Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 05-04-2015, 12:23 PM   #1
apocalypse
apocalypse's Avatar
1 Piece Driveshaft
Is anyone running a 1 piece driveshaft in their Sub or Panel? If so what donor vehicle did it come out of? I'm thinking of converting mine to see if it gets rid of the vibration problems I'm having.
apocalypse is offline   Reply With Quote
Old 05-04-2015, 04:47 PM   #2
pimpston65
pimpston65's Avatar
Re: 1 Piece Driveshaft
just scrap the burban and i'll give you a one piece drive shaft!!! did i mention i haul scrap!!! i have a 4x4 burban so im no help, nice rig thou!!!
pimpston65 is offline   Reply With Quote
Old 05-04-2015, 06:11 PM   #3
65chevysub
65chevysub's Avatar
I was at one time in my Suburban. Had the local muffler drive line shop make one using my original 2 piece for length but had more vibration than with the 2 PC so went back to original.
65chevysub is offline   Reply With Quote
Old 05-04-2015, 07:25 PM   #4
chevy barn
I don,t know what your using for running gear , I have a sb with a700r4 and I found a 74 Nova 4 dr . that fit perfect. It had the right size yoke and ujoints .
chevy barn is offline   Reply With Quote
Old 05-04-2015, 09:21 PM   #5
65sub
65sub's Avatar
I have a one piece driveshaft in mine. I had a local shop build it from new parts just gave them the transmission yoke.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 05-05-2015, 12:25 AM   #6
Captainfab
60-66 Nut
That chances of finding a factory driveshaft other than an original, and having it fit correctly is a gamble. On my '66 Suburban, I just took a driveshaft that was too long to a driveshaft shop and had it shortened to the correct length.
Old 05-05-2015, 08:12 AM   #7
apocalypse
apocalypse's Avatar
Thanks for all the advice guys!
If I could find a short bed Chevy truck with a 1 piece shaft, wouldn't that work? They're the same wheel base as the Sub, aren't they?
Old 05-06-2015, 12:53 AM   #8
Captainfab
60-66 Nut
Yes they are the same wheelbase. An original driveshaft will bolt in as long as your engine is in the original location and your trans is an original type trans. Otherwise the driveshaft will have to be shortened or lengthened to be the correct length to allow for enough movement without causing issues. Shortening a driveshaft is not expensive. Apparently most guys seem to think it is. It is when you need to re-tube (lengthen) the driveshaft that it becomes expensive.
Old 05-06-2015, 08:22 AM   #9
apocalypse
apocalypse's Avatar
Thanks CaptainFab.
Old 05-18-2017, 01:21 AM   #10
hop sing
hop sing's Avatar
Thanks CaptainFab.
Any body know wheel base of a short frame 63 ,carry all mine came stock w/ one piece drive shaft 2wd 3 on tree truck is a short bed truck frame same wheel base ? thx ahead of time Hop
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
Old 05-18-2017, 09:48 AM   #11
63burban
Chevy addict
Having your driveshaft shortened by a driveshaft shop that can also balance it is the key. Spend a couple bucks and have it done correctly to eliminate vibrations that cause problems with bearings and seals.
63burban is offline   Reply With Quote
Old 05-19-2017, 12:32 AM   #12
Captainfab
60-66 Nut
They are 115", the same as a short wheelbase truck.
Old 05-19-2017, 03:19 PM   #13
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
1995 Suburban, Took it to a Shop by my House in Katy, Texas and they Cut it Down and Put the 1972 c10 U-joints in for me all Under 200.00 Bucks.. My Truck is a 66 Fleetside Long Bed... Chris.... Yes they can be cut down by the Right People..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 09-08-2017, 10:31 PM   #14
hemifalcon
My '65 Suburban has a one piece shaft.. AFAIK it's original to the truck..
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
