Old 11-21-2014, 09:33 PM   #1
66Submarine
66Submarine's Avatar
Re: 292 4bbl Carb
Originally Posted by geezer#99 View Post
I did!
When you're pedal to the metal it drops to near zero. When you shift it flips back to normal or higher due to the sudden closing of the throttle.
Not a ton, but it still appeared to pull a peak of slightly less than 4" at WOT just before the shift; If you put it on 1080p and make it full screen you can read the gauge fairly well (you can see it better in the second part).
My point was that although there may a little peak HP to be gained by going to a (slightly) larger carb setup, the gains wouldn't really show up unless you were winding it up pretty tight.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
292, 4bbl, fuel consumption, headers, hei
