Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-26-2015, 02:49 PM   #126
205harleyman
205harleyman's Avatar
Re: Hydroboost Mounting Plates
please send me paypal invoice for booster bracket, no clutch and hydroboost plate in satin black powdercoating to timmywester@aol.com
205harleyman
1972 K5 Blazer
2002 5.3 ltr engine and transmission
Vintage Air
1999 tan leather bucket seats and console w/1999 back seat
20inch Torque Thrust Wheels
Corvette Madrid Red with Tan Top
Hope to be driving soon!!!
205harleyman is offline   Reply With Quote
Old 03-26-2015, 11:44 PM   #127
Captainfab
60-66 Nut
PayPal invoice sent.
Old 03-27-2015, 01:54 PM   #128
205harleyman
Paid, you can just send them raw steel
205harleyman
1972 K5 Blazer
Vintage Air
Old 03-28-2015, 12:28 AM   #129
Captainfab
60-66 Nut
You asked for a powder coated booster bracket and hydroboost mounting plate, that is what I billed you for, that is what you paid for and that is what I shipped to you today. Do you not want powder coated now?
Old 03-28-2015, 08:48 AM   #130
205harleyman
that is what I wanted, just though you didn't have any ready. Thank you
205harleyman
1972 K5 Blazer
Vintage Air
Old 05-25-2015, 07:19 AM   #131
pullit
Captainfab.... Is there a reason you make the adaptor bracket that moves the assembly out from the firewall and not just a single flat plate?
pullit is offline   Reply With Quote
Old 05-25-2015, 11:54 AM   #132
Captainfab
60-66 Nut
Yes there are a couple reasons. One is so that you do not have to cut and drill your firewall to accept the hydroboost unit. The center hole would have to be enlarged a bit, plus 4 more holes drilled into the firewall. And who knows where they will come out on the inside. Secondly with the use of my booster brackets, all the factory holes are used which properly secure the vacuum booster or hydroboost and master cylinder to the pedal bracket as GM designed it to be. This ensures that when you have to stand on the brakes, you get the full function of the brakes with no deflection in the firewall.
Old 06-12-2015, 11:13 AM   #133
brownge
I'll take a mounting bracket in bare steel and a hydroboost adapter for my '72 C10 please.
Thanks,
Greg
brownge is offline   Reply With Quote
Old 06-12-2015, 10:46 PM   #134
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Thanks,
Greg
Old 07-04-2015, 07:32 AM   #135
engairuph
I would like a hydrobooster plate and booster plate adaptor for 69 K-10
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 07-04-2015, 10:51 PM   #136
Captainfab
60-66 Nut
Old 07-19-2015, 05:08 PM   #137
caddyfront
I would like a Hydro booster mounting bracket and a adapter plate for a 68 gmc c1500
caddyfront is offline   Reply With Quote
Old 07-19-2015, 11:38 PM   #138
Captainfab
60-66 Nut
I'll send you a PM with ordering info.
Old 08-24-2015, 06:09 PM   #139
bill92250
If anybody has a hydroboost nut socket they would lend, rent or sell, PM me.
bill92250 is offline   Reply With Quote
Old 08-24-2015, 11:25 PM   #140
Captainfab
60-66 Nut
I replied to your PM. I sold my last one 2 days ago. I should have some more in a couple weeks.
Old 08-31-2015, 02:07 AM   #141
Curtb1971
Curtb1971's Avatar
Hey Captian,
I'm doing an astro van hydro boost swap into my 71' chevy truck and I'm needing your mounting plate but I want to mount the plate directly to the studs coming out of the firewall. I'll have to enlarge the hole but the only issue I forsee is the factory studs are offset to the hole in the firewall. Is there anyway you could fab up one of the with the center keyed hole offset lower on the plate. I don't need the mounting holes punched and raw steel is fine.
Thanks, Curt
Curtb1971 is offline   Reply With Quote
Old 08-31-2015, 10:50 PM   #142
Captainfab
60-66 Nut
I could do that but it will take a couple weeks. It will take a few days to get it drawn up, and the laser cutting is a week out. The cost of a custom one off part will cost more than my regular production parts. None of the holes are punched, everything is CNC laser cut. So adding the holes is no more than a few mouse clicks.
Originally Posted by Curtb1971 View Post
Hey Captian,
Thanks, Curt
Old 08-31-2015, 11:24 PM   #143
Curtb1971
Curtb1971's Avatar
Awesome! I can send you a template made out of 1/16 flat and some measurements of what I'm needing if that's the easiest way of going about this. I'll pm my contact info. Thanks
Old 09-01-2015, 12:25 AM   #144
Captainfab
60-66 Nut
I know what you are wanting and I already have all the measurements I need on my work computer. It's just a matter of combining 2 drawings and having one cut.
Old 09-02-2015, 02:16 AM   #145
Curtb1971
Curtb1971's Avatar
Sounds like you already got everything set for what I'm needing. Let's go ahead and make it when you get some time. Send me your paypal info and if you need a down payment on the custom work. Thanks
Old 09-02-2015, 11:51 PM   #146
Captainfab
60-66 Nut
I made some progress on your custom hydroboost plate today. I'll try and get an order put together tomorrow. It really isn't feasible to order just one piece, so I need to see what else I can order along with your plate.
Old 09-04-2015, 10:06 PM   #147
cru_zn_29
cru_zn_29's Avatar
Captianfab I need one of your hydro boost plates like you are making for CURTB1971 ( Plain steel )
cru_zn_29 is offline   Reply With Quote
Old 09-05-2015, 12:50 AM   #148
Captainfab
60-66 Nut
I guess it's a good thing I didn't get time to plane a laser cutting order today. You do realize that this will only work with a '67-'72. I see a '64-'66 in your Avatar.
Old 09-05-2015, 08:47 AM   #149
cru_zn_29
cru_zn_29's Avatar
The 66 has a 70 power brake unit installed 20 years ago so your plate should use the same mounting.
Old 09-05-2015, 11:34 PM   #150
Captainfab
60-66 Nut
OK, just as long as you understand that it won't be bolted up correctly to your '66's firewall and pedal bracket.
