Old 11-04-2014, 05:06 PM   #1
siggyfreud
siggyfreud's Avatar
GMC 3/4 cab mounts the same as 1/2 Chevy?
Hey all,
Looking to purchase some new cab mounts for my 66 GMC 3/4 Ton. Looks at mounts readily available online, they appear to be for the 63-66 Chevy 1/2 ton, and 3/4 ton have different frame mounts thus they take different mounting hardware. However, from looking at photos my rear cab mounts appear to be the same as the 1/2 style, which made me wonder if the GMCs used the 1/2 mounts across their range.
In that photo you can see what my rear mounts look like. Would I be good to go with the standard 1/2 mount kit?
Cheers all!
siggyfreud is offline   Reply With Quote
Old 11-04-2014, 07:17 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: GMC 3/4 cab mounts the same as 1/2 Chevy?
hard to say for sure but the one 64 gmc 3/4 ton I have has the chevy 1/2 ton style mounts , not the vulcanized mounts like a 3/4 ton chev....
Old 11-04-2014, 11:31 PM   #3
sodly
sodly's Avatar
Wow... this is news to me. Can anyone else confirm non-rubber rear mounts on their GMC 3/4 tons? Sure they haven't been modified over the years? That's pretty strange, if you ask me.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 11-04-2014, 11:45 PM   #4
LT1 Burb
LT1 Burb's Avatar
Are they riveted on or bolted?
LT1 Burb is offline   Reply With Quote
Old 11-04-2014, 11:46 PM   #5
siggyfreud
siggyfreud's Avatar
I just recall the mounting brackets for te 3/4 ton looking differently in diagrams. The rears in the photo above look like 1/2 ton to me. They're riveted on, but cant be 100% it's factory. Looks factory though.
Are you saying the mounts in the photo shouldn't have come on a 3/4 ton?
I can't remember what the actual mounting material looked like unfortunately.
Old 11-05-2014, 12:44 PM   #6
60-66
60-66's Avatar
I have a GMC 1/2 ton and a GMC both 66s sitting side by side and they have the exact same mounts for the frame and cushions, same height and shape.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-05-2014, 04:39 PM   #7
jhrusk
I had a 66 Chevy 3/4 ton and the rear mounts were different than the 1/2 ton, kinda weird looking setup.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 11-05-2014, 08:19 PM   #8
LT1 Burb
LT1 Burb's Avatar
PS, I want to warn you about that fuel line you are running. I ran Russell steel braided fuel line for my LT1 and I had to take it all off after 3-4 years and throw it away. The fuel actually weeped through the lines over time and soaked the frame the whole length. I had to move the truck outside because the garage and house stunk of gas. I redid it in aluminum and had no more problem. I don't know if it was a bad run of line or if the fuel nowadays eats the rubber.
Old 11-05-2014, 08:26 PM   #9
rickywideglide
rickywideglide's Avatar
thats strange the rear mounts would be different between 3/4 ton gmcs and chevys,my 3/4 ton has sheer type with vulcanized rubber.. anyone know why,was it a comfort thing more cushioning?
rickywideglide is offline   Reply With Quote
Old 11-05-2014, 08:37 PM   #10
padresag
Originally Posted by siggyfreud View Post
Hey all,
Cheers all!
that does look like the right rear mount for the 1/2t insulators
ron
padresag is offline   Reply With Quote
Old 11-05-2014, 09:06 PM   #11
siggyfreud
siggyfreud's Avatar
Thanks for the heads up. I'll definitely keep an eye on it. They should be ethanol safe by now but I'll send a note to summit and see.
So it sounds like I should be good with 1/2 ton mounts. Thanks all!
Old 11-06-2014, 12:02 AM   #12
Bears63
...just another truck junkie..
Bears63's Avatar
RickyWideGlide, I think the comfort issue was the entire thing. The rear mounts on the 3/4 ton Chevy's do absorb more vibration and such, but I have never seen that it was enough to make a whole lot of difference. They are just plain rough trucks anyway
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 11-16-2014, 02:13 AM   #13
sdwolff98
Turning Wrenches Daily
I can confirm the 1/2 chevy mounts are the ones used on my 64 gmc 3/4 ton.
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 11-16-2014, 10:55 AM   #14
creep
Registered Loser
creep's Avatar
My 63 GMC 3/4 ton had the same rear cab mounts as the Chevy 3/4 ton mounts. They were pretty jacked so I replaced with 1/2 ton mounts.
Before...
After...
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
