Old 10-09-2014, 01:33 PM   #1
Mitchel
Mitchel's Avatar
Post dana 60 help
i have a 1971 c20 with the eaton ho52 and 5.13ish gears and it tachs bad on the freeway, i picked up a dana 60 from a 1970 c20 big block truck for under $150 and was told its 3.54 and possible power loc i have a sm465 right now and was wondering if anyone ever swapped just the rear section of the driveshaft with the rearend so i wouldnt have to shorten it just swap rear of the carrier bearing? and also anyone have info on a saginaw 3 speed with an eletric overdrive got one for 25 bucks from a 1967 c10 and might want to use it
1971 C20 long bed 350ci sm465 ho52 5:12 daily
1966 pontiac star chief executive buildt 389 th400
"Horsepower sells cars torque wins races" Carol Shelby
Mitchel is offline   Reply With Quote
Old 10-09-2014, 07:53 PM   #2
farmall
farmall's Avatar
Re: dana 60 help
Shortening is easy and cheap. Is the 70 driveshaft available? Pop the cover on the 60 and get the ring and pinion tooth count. Powr-Loc looks like this http://www2.dana.com/pdf/5315-3.pdf
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 10-10-2014, 11:36 AM   #3
Mitchel
Mitchel's Avatar
Re: dana 60 help
The 70 driveshaft is avavble wondering if I can just swap the part that's goes from the axle to the u joint by the carrier bearing and I piped the cover it's a open diff and is there anyway to get a replacement of the stud that bolts into the diff to mount the trackbar mine is rusted really bad can post pics if it helps
Old 10-10-2014, 12:05 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: dana 60 help
You can do it as long as both drivelines have the same carrier bearing, but you will have to have the driveline balanced. However just a direct swap with nothing else, that would be a no. As far as finding a stud, you may want to post a WTB thread in the parts board. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-13-2014, 01:55 PM   #5
Mitchel
Mitchel's Avatar
Re: dana 60 help
thanks anyone know if that stud is remanufactured by anyone
dana 60, drive shaft, eaton ho52, sm465
