Need some help 62 k10 d44
Working on a 62 K10 with D44, closed knuckle. I need two spindles, as these obviously went dry at some time and the bearings have cut into the step in the spindle. I found them at Quad 4x4, but at $400 per side, after adding bearings, seals, lube, and labor, a swap seems more logical. Anyone have spindles? If I want to swap complete axle, is there a bolt-in? Thanks for any help, I got a headache from searching the net
Re: Need some help 62 k10 d44
For cheap oem parts look on rockauto.com if they have them.A full axle swap anything 60s to 87 will bolt right in it just make sure the gear ratio matches the rear end you have now.
![]() Join Date: Aug 2008
I recommend finding a front axle from a 73+ pickup. 73-76 are dana 44 and 77-87 will be 10 bolt. Both will bolt up to your springs, have disk brakes and have larger u-joints.
however because of the front disk brakes you will now need a new master cylinder and will need to modify your hardline plumbing to separate front and rear circuits.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#4 | |
![]() Join Date: Jul 2012
You're looking for 22137x spindles on a dana 44 closed knuckle. King pin bearings are 11590/11520. Can be ordered from any auto parts store. Get your seals and king pin shims from Walcks 4wd. www.Walcks4wd.com Same stuff Quad 4x4 sells but at a much better price, and the seals are exactly the same. Hope that helps. The closed knuckle stuff is out there, you just have to look unless you desire a swap. I wanted my original, so I looked around until I dug up what I needed. Jonathon
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 04-05-2015 at 12:14 AM. Reason: general edit |
