Old 01-28-2015, 08:31 PM   #51
65sub
65sub's Avatar
Re: My suburban's Twisted Little Sister
Originally Posted by FrankyV8 View Post
Man o man this is one awsome build you got going on here! Gonna be following this! Just out of curiosity why you using a Corvette for suspension?
Thanks Franky. The corvette suspension is just for fun. For the driving I do it really has no real benefit but as I mentioned earlier, on this truck I 'm going to do everything I ever wanted to try whether it's practical or not.
Yesterdays progress was just welding some 2X4 frame curves. Today I decided my daily driver needed some work so we changed the head lights to LED then we used "GMC Sub4X4" idea for LED taillights http://67-72chevytrucks.com/vboard/s...d.php?t=623681. Makes quite a difference.
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-28-2015, 09:55 PM   #52
Free Candy Inside
Nice! Where did you get the headlights?
Free Candy Inside is offline   Reply With Quote
Old 01-29-2015, 12:06 PM   #53
TJ's Chevy
TJ's Chevy's Avatar
Frame and burb are looking good!
Old 01-29-2015, 09:46 PM   #54
65sub
65sub's Avatar
Thanks Guys
The headlights came from the local truck and tractor parts supplier. I haven't decided if I like the look of them yet. They stick out about 1/2 inch.
Dale
Old 01-31-2015, 04:13 PM   #55
65sub
65sub's Avatar
Here's Friday's work. One rear frame rail welded and ground and one just tacked together.
Dale
Old 02-02-2015, 09:42 PM   #56
65sub
65sub's Avatar
Yesterday's snow storm kinda slowed things down today but we did get one rear frame rail mocked into position.
Dale
Old 02-05-2015, 09:48 PM   #57
65sub
65sub's Avatar
We got a bunch done in last couple of days. First we welded on the other rear frame rail. Second we made some boxing plates for the rear corners. Next we put in two angle braces for the rear frame rails.
Dale
Old 02-05-2015, 09:57 PM   #58
65sub
65sub's Avatar
Then today we got some 1/4 x 3 flat bar drilled thee mounting holes. We bent the ends in the metal bender. The last picture is the bracket tacked in place
Dale
Old 02-05-2015, 10:09 PM   #59
pimpston65
pimpston65's Avatar
can i borrow your "easy" button when your done cuz you make all the hard work look easy!!!
pimpston65 is offline   Reply With Quote
Old 02-08-2015, 05:10 PM   #60
65sub
65sub's Avatar
You can borrow the button any time you need it. With your attention to detail finding nos parts you could build this if you wanted.
Friday we finished the welding and then used the cherry picker to lift the rear suspension into place
Dale
Old 02-08-2015, 06:20 PM   #61
Free Candy Inside
Looks good
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Old 02-11-2015, 09:49 PM   #62
65sub
65sub's Avatar
We made a little progress the last couple of days. First we made some brackets for the batwing crossmember and got them welded on. We aren't finished with them yet. Then we cut out one of the shockwave brackets.
Dale
Old 02-11-2015, 10:47 PM   #63
Advanced Design
Advanced Design's Avatar
Very nice brackets. Did you use a plasma cutter?
Advanced Design is offline   Reply With Quote
Old 02-12-2015, 10:31 PM   #64
65sub
65sub's Avatar
Thanks A.D. I just used a cut off wheel in a die grinder and a sanding disk.
We made a spacer for between the lower shock mount and the shockwave bracket. The we made upper and lower brackets for the shockwave
Dale
Old 02-12-2015, 11:19 PM   #65
63gmfleetside
Beautiful work, I will be following this one.
Dave
63gmfleetside is offline   Reply With Quote
Old 02-15-2015, 03:37 PM   #66
65sub
65sub's Avatar
Dave
Thanks Dave
Here's my picture for today. Hot rodding in the Great White North
Dale
Old 02-15-2015, 03:48 PM   #67
Greg63
Enjoy your truck
Greg63's Avatar
I just found your build thread. Very interesting for sure.
My in-laws owned some property in Dresden about 25 years ago and they planned to build out there. All I remember is that Dresden seemed like the middle of nowhere (no disrespect intended).
Are both your Burbs Canadian in origin?
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 02-15-2015, 03:56 PM   #68
cheessee
Awesome build so far!!
1963 GMC swb sbw 5.3/4l60e porterbuilt
From middle Tennessee
60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details..
cheessee is offline   Reply With Quote
Old 02-15-2015, 04:50 PM   #69
65sub
65sub's Avatar
Greg.
Thanks Greg. Yes Dresden is definitely a small town in the middle of a lot of farmland. Both my Suburbans started out in the US. The red and white one is from Arizona so it was relatively rust free. The green one is from a Michigan field and life there was not kind
Thanks cheesee
Dale
Old 02-16-2015, 11:25 AM   #70
CRGRS 66
CRGRS 66's Avatar
Greetings from Cambridge, I am in awe as much as I am perplexed at what you are doing. Really looking forward to seeing this one progress!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 02-17-2015, 01:06 PM   #71
Jeff La
Another job of someone knocking it out of the park, some talent being displayed here.
Jeff La is offline   Reply With Quote
Old 02-18-2015, 10:50 PM   #72
65sub
65sub's Avatar
Hey neighbour. Thanks for the compliments. The frame is almost done making the body fit the frame will start soon.
I'm not sure about knocking it out of the park but we are swing at it
We had to make a small notch for the driveshaft. Next we got the upper and lower shockwave mounts for the rear tacked in place. Then we got started making bump stop brackets.
Dale
Old 02-18-2015, 11:21 PM   #73
Advanced Design
Nice work! You move fast!
Old 02-18-2015, 11:53 PM   #74
pimpston65
pimpston65's Avatar
i need a set of replacement burban frame horns welded on, you should cross and help me out??? i'll have some timmies(tim hortons) wait'n for ya...
Old 02-19-2015, 08:54 PM   #75
65sub
65sub's Avatar
Thanks AD.
My buddy is the better welder but maybe when spring gets here we could arrange a trip. If you need a suburban frame I will have an extra one when we take the green body off.
Today we got a bit of welding done. Then finished the bumpstop brackets and tacked them in place. Also started the rear frame turn down
Dale
