Closed Thread
Old 01-19-2015, 09:58 AM   #201
la hi
Re: What did you do with your truck today, take 2
Bit the bullet! Took off the front of the 57. It was surprisingly easy as I have not taken off the fenders before. I will repair most of my previous mistakes, custom radiator supports, including steering, changing to IFS, exhaust that falls off every week, replace the lower sheet metal that bent in an accident, and add a condenser for a/c when i put it back together.
la hi is offline
Old 01-19-2015, 01:56 PM   #202
futameca
futameca's Avatar
Got new front tires, the old ones were balding and kept losing air.
Put the side rails back on the flat bed. I sanded down and refinished them. They were grey and worn like the bed is now... gonna refinish the bed next. There was a debate with friends and family whether the side rails should stay off or on. I think I like it better with the side rails on.
'59 GMC Fleet Option
futameca is offline
Old 01-19-2015, 02:57 PM   #203
OrrieG
OrrieG's Avatar
I've had mine off and on three times in the last two weeks, make it a lot easier to do fab stuff up front.
OrrieG is offline
Old 01-19-2015, 02:59 PM   #204
OrrieG
OrrieG's Avatar
Originally Posted by OrrieG View Post
Found out my AC compressor came with an odd ball head piece that I cannot find fittings for (1" x 14). Will need to swap it out for a K type head that will take standard #8 and #18 fittings.
Parts ordered, will have it buttoned up next weekend.... moving on to finishing up the interior, upholstry for the visors, carpet layout, etc.
OrrieG is offline
Old 01-20-2015, 01:32 PM   #205
Bernman72
Did me some bed wood....
Bernman72 is offline
Old 01-20-2015, 01:52 PM   #206
yossarian19
Was actually late last night but I started planning a total re-wire of engine & body. I'd gotten the truck running but never could make it "clean"... hoping to fix that.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Old 01-21-2015, 04:21 PM   #207
thebebop
thebebop's Avatar
Got the new rear shock mounts welded in and painted. Had all the new brake lines in and ready to bleed but stripped out the proportioning valve (aluminum) on the last line going in so had to order a replacement...maybe next week.
Very close to having it back on the road!
1955 2nd Series Truck
thebebop is offline
Old 01-21-2015, 07:37 PM   #208
capnduane
capnduane's Avatar
Finally got around to fixing something that had been bugging me since I got my truck. The right front radiator support pad had no shims or cushions at all, metal to metal and about 1/4" slop. Went to my local Ace hardware and got some rubber washers and nice thick steel washers and installed them. no more clanking over the bumps!
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline
Old 01-21-2015, 07:43 PM   #209
Russell Ashley
Russell Ashley's Avatar
Finally got around to installing speakers. Just finished and haven't driven it yet to see how it sounds when it's competing with wind noise, but it sounds good sitting in the garage.
Russell Ashley is offline
Old 01-22-2015, 12:04 PM   #210
CMACDONALD1
CMACDONALD1's Avatar
I eliminated the tailgate chains. I have been thinking of this modification for a while and finally got around to it.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts.
1972 Cheyenne Short Bed
1958 Apache short fleet
1980 Chevy short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=761005
1959 "Henry"
http://67-72chevytrucks.com/vboard/s...d.php?t=670461
1966 Biscayne
http://67-72chevytrucks.com/vboard/s...d.php?t=444419
1972 Suburban
http://67-72chevytrucks.com/vboard/s...d.php?t=478828
CMACDONALD1 is offline
Old 01-22-2015, 03:53 PM   #211
57chevyman
57chevyman's Avatar
Cleaning up my tailgate
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline
Old 01-22-2015, 04:04 PM   #212
Russell Ashley
I wish you were closer, my nephew owns a media blasting business in NW Georgia, near Chattanooga, Tn. He does a lot of car parts.
Old 01-22-2015, 07:41 PM   #213
Russell Ashley
Just noticed your tail lights, they look good.
Old 01-31-2015, 08:38 PM   #214
OrrieG
OrrieG's Avatar
Finished up the AC lines, now need to sell the r12 compressor and buy the r134a model. Also picked up the vinyl for the visors.
OrrieG is offline
Old 01-31-2015, 11:21 PM   #215
iowaboynca
iowaboynca's Avatar
was able to grab a NV3500 5speed outta P'n'P. Nice score should mate up nice w/the 5.3 that i'm going to "old school", now to get all 4.8L stuff to make it simple, well simpler. I'd post a pic but i haven't cleaned it yet.
Build: "1950" GMC -Charlotte
iowaboynca is offline
Old 02-01-2015, 05:01 PM   #216
Softpatch
Softpatch's Avatar
.post a picture we do dirty
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 02-01-2015, 05:09 PM   #217
Dan in Pasadena
Dan in Pasadena's Avatar
Yeah, post it dirty then we'll be MORE impressed when you post a clean, possibly painted picture!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 02-01-2015, 11:35 PM   #218
Clarance J
Clarance J's Avatar
I decided that it was time to move the battery off the fire wall. Its new home will be down low and in front of the cab mount. Started making the new covered battery box today. It will slide forward and tip out for access. It will be finished this week sometime.
You have to have patiences or you'll be one.
Clarance J is offline
Old 02-02-2015, 01:45 AM   #219
iowaboynca
iowaboynca's Avatar
Clarence :
that sounds awesome please post pics
Old 02-02-2015, 02:07 AM   #220
Clarance J
Clarance J's Avatar
iowaboynca, pictures are on my build thread. Just another old truck. Thanks.
Old 02-02-2015, 10:38 AM   #221
Nordic
Nordic's Avatar
Building new instrument cluster. I will be using Autometer speedometer and gauges
Nordic is offline
Old 02-02-2015, 11:01 AM   #222
yossarian19
Late last night, I sectioned & re-soldered the transmission / pass. o2 sensor / crank sensor leg of my engine harness. One down, three to go.
"Over my head"
Old 02-02-2015, 01:37 PM   #223
Softpatch
Softpatch's Avatar
I liked this
http://67-72chevytrucks.com/vboard/s...=567211&page=8
I'm not to proud.....I like This because i just did this
blasted parts
Wiper motor was not working
Reason...
slider arms were rusted together
also switch not working heavy corrosion inside Hi/LOW/OFF
disassembled wiper motor/gear box and switch cleaned
reassembled broke the wiper "Park" COG.?
and broke this {repaired}
Old 02-02-2015, 05:21 PM   #224
octanejunkie
octanejunkie's Avatar
I changed power steering fluid and completely flushed out the pump and gearbox in the process.
Nothing really sexy.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline
Old 02-02-2015, 11:33 PM   #225
iowaboynca
iowaboynca's Avatar
Cleaned up tranny i yanked from junkyard on saturday (see before and after)
need to hit it one more time to make it really clean
Closed Thread
