reproduced now. I see a big difference in price from LMC ($14.95) and CJpony parts $32.99
08-23-2023, 05:43 PM | #13 |
Happy to help! I found an original for mine before they were being reproduced, so I have no experience on if there's a difference in quality or if it's just a difference in who's reselling it
Tags |
1965, champion, mount, radiator |
