Painting My Rusted 72 Blazer......Lots of Questions
After 23 years of wheeling, camping, beach driving and just having lots of fun with our Blazer, it's time to get it painted.
I'll start with some easy questions first and move on to the harder ones if I can "reel" a few helpful peeps in ![]() - Mirrors: I want something I can tow with, but don't want the big 3 point truck mirrors, any suggestions? - Painting the grill: Is there a proper color, and can I rattle can it? - Rusty Doors and Tailgate: - I have a booth at the big automotive swap meet in this area in a couple of weeks, are my rusty doors and tailgate worth anything, or should I just part them out and scrap the rest? I have more questions and will edit this first post as needed. Thanks for any help, suggestions, and criticism ![]() Pics to follow |
Re: Painting My Rusted 72 Blazer......Lots of Questions
Getting ready to leave for some much needed body work
![]() Just some of the parts that I've collected through the years ![]() Digging into the drivers side...........ugly ![]() The ol'dood that is doing the body work............cheap, but slooow ![]() |
More ugly
![]() ![]() More to follow |
I had the late 70s-80s mirrors on my 68 k10, a little trimming around the base but they looked like they belong. You might be able to see them on my old build thread.
1968 k10 lwb-swb stepside 1936 chevy truck 1977 corvette My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176 1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824 |
![]() Join Date: May 2011
I have a windshield frame in the for sale threads if interested. Have fun with the rebuild what color do you plan on using on the grill.
http://67-72chevytrucks.com/vboard/s...d.php?t=651723 |
![]() Join Date: May 2007
On your doors, I would save the Blazer only reinforcement plate , around the door latch. I would also cut out the 72 screw hole area. And if your replacement doors are non 72, use you originals for proper door panel hole placement, before you scrap them.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#8 | ||
Thanks, but the windshield frame has already been repaired ![]() ![]() ![]() ![]() Quote:
More pics ![]() ![]() |
This is an awesome thread...I love the history that goes along with this build. I'll be keeping an eye on this one!
Your not wasting any time I thought you said the body man was slow LOL
#11 | ||
I missed this one, I want to paint it the stock gray/silver. I tried a google search but didn't find anything.
![]() I'll try and get caught up with my pics as soon as I can, it is coming along. |
I don't know about the silver but SEMS has a trim black that works will good maybe they make a silver that is close
I used satin black spray paint on my inner grill. Turned out good but I secided I liked my homemade grill better. I just cleaned it good primer and paint. I can't help you on the stock color though. That cream color I have no Clue what it's called.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
Krylon #1403 Dull Aluminum is real close to the factory color, also close to rally wheel color. You may have to have a store order it since it can be hard to find, but looks better than any other aluminum paint I have ever found in a spray can.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#15 | ||
I'll check both these out...........Thanks. |
#16 |
OK, lets get on with more pictures..............so I can ask more questions
![]() Just when I thought it was ready for paint......................... Right side rocker panel was good as I replaced it over 15 years ago, the old dood doing the work wanted to cut it out to see what was behind it, I said "no it's fine, just paint it"....................this is taking way to long. ![]() We took of the right front fender and found more ugly, so off with the rocker panel..............damn ![]() Not good, not good at all.................and yes, behind the rocker panel was rotten also ![]() Time to go find a donor cab. |
#17 |
A Little Slice of Heaven
#18 |
Donor Truck
This will work
![]() Yep, that's what I need.............don't drop it. ![]() ........and he drops it LOL ![]() It's OK though...........the part I need is just fine. |
#19 |
I took my son through that yard, pretty cool old cars, and pretty sad that they are just decaying out there.
Did you go into the upper areas of the barn? A ton of old trim for headlights, taillights and little of this and that.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 |
#20 |
Looks like lot a lot of Good old iron left there at that yard. Stock pieces can't be found around me Anymore. Ally he yards crush anything before the 80s a few years Ago. At least I got One last Look and got what I needed before The majority got Crushed. I almost cried the next time I went to the yard and the 5 trucks I had been taking from were gone.
#21 |
Re: A Little Slice of Heaven
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#22 |
Key Motors auto wrecking
29649 S Highway 213 Molalla, Oregon 97038 (503) 829-3800
#23 | ||
BTW, would like to see your Blazer in person sometime if that's cool. Quote:
#24 | |
The younger guy working there is pretty cool. He showed us the old cars they had under tarps in the barns. They had a decent looking white '70 Blazer in the breezeway when we were there, but not for sale. Thought he would trip me up with the Mercury pickup they were storing for some guy- but I had an associate at work that owned one. He was shocked I knew about them.
#25 | |
Although I've heard of this place for years, it was my first time there, from what I've heard about the old guy, the young guy is way cool. |
