#26 | |
![]() Join Date: Feb 2011
Re: "Almost Heaven" 67 - swb- Lilly
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
#27 |
![]() Join Date: Sep 2012
Merry Christmas to all !!! have not done much to the truck lately ...
my painter guy backed out on me , so have not had the cab painted ... I need some advice on the wiring , is the http://www.summitracing.com/parts/prf-10112 or is this one the easier one to use ? http://www.ebay.com/itm/331394910421...%3AMEBIDX%3AIT
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD 70 CHEVY C/10 LWB x 2 ----- SOLD 67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN " Build thread : http://67-72chevytrucks.com/vboard/s...15#post6826315 |
#28 |
Heres a thread that may interest you on the wiring kit, may help make a decision.
http://67-72chevytrucks.com/vboard/s....php?p=6959818
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#29 | |
from Brothers ... here are some pics of the progress so far ...New , Chrome SB Chevy 110 GPH 7.5 PSI Fuel Pump W/ Chrome Mounting Plate & Bolts 350, AGR Performance Billet Steering Boxes, Lokar KD-2400HT GM TH-400 Stainless Steel Electric Kickdown Cable Kit Brush Fini , SS tran cooler lines , fuel cell ,GM CHROME 120 AMP 1 ONE OR 3 THREE WIRE SBC BBC CHEVY ALTERNATOR ES-1001-C ,Holley 600 CFM Polished Aluminum Carburetor - Electric Choke (Part #0-80457SA, rebuilt TH 400 , 66 327 V8 , SS braided brake lines , 1967-1972 chevrolet c10 truck suburban chrome brake booster and master cylinder,Steering U-Joint / Vibration Damper, Polished Stainless, 3/4DD X 13/16-36 100% Genuine Borgeson,Borgeson Universal Steering Shaft Steel Alloy Universal Each 409418,Borgeson Univ Steering U-Joint Stainless Steel Polished 3/4" 36-Spline 3/4" DD ,SBC Small Block Chevy 305 327 350 400 BLACK Coated Block Hugger Shorty Headers,Black Cast Iron High-Flow Water Pump •1969-76 Small Block Chevy (Long Water Pump) Black Cast Iron , Accel 8021 - Accel 8.8mm Ignition Wires,fuel line Pro-Flo 350 Braided Hose•-8AN 1970 1971 1972 Chevy C/K Series Pickup Champion 3 Row Aluminum Radiator CC369
#30 |
more pics , MERRY CHRISTMAS !!!
#31 |
Still waiting on paint , so I just put another cab on so I could get
everything working ... So first thing I did wrong was blow up my tank by not venting it , busted a weld , gas sprays out ... second I cant get my steering right , it gets hung up wen u turn left or right and u have to jerk it back , t I thought bad column but I had a new rebuilt one , so I put it in , same thing , not the column ... Any Ideas ???
#32 |
There are a few different possibilities for why the steering could be hanging up.
Believe it or not the centerlink can be installed backwards and you won't realize it until later when you start having interference issues and tire scrub. The other possibility is the steering box needs adjusted, it is made so that you can adjust the tightness of the gears inside, it sounds like yours is way too tight and you need to loosen it just slightly, now keep in mind that a little goes a long ways adjust it by 1/8 of a turn at a time, here is a link to a video so you can see how to do it. https://www.youtube.com/watch?v=W5Ck4eANgII Last edited by Xeen; 06-07-2015 at 06:06 PM. |
#33 |
Thank you Brian , I 'll check that out ...
#34 |
Over a year later , still not done , gotta get new bed and paint it !!!
interior getting close ...
#35 |
Are you not going to use the bed in the photo? I'm looking for a fleet side shorty myself. If you are selling the one in the photo, send me a PM and some pics. Thanks
#36 |
sorry bed not for sale, its off another truck, just using it for mock up...
#37 |
Okay, thanks
#38 |
![]() Join Date: Apr 2005
in...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#39 |
Little more interior done ... All new glass , weather stripping , vent windows...
#40 |
![]() Join Date: Apr 2015
#41 |
Looking good, did you ever get your steering issues sorted out?
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
#42 |
yes , just went back to the original gear box and all problems solved ...
#43 |
Ah man, I have an AGR box. Hope it doesn't give me trouble. I'm liking your glove box door....
#44 |
Do you have a part number on those front rotors?
And WHERE DID YOU GET THAT GLOVE BOX DOOR??
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#45 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=600288 Have not seen many of the glove box doors , I just happened across this one on Ebay ...
#46 |
Keep moving forward. Truck looks killer
#47 |
Can not get my hood lined up everyway I move it is wrong !!!
Passenger side is up high in front and wider gap on fender , crazy ??? Will the billet hinges solve my problem ? Any advice is appreciated...
#48 |
Just found your build and subscribing. It's looking good with everything you're doing to it. As for the hood; something that long moves a long way with just a little bit of adjustment. For the side to side gap have you tried loosening one bolt (one bolt not one side) at a time on the hood to hinge bolts (not hinge to fender)? I'm sure you've done everything we're going to ask you but its hard to know since we're not there.
1970 SWB CST; 307ci, 200-4R, (Slow Motion) |
#49 |
could even be in the core support side to side if the gap at the cowl is good... ? maybe
#50 |
That probably the best gap you'll get on the passenger side
