Old 11-02-2014, 12:55 PM   #1
Roarinrat
Wiper switch help for the uk
Hi
I'm restoring the wiper mechanism on my 57 GMC truck, and I have got it all running, except the rotary wiper switch and cable is beyond repair.
I have looked at Brothers and LMC and others for replacements, but none of them seem to stock the part.
Does anyone know where I can get one from?
Steve
Roarinrat is offline   Reply With Quote
Old 11-02-2014, 01:16 PM   #2
_Ogre
_Ogre's Avatar
Re: Wiper switch help for the uk
i gave mine away on this forum a while back otherwise i could send you mine.
i still have my factory wipers on my 58, they are electric but used the same rotary switch w/ cable
when i shaved my dash i lost the spot for the rotary switch
i converted the spot next to my headlight switch to wiper switch using a stock throttle or choke cable
it attached to the wiper motor without any problem, i did cut the housing and cable to fit
this won't help if your doing a points restoration, but may get your wipers working to get an inspection
this is the spot where i made my wipers work (left of the cluster)
out this much is off, in a bit is low, in all the way is off
shop air compressor timer
Old 11-02-2014, 01:39 PM   #3
Roarinrat
Ogre
Thanks for the fast response.
I like your idea, just have to live with out is off.
Steve
