06-30-2015, 04:30 PM | #176 |
Re: Parting 1986 Suburban K20 4x4
06-30-2015, 04:59 PM | #177 | |
Here are photos of the bezel. Not the greatest condition but no cracks anywhere. I have the brackets you need for $50.00 for the pair. I will need to get them removed from a truck we have here. I do not have anything loose currently. These brackets are riveted to the cross member near the frame rails correct? I believe they would be correct for an 81-87 K10 pick up or 81-91 suburban/blazer? Nothing on the seat belt cover. Let me know and I can figure out shipping for everything. Thank you, Thomas |
06-30-2015, 10:00 PM | #178 |
Thomas,
sent PM Les |
06-30-2015, 10:49 PM | #179 |
Yes
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-01-2015, 04:49 PM | #180 |
Item received. Thank you so very much!
07-05-2015, 06:12 PM | #181 |
Do you still have the axles?
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
07-06-2015, 11:21 AM | #182 |
What exactly do you need? Complete rear diff assemblies from rotor to rotor / drum to drum, or just axle shafts? What gear ratio are you looking for? I think the ones in this Suburban sold but we have others.
Let me know. Thank you, Thomas |
07-06-2015, 11:29 AM | #183 |
I need complete assembly's, I would like to have 410 ratio front and rear with a full floater for the rear. I am going to put this under a 87 1/2 ton and would like for them to be bolt in.
07-06-2015, 12:59 PM | #184 | |
I have a front (unknown mileage) for $500.00 lug nut to lug nut. Both 4:10 gears. I have quoted shipping for these before to and it was $350.00 to ship the rear to NJ. My guess is you would be looking at at least $600.00 if not more for shipping alone. Let me know. Thank you for the interest, Thomas |
07-06-2015, 01:00 PM | #185 |
Would shipping still be that high if they are strapped to the same pallet?
07-06-2015, 02:19 PM | #186 |
Pm sent
11-26-2016, 02:49 AM | #187 |
Do you still have the suburban for parts? Looking for the parts that hold down the jack in the inner fender.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-04-2017, 12:53 AM | #188 |
BMW & ASE Master Certified
Is the trans tunnel a high hump? If so how much?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
01-24-2017, 08:16 PM | #189 |
Do you have a factory K20 bottle jack that works? Could you please post a pic if you do?
01-25-2017, 10:15 AM | #190 |
Checking to see if you have two dent and rust free rear inner wheel housings,
is the grill from the red suburban pictured still available, bumper brackets for a rear sport sport bumper, core support for single headlight (same set up as pictured in the ad) and possibly an electronic speedo cluster. All this going on an 87 R10. Thanks, Mike |
03-01-2017, 11:35 AM | #191 |
Hi do you have a vent window assemble that will fit my 84 C10 Silverado? I need the passenger side. Thanks
1991 GMC K2500 4X4 350/auto 1991 Chevy S10 ext cab. 1990 Chevy S10 1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto |
03-11-2017, 10:09 AM | #192 |
Parts wanted for pickup from other trucks in your yard or other members here...
Catalytic converter heat shield and brackets, 1987 4x4 standard cab or any 1987-1991 one ton, standard cab. 87-90 454 TBI Dipstick Tube 87-91 V30/V3500 TBI Intermediate Fuel Feed Line from fuel filter to braided line. Rear DRW Hubs. 73-91 Dually Bed harness, filler panels (inner to outer skin), wiring protectors, rear red fender light. 87 GMC service manual. 87 GMC wiring diagrams. 3.73 Dana 60 Front and Dana 70 HD Rear. Tan manual window door panels (clean) (81-87 old style) Scottsdale, or better yet Silverado/Sierra Classic. Tan and red/maroon OEM floor mats. Clean LH rear brake drum backing plates for 84-87 1 ton GM, some 88-91 R/V may be the same. These have the snap in style ebrake cables. Can be from 14 bolt FF SRW, DRW or Dana 70. OEM 30/3500 Series Tailgate, Lights and Harness Camper Special stuff, Tie downs, dual battery harness and relay(73-91 old style) 85-89 factory dual exhaust, any pieces, from carbureted truck. Silverado 30 fender emblems with studs in tact (81-91 old style). Scottsdale 30 fender emblems with studs in tact (81-91 old style). Factory Under bed exhaust heat shields. Rear spring shackles from 1973 +/- (folded with two rivets). Doug Thorley Tri-Y headers for small block or big block. OEM Front bumper guard (bumperette) for 81-87, passenger side. SRW K30 OEM front hubcaps. Harness, dual tank, upper, 87-91, TBI. Rear frame rail tips from one ton pickup Factory split tailpipe, cat and brackets from 87-88 one ton VIN R OR V
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) |
04-19-2017, 01:00 PM | #193 |
Roof rack/rear air dam? thanks.
11-03-2017, 11:49 PM | #194 |
engine crossmember?
11-17-2017, 01:11 PM | #195 |
Hello are you still selling parts looking for a transmission cross-member for a 4x4 with 400
turbo and a 208 transfer case my tuck is a 1984 ? My name is Dale and i can be reached at 704-865-1616 or by email |
11-17-2017, 05:52 PM | #196 |
This dude hasn't been on the forum in over a year.
