#101 |
Re: Blake's 67 GMC stepside build
Time to make it look pretty...
Pic #1. The first order of business was to fill the opening for the stock blower motor. Pic #2. The two plates made to fill the next areas. Pic #3. All welded in.. Pic #4. More factory holes to be filled..
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#102 |
![]() Join Date: Jul 2012
That will make a nice difference on the firewall. The magnets look really handy. Do you remember where you got them Mark?
Thanks! Doug |
#103 |
Ace hardware..a couple bucs...
#104 |
Update....
Pic #1. Holes,Holes and more holes to be filled!!! Pic #2. After getting some welded and metal finished.. Pic #3. After doing all the work filling in the holes I didn't care for how it was coming out....So I made a flat plate to cover the entire section. I know more work but it will look much better in the end... Pic #4. Here I bolted it to the firewall and using Clecko's to hold it in place for tacking and final weld..
#105 |
The flat plate looks good!
#106 |
Yea nice job. It may be more work but It does look better.
Ryan. |
#107 |
You're making it too good
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#108 |
Looks good but where is your throttle linkage/cable and sterring column going to go?
#109 |
Thank's Guy's for the compliments..
David....The column will be in the stock location I will drill out the hole later using hole saw.. Mark..
#110 |
Pic #1. All welded in..
Pic #2. The template for passenger side.. Pic #3. Welded.. Pic #4. The template for the old blower motor location...(will be running a Southern Air unit under Dash)
#111 |
Update...
Pic #1. The template being laid out on steel panel.. Pic #2. All welded in place.. Pic #3. Here I started to weld in the O.E. spot weld to fill them up so you don't use as much filler to smooth them out.. Pic #4. More welding.. Pic #5. All ground down... Next up, The ugly junk collector aka wire trough... Mark...
#112 |
Wow, nice improvement!
#113 |
Thank's Doug....
I always felt the firewalls in these trucks were pretty damn ugly and have a ton of potential!!! Mark...
#114 |
Pic #1. This is the start of making that junk collector go away...1st I used Eastwood encapsulator inside the trough.
Pic #2. The start of getting the strips tacked in place (using 16g because i had it ) Pic #3. Here I'm showing the angle I set it at to prevent water (if any) to roll off the ledge. It is set at 10 degrees. Pic #4. Another look, with the transition tacked in place. (As i worked my way to through bend the degree started to drop to 0 ) Pic #5. One more shot...
#115 |
![]() Join Date: Jan 2015
Going to be smooth
#116 |
Thank's Justin....
#117 |
Pic #1. The small pieces going in to smooth out the transition.
Pic #2. Round 1 of many... Pic #3. Another shot of the welding process. Pic #4. The front portion all welded. Till next time... Mark...
#118 |
Lookin good, havnt checked the thread in awhile, impressive the work you've gotten done.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
#119 |
I'm not sure how I missed this build but dag gone it I'm in for the ride. Killer work dude.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#120 |
Rusty Nuts
I love watching professionals at work, nice fab work
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
#121 |
That's a pretty firewall in the making Mark!
#122 |
Nice progress. Very time consuming. But will definitely clean up the look of the firewall. Look'n forward to more.
Ryan. |
#123 |
68shotwide,Rusty76,Mr chevorlet,rockinkees,and yj4000 Thanks a bunch guys for checking out the build and the kind words!!!
#124 |
Pic #1. The front edge all ground and smoothed out.
Pic #2. Here I'm showing the process I used...After 1st round of welding I would grind down the main portion of the weld then start the next round of welds to help prevent holes in between your welds.. Pic #3. This was after all welding was done and the grinding as well. Pic #4. 2nd view up close.. Pic #5. After all metal finish was done for a better overall look.. Till next time.. Mark...
#125 |
Nice process on the back weld Mark. Looks good!
