10-21-2014, 08:50 AM | #476 |
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
It was fun watching the Clunker get progressively faster and faster throughout the day. Here's another view of one of the 11.2 passes.
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina 1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208 1970 GTO Judge, heads/cam LS1 & stalled 4L60e |
10-21-2014, 09:37 AM | #477 |
2WD Jimmy
It looks like you were able to hook pretty well on those 20's. Were you surprised?
10-21-2014, 10:26 AM | #478 |
Boosted Member
Thanks guys.
Tom, those are 18s with MT DRs. I must have stumbled onto a great combo, because this thing seems like it will hook on ice. Zero problems, even on the street.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
10-22-2014, 05:22 PM | #479 |
The LuvShack Garage
Wowsers, just read this from start to finish, very impressive build.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-23-2014, 02:34 PM | #480 |
That's awesome
10-24-2014, 10:19 AM | #481 |
Boosted Member
10-24-2014, 10:23 AM | #482 |
Very nice. Go Pro?
10-24-2014, 10:41 AM | #483 |
Boosted Member
Yup, just an el cheapo first gen Go-pro.
10-24-2014, 10:42 AM | #484 |
Very, very nice. Love how straight it goes. Seems to hook nicely too. Dang... I want one.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
10-27-2014, 04:27 PM | #485 |
If I may, why did you choose a turbo for boost instead of a super charger? I really have no idea of the true pros and cons. I have heard that turbos are more efficient, but I doubt fuel mileage was your goal here. Just trying to learn something.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
10-27-2014, 04:40 PM | #486 | |
Boosted Member
I'm a turbo guy. Superchargers don't do a whole lot for me. They sound pretty cool though.
10-27-2014, 08:29 PM | #487 |
I can say this, I am turbocharging anything I want serious power from. I spent way too many years trying to get 18 PSI of boost to run reliably with a centrifugal, and when I did get it to stay on boost ( belt slippage or rippage ), it was way too touchy to drive on the street.
Now, I am at the extreme end of the spectrum, 489 Ci BBC, but given the choice, today I honestly believe it is easier and cheaper to run a pair of hair dryers. |
10-28-2014, 08:41 AM | #488 |
2WD Jimmy
If I had it to do over, Id go the way Wasted Income has gone. turbo LS
10-28-2014, 11:20 AM | #489 | |
Boosted Member
A turbo engine that makes 1000 hp at the crank makes 1000 hp. A blower engine that makes 1000 at the crank, might really be "making" 1200 hp, with 200 hp being consumed to turn the blower, to net that same 1000 at the crank. The bottom end of a blower engine takes more of a beating for sure.
10-28-2014, 11:48 AM | #490 |
OK, so for mild power a small blower is fine, but for big stuff go with a turbo?
10-28-2014, 03:02 PM | #491 |
Boosted Member
Not necessarily. Some guys make HUGE power with blowers.
Guys also make good streetable hp with a small reasonably sized turbo. What are your goals and what is your budget? I'm sure we can get you pointed in the right direction. Don't rule out nitrous either. I built an LQ4 Monte Carlo SS with spray that hurts a lot of feelings of big dollar cars.
10-28-2014, 03:18 PM | #492 |
I'm in the learning phase, but my company build test machines for a turbo manufacturer and I see many many different sixe turbos come thru for setup and test. Some get tossed in the steel recycling, likely they did not pass or otherwise broken. The little gerbil powering my brain had some thoughts. Between all the different parts we test, I could build a Johnny Cash car!
10-28-2014, 03:48 PM | #493 |
Turbochargers and superchargers produce power in different parts of the RPM range.
Turbochargers require the engine be passing a fair bit of air already to get spinning (AKA: turbo lag) so they make their boost more in the higher RPM ranges. Before fuel injection it used to be even worse since typical applications usually put the carb either at the beginning of a really long intake plenum or sitting on top of a thousand degree heat source. Turbo lag can be reduced with a smaller turbo that gets spinning faster (but produces less ultimate boost). There are also dual stage systems that use a smaller turbo and a larger turbo driven of a common exhaust plenum. There is also variable vane turbos that can be electronically controlled to produce varying boost. Turbos also add more heat to the intake gas mixture which is where intercoolers come in to cool this gas mixture between the heat source and the intake. Oh and then there is wastegates to bleed off over pressure. It can all get pretty complicated. Superchargers are basically just a belt driven pump, though these can come in several different configurations from the familiar Roots type you see on top fuelers (which is really a part borrowed from a 2 stroke diesel engine) to centrifugals which look like just the compressor side of a turbo with a belt where the turbine would usually be (there are also screw types and progressive vane types). The power is more linear and at modest boost levels will act, for the most part, like an engine with larger displacement and higher compression through out the RPM range. It'll consume more fuel, be more prone to pinging and pretty much have all the issues a higher compression higher displacement engine will have but without the benefit of component parts of a larger engine, add to that that the blower will also add additional stress on the rotating assembly of the engine to drive the resistance of the compressor. At higher boost levels, and at higher rpm ranges the intake pressure can start to do funky things to everything like blowing the intake valves open (when they aren't supposed to be open) or creating so much back pressure that turning the blower (especially in the case of positive displacement roots and screw type blowers) becomes very difficult. Positive displacement blowers also are designed to not allow any back flow at all or any forward flow if not driven. Unlike turbos superchargers do not typically have the equivalent of a wastegate to limit pressure so are typically driven (by varying the pulley size or actual pump size) to achieve a fixed target boost level. Both superchargers and turbochargers increase the baseline pressure of the fuel/air mixture so that the engine is compressing a pre pressurized mix. They will both increase the stress on the combustion chamber related components, both be more prone to knock and both will push components past their design limits. To say that turbos are free horsepower is not exactly true, they create a lot of exhaust back pressure, introduce all kinds of heat to the intake, basically make all the typical things you would do to a normally aspirated engine to gain a little bit of horsepower a lot worse, like adding headers to make the exhaust evacuation more efficient, or adding a cool air intake. Both have their place in both low additional horsepower and high, and both can be made to be drivable and dependable, and both can be made to disintegrate an engine. At the dependable and drivable levels turbos can be more dramatic in that you hit a certain RPM range and all a sudden it's like you kicked in an extra engine, where the supercharger being more linear doesn't have that tipping point where it's like you flipped the "more" switch. Also superchargers will consume fuel like a larger engine all the time. |
10-28-2014, 04:05 PM | #494 |
Boosted Member
You must have missed the quotation marks when I said "free".
10-28-2014, 04:18 PM | #495 |
I was referring to a statement often made, I am very well aware it wasn't free in your case.
10-30-2014, 08:52 AM | #496 |
Still Learning
I spent the last few days going through this build. Awesome job on the project! I really love the boost setup too. I have a small LS in my truck, I can only imagine the thrill you get driving with all the extra ponies.
11-12-2014, 04:02 AM | #497 | |
Active Member
11-12-2014, 11:06 AM | #498 |
Boosted Member
The rotors and calipers are from a 94-96 Impala SS. I think the B4C police stuff is the same. They use the same 5x5 pattern as the trucks and astro vans.
11-12-2014, 11:07 AM | #499 |
Boosted Member
And let me add, that these brakes work FRIGGIN AWESOME, especially with the hydroboost.
11-12-2014, 01:03 PM | #500 |
Do those rotors have the internal drum in the hub for the parking brake?
