Old 05-01-2015, 06:48 PM   #1
68 short step
my twin turbo sleeper nova
here is the build up of my 64 4 door nova, a continuation of my previous thread
http://www.stevesnovasite.com/forums...d.php?t=220060
after driving this car all summer, going to the goodguys car show in texas, driving around town,and just simply enjoying it, its time for a little winter project
here is what I have so far, some LS flanges and some pipe...the turbos are going to be 70mm units, and the end goal is going to be 1000HP..should be a fun little ride..
so here is what im starting out with...
68 short step is offline   Reply With Quote
Old 05-01-2015, 06:49 PM   #2
68 short step
Re: my twin turbo sleeper nova
so, in starting to figure out where I can mount these, while retaining the stock hood, down bars, inner fenders, and even the current exhaust I have (3" magnaflow)... once I had it somewhat positioned, I removed the driver header, and begin to build the new header, starting with the flange, and some 1.75" primary tubes.... here is the progress so far...
Old 05-01-2015, 06:51 PM   #3
68 short step
dang brake lines are in the way, but there happened to be a tube that had most all the bends in the right spot to clear them, now only 3 more tubes needed to be fabbed on the driver side... so cut, index, mark, and weld was the process...
Old 05-02-2015, 09:29 PM   #4
Advanced Design
Advanced Design's Avatar
This is cool and I am tagging along!
Advanced Design is offline   Reply With Quote
Old 05-05-2015, 12:40 PM   #5
Luther Grimace
Luther Grimace's Avatar
Right on! I love the sleeper vibe. Is it a 4 door?
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 05-06-2015, 05:55 PM   #6
68 short step
yes it is a 4 door 'ol grandma car'
Old 05-06-2015, 06:06 PM   #7
68 short step
with all the pipes, in postion, I cut the tack welds at the flange, then fully welded all the pipes, then final welded them to the flange... once they were fully welded in, I clamped them using a big hose clamp, cut the primany tubes flush with each other, welded on the collector, then cut collector to length, and then welded on my 3" v-band...
Old 05-06-2015, 06:08 PM   #8
68 short step
so, you'll notice that the turbo is more forward then where I first had it positioned, this is because there wasn't enough room to run my 3" exhaust down pipe from the turbo to the exhaust...so forward it went, it still is going to be tight, but doable...also, the fuses/relays in the engine compartment will have to be relocated, cause the turbo inlet is trying to suck them in
so ill have to move them to the inner fender area...but so far, so good, and the hood closes with no interference....
Old 05-06-2015, 06:26 PM   #9
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Diggin it, nice work so far.. Following along, thankfully the son's truck has more under hood room to play with when he gets to his
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 05-06-2015, 10:35 PM   #10
68C15
blood type; Retumbo
68C15's Avatar
it takes some real gumption to take a bite as big as that.
One thing I'm curious about though. Are the pipes close enough to the hood to hurt the paint?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-07-2015, 10:36 AM   #11
68 short step
I too thought of that, as is, they are about 1" away, so ill run it, and check the temps on the hood, and if needed ill add some heat mat to the bottom of the hood.
Old 05-07-2015, 03:09 PM   #12
Luther Grimace
Are you MIG welding all your hot and cold side piping? If so what kind of welder do you have and where are you getting your pipe from?
Old 05-07-2015, 04:03 PM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work and sweet Nova! Are the pieces that bolt the turbine housing, with the flange on it to connect to the header, cast aluminum?
Ryan
1969 Chevy milk truck
Old 05-07-2015, 05:55 PM   #14
68 short step
yes, im using a mig, its a miller DVI welder. the pipes are from summit, I got a universal header kit, and some LS flanges. the cold side, I too got them from summit, its a universal exhaust kit 2.5"
the 90* v-band to T4 transitions are 304 Stainless Steel Cast
Old 05-07-2015, 05:57 PM   #15
68 short step
pass side done. same routine as the driver side. position the turbo where it needs to go, then build the header to it... cut the pipes, clock them, mark them, then weld them...
Old 05-07-2015, 06:00 PM   #16
68 short step
few more pics...
Old 05-07-2015, 08:42 PM   #17
Dieselwrencher
Great work! I started putting twin turbos on my 40 Ford with a 354 Hemi in it. I feel your pain on the room issue. This nova will be a hand ful and a half when you're done!
Ryan
Old 05-08-2015, 09:19 PM   #18
68 short step
once headers were made, I looked into mounting my wastegates, I decided that mounting them inboard looked the best, and would keep my vacuum line routing shortest run possible, to aid in response.. I went with precisions 46mm wastegates.. here is some pics of mounting them...
Old 05-08-2015, 10:03 PM   #19
Advanced Design
Nice work!
Old 05-16-2015, 04:24 PM   #20
68 short step
once I had the wastegates mounted, my next step was to make the down pipes to connect to my existing exhaust. I made the down pipes to connect with the existing placement of the header collectors, so if I chose to, I can just put my headers back on, and not have to do anything to the exhaust.
the pass side wasn't to bad to make, as there wasn't much I had to clear. The driver side was a bit more challenging, as I had to snake around the steering shaft, and the header itself, but I got it. the down pipes are 3" mandrel exhaust. once I had the DPs made, I then mad the wastegates connection to them, and finally welded in my 02 bungs, 2 per side, 1 for my 02 sensors, and one for my wideband. here are a few build pics
Old 05-16-2015, 05:25 PM   #21
tommys72
tommys72's Avatar
Ok, I'm watching! That sir, is some fine work. Awesome
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-16-2015, 09:15 PM   #22
68 short step
thank you
Old 05-16-2015, 09:16 PM   #23
68 short step
so, with no time to spare, I tore it down, disassembled the turbos, and sent it all off to get ceramic coated.. here is some turbo tare down pics, and the pieces going out to get coated.
Old 05-17-2015, 11:04 PM   #24
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You got my Good Lord Award on this one.
Very cool.
Zoomin is offline   Reply With Quote
Old 05-18-2015, 08:58 AM   #25
Advanced Design
Really awesome work!
