Old 05-04-2012, 05:18 PM   #1
suttoncurt
suttoncurt's Avatar
pinion angle correction blocks?
This may be a stupid question but does anybody know a vendor on this forum that sells the pinion corrector blocks ? I have 5''drop springs and 3'' blocks so I know I need them . Thanks in advance for your help
suttoncurt is offline   Reply With Quote
Old 05-04-2012, 05:30 PM   #2
suttoncurt
suttoncurt's Avatar
Re: pinion angle correction blocks?
I have some driveshaft shimmy and wanting to correct it before the HRPT - Thanks
Old 05-04-2012, 05:44 PM   #3
snj8198
snj8198's Avatar
your local alignment shop or tire shop should have them. They will carry both angle shims and angled blocks to fit your needs.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 05-04-2012, 05:49 PM   #4
suttoncurt
suttoncurt's Avatar
Really ? Cool , Never thought about the local shops having them ! Thanks for the info
Old 05-04-2012, 06:28 PM   #5
cpetersen
cpetersen's Avatar
You can order them through CCP. Or you can order them directly from cv everything racing products. This is the nascars brian vickers uncle i guess. This are exactly what the nascar boys use[ATTACH]Name:  IMG-20110916-00081.jpg
Size:  31.9 KB[/ATTACH]. Click on chassis they are under lowering blocks.
cpetersen is offline   Reply With Quote
Old 05-04-2012, 06:49 PM   #6
suttoncurt
suttoncurt's Avatar
Originally Posted by cpetersen View Post
You can order them through CCP. Or you can order them directly from cv everything racing products. This is the nascars brian vickers uncle i guess. This are exactly what the nascar boys use[ATTACH]Attachment 918994[/ATTACH]. Click on chassis they are under lowering blocks.
Sweet !!! That's exactly what i'm looking for !! Thanks for the the reply with picts !!cpetersen=awesomeness
Old 11-18-2014, 11:55 PM   #7
JonnyC10
I know this is an old thread but I want to add 1" blocks in the rear to bring my rear down to level with the front. Should I get the angled blocks or am I ok with the regular one. I have 4" rear springs, shock relocators, and adjustable phb. Thanks.
JonnyC10 is offline   Reply With Quote
Old 11-19-2014, 12:19 AM   #8
geezer#99
geezer#99's Avatar
First you need to know if your pinion angle is correct. To figure that out look here.
http://www.drivetrain.com/parts_cata..._problems.html
Old 11-19-2014, 07:44 AM   #9
Fitz
Originally Posted by suttoncurt View Post
this may be a stupid question but does anybody know a vendor on this forum that sells the pinion corrector blocks ? I have 5''drop springs and 3'' blocks so i know i need them . Thanks in advance for your help
cpp
Fitz is offline   Reply With Quote
angle, pinion
