Old 12-08-2014, 02:38 AM   #76
hopped up
hopped up's Avatar
Re: Project-GMC Slant Nose
Good to see ya getting back on it
hopped up is offline   Reply With Quote
Old 12-08-2014, 05:15 PM   #77
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks bro, im trying. Tired of missing events.
VDOG is offline   Reply With Quote
Old 02-13-2015, 04:35 PM   #78
VDOG
Grand PooBaa Member
VDOG's Avatar
Getting the frame, back of the cab and front of the bed ready for paint. Previously applyied POR-15 on parts of the rear frame, need something with UV portection.
Had to change the gear oil due to not knowing when it was last change.
Preventive maintance. Rear brakes are next to check.
Old 02-14-2015, 12:04 PM   #79
68Gold/white
Keep up the good work!!!
Have you done anything else to the engine??? or got it apart???
68Gold/white is offline   Reply With Quote
Old 02-16-2015, 01:45 PM   #80
VDOG
Grand PooBaa Member
VDOG's Avatar
Actually the 350 engine has been tore down to the short block and is sitting on an engine stand. Now I have two. Thinking about taking the tune port out of my green truck and installing it in this one for the time being. Trying to have it running for Del Mar GoodGuys.
Old 04-03-2015, 01:06 PM   #81
VDOG
Grand PooBaa Member
VDOG's Avatar
Had to back off the stepside to concentrate on the longbed. Since it is running I figure id finish it up. Heres where I am now along with my new cab.
Old 04-25-2015, 11:29 PM   #82
VDOG
Grand PooBaa Member
VDOG's Avatar
My replacement cab with bedliner sprayed inside and under the cab. The frontend striped down and ready for paint. The old cab and the reason for the change, rust.
Old 04-26-2015, 11:19 PM   #83
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
nice Job Vince! Keep up the good work.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 04-27-2015, 12:02 PM   #84
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks Kev. Since the wind has died down, im going to spray the frame today so I can start putting it back together. Brothers or bust. LOL
Old 04-27-2015, 12:13 PM   #85
zamboni2354
Vince,
I like your wooden stand for the cab. I've got my cab up on saw horses which works but it's a little high for working in the cab...good for the firewall and cab corners though.
keep up the good work!
Jeff in Long Beach.
zamboni2354 is offline   Reply With Quote
Old 04-27-2015, 02:09 PM   #86
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by zamboni2354 View Post
Vince,
Jeff in Long Beach.
Thanks Jeff, the stand I made from looking at others on the board and copying from them. I should have raised the bottom horizontal 2x4 higher to get my engine hoist under there so I could lift the cab. Now I have to use human lift power times 4 to get it on my frame.
Old 05-09-2015, 01:03 AM   #87
VDOG
Grand PooBaa Member
VDOG's Avatar
Front end of the frame is done. Time for assembly of suspension, cab and fenders.
Old 05-21-2015, 11:19 AM   #88
Mike Bradbury
Mike Bradbury's Avatar
Looking good Vince, you've done a lot of work in the time I have been away.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 05-25-2015, 11:34 PM   #89
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks Mike, im trying to make the Brothers Show next month. It might not be painted but it will run.
Old 05-25-2015, 11:54 PM   #90
VDOG
Grand PooBaa Member
VDOG's Avatar
Where im at now. Tomorrow I will finish the driver side then try to install the cab by Thursday.
Did not know I needed to shoot a coat of clear on CPP products so they don't rust. Duh!!!!
Old 05-26-2015, 12:18 PM   #91
zamboni2354
vince,
If you need help getting the cab on I'm available in the evenings or on the weekend.
jeff
Old 05-26-2015, 03:59 PM   #92
VDOG
Grand PooBaa Member
VDOG's Avatar
vince,
jeff
Thanks Jeff. Havent done it yet wo I will keep you in mind. I appreciate the offer.
Old 06-16-2015, 01:58 PM   #93
VDOG
Grand PooBaa Member
VDOG's Avatar
This is where im at now. Frontend is done, while I wait to prime my cab and paint my cab im going to detail my engine. 91 305 was a Tunned Port injection until I swaped a intake and carb. Going to add a cam to give it a little grunt but keep it dependable. Painted my brakelines red cause I was bored and wanted to see what they would look like.
Also want to install the Cal Custom Valve Covers but need some kind of adapter from center bolt to outside bolt.
Old 06-20-2015, 01:51 PM   #94
Mike Bradbury
Great progress Vince,
Bummed I will not see it at the Brothers show.
Old 06-23-2015, 02:45 PM   #95
VDOG
Grand PooBaa Member
VDOG's Avatar
Don't be Bummed out Mike, it wont be there.
Old 07-03-2015, 12:42 PM   #96
VDOG
Grand PooBaa Member
VDOG's Avatar
Engine finished and bout to be mounted back on the frame.
Old 10-25-2015, 03:33 AM   #97
VDOG
Grand PooBaa Member
VDOG's Avatar
Engine and cab installed
Old 01-15-2016, 04:51 AM   #98
VDOG
Grand PooBaa Member
VDOG's Avatar
New rocker work I had to do. Still learning.
Old 02-08-2016, 05:54 PM   #99
VDOG
Grand PooBaa Member
VDOG's Avatar
Welded up button holes and stake pocket holes.
Old 02-08-2016, 05:59 PM   #100
VDOG
Grand PooBaa Member
VDOG's Avatar
more pics
