01-14-2015, 01:31 PM | #226 | |
Re: 70 Blazer Frame Off
Starts to spin freely, then binds Good link, thanks for sharing, and your time. God knows you have your hands full
01-14-2015, 01:53 PM | #227 | |
I'm trying....
...and thanks for your kind words...I have been following and referencing your build thread since the first time I clicked on this site. It is a "Pillar" thread for the Blazer/Jimmy build forum.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-14-2015, 02:24 PM | #228 |
Also, check your threads on the spindles. One of mine was pretty chewed up but I was lucky enough to save it. I used a small file and with little fitness and patience I was able to clean it up enough for the spindle nut to go back on smoothly.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
01-14-2015, 02:53 PM | #229 | ||
Thanks for following along w/ my thread, i tend to gear it to the 16 year old who doesn t have a father to guide him, not the long time gearheads on this forum I think the stock builds are great, keeping original is often difficult. As you can see my build tends to morph Dark Olive, i have a thread file with a 16 tpi side, hoping that will work, but now i have to disassemble the hub to get at it
01-14-2015, 07:44 PM | #230 |
I'm trying....
A few more piercings and associated jewelry. Started on the tailgate trim and one of the strips came out of the box bent....at least one thing could be like, I don't know, easy?
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 01-14-2015 at 07:49 PM. |
01-15-2015, 09:33 PM | #231 |
I'm trying....
The real difference between a base K5 and a CST: 119 holes.
Console, glove box emblem, rear panel brackets and trim, door badges, belt molding, tailgate trim and molding... ....you spend all this time trying to fix holes just to turn it into Swiss cheese. Edit: That glove box door was literally the first part I bought for this truck after the truck itself. Got it from member teeitup. Perfectly straight and no holes...until today. It's also got a helluva SPID on it...will be kind of sad to take it off.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 01-15-2015 at 09:55 PM. |
01-15-2015, 09:45 PM | #232 |
I'm trying....
....Well sir I see you've selected the top of the line CST package...nice choice, nice choice...Did you know that package means 119 extra holes in your truck...What a deal!...but you know Brad, can I call you Brad?, great, what'll really set you apart from the neighbors...and isn't that what it's really all about right?, exactly...wrap your mind around this....let me cut 3 more holes in your dash and bigger ones in your firewall...I can see it now...you'll be the talk of the town...Less for more they'll say! Why it's as American as apple pie!
01-15-2015, 10:05 PM | #233 |
Carpe manana
LMAO! Looks great!
01-15-2015, 10:15 PM | #234 |
I'm trying....
Thanks Pete...the only thing better than an unstamped repop tailgate is one dressed with the heretical and dreaded BLACK TAILGATE BAND! ....which now that I type that would be a good name for an actual band.
01-16-2015, 01:52 AM | #235 |
ROTFLMAO......your not a used car salesman by any chance? Chervrolet, at one time had OK Used cars
Screenshot_2015-01-16-00-48-03
01-16-2015, 10:14 AM | #236 |
I'm not sure if you are going for a totally correct 1970 fully loaded Blazer, or just correct-looking, but those mirrors were not offered until the 71's came out.
I do like that you put the 8-350 emblem under the K/5 emblem. That's where mine is from the factory. I guess that was an early '70 thing, because I have seen other '70 Blazers with the engine size under the marker light.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-16-2015, 10:40 AM | #237 | |
I'm trying....
No...but my wife thinks this whole thing is a good idea...so....
01-16-2015, 10:52 AM | #238 |
"Period-Mod" I Love it! I hope you don't mind, but I'm going to start using that one. When you do hear it on B-J you'll be able to say that you coined the term.
01-16-2015, 11:47 AM | #239 |
I'm trying....
That's the real reason I had such a hard time constructing my SPID and why Jeff was so helpful. There are things on the truck that you just couldn't get in 1970...but I still wanted a new SPID that reflected what the truck is. Jeff was awesome helping me sort through it. A lot of thought went into that SPID and there's a lot going on in it. I'd be willing to bet some of you RPO aficionados were already way ahead of me.
01-16-2015, 09:47 PM | #240 |
I'm trying....
The hood came off of a 72 truck. The driver's door came off of a 71 truck. Both of those things required sorting.
01-16-2015, 10:04 PM | #241 |
I'm trying....
I wish I could show a beautiful new grill assembly mocked in. But the reproduction unit that I got fit so poorly we are sending it back and trying again. Trust me when I tell you it was well beyond massaging. It's funny too, because the front of the truck is all really nice unmolested OEM stuff.
01-16-2015, 10:09 PM | #242 |
I'm trying....
All holes drilled...It's finally time to start body work!
01-17-2015, 12:35 AM | #243 |
Not sure if you have the coin for it or not, but there is a NOS grille on ebay right now.
http://www.ebay.com/itm/NOS-69-70-CH...d30879&vxp=mtr
01-17-2015, 12:38 AM | #244 |
I'm loving what you're doing, taking all the cool stuff from the different years and putting them to use. Really sucks about the grille shell though, doesn't give me a warm and fuzzy knowing I'm gonna need one for my 71.
01-17-2015, 10:48 AM | #245 | |
I'm trying....
Thanks. It's a straight up 70, that was my preference when I started the search and was glad to find it...such that it was. And we've tried to stay true to it. It already had the single wall top and the front axle swap so that was a no brainer...the only real non factory "choices" I've made are mirrors, steering wheel, console, paint, and TG band...and radio....and A/C...well I guess when you list them out like that it is a lot...um...yeah...thanks. That's what I was going for the best of all years
01-17-2015, 03:51 PM | #246 |
Nice build. Stole a few pics for later reference. You don't get to see a lot of Blazers completely bedsides removed and all the frame work you did. I'll be watching.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
01-17-2015, 04:13 PM | #247 |
I'm trying....
Thanks. Wish we hadn't had to do that level of rust repair...wasn't the kind of fight I was looking for. But we played the hand we were dealt at that point. Luckily we're starting to get into the short rows.
01-17-2015, 04:27 PM | #248 |
Yeah. I half ass rebuilt mine to the piont it just looks ok. It would take a ton of coin to get it in the condition yours will be in. Money is always tight so didn't have the time or fundage to go the rought you did. Someday maybe but won't be til my kids are out of the house probably. It's looking real good though.
01-20-2015, 08:42 PM | #249 |
I'm trying....
Dust on the floor can be a beautiful thing...when it means body work has started.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 01-20-2015 at 08:48 PM. |
01-20-2015, 11:10 PM | #250 |
Just cover everything up. That dust gets everywhere. Lol
Tags |
1970, blazer, k5 blazer, restoration, silver |
