Old 07-01-2015, 12:03 AM   #26
ho70
ho70's Avatar
Re: Spray-in Bed Liners: Your thoughts?
unless your hauling gravel, no bed liner......if you get a bed liner, have them tint it so it is the color of your truck, did it with my car for undercoating it, use raptor linerspray
ho70 is offline   Reply With Quote
Old 07-01-2015, 01:20 AM   #27
ButtersTheTruck
ButtersTheTruck's Avatar
After reading these reviews and chatting with dad at dinner tonight, I am thinking we'll skip the spray-in liner. I did find a reasonably priced little flatbed trailer I can use for hauling hay which I can get in the next few weeks, so that will save on the bed's wear
Glad to see dad pop in and offer more information on Butters!
We do intend to get the truck painted in the next several years so when that happens will will chat with the shop about a heavy-duty clearcoat for the bed.
For the meantime, does anybody have suggestions for over-the-counter products that would help protect the bed (and the rest of the truck) from the weather?
ButtersTheTruck is offline   Reply With Quote
Old 07-01-2015, 02:20 AM   #28
imjeff
imjeff's Avatar
Don't put a bed Matt in it. They trap water and grit. I have a color matched spray in liner in mine, but it's my DD and I use it as a truck. I washed the bed out today at the car wash after hauling a variety of things and it looks nearly new. It's actually at least 12 or 14 years old.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 07-01-2015, 06:25 AM   #29
GRX
GRX's Avatar
Hauling and show truck do not usually go together. Unless of course you want to show it as an actual working truck and not a piece of wheeled jewelery. Which is what I do - working truck. Went to a show once with an entire cedar tree cut & piled in the back. Long bed step side with black spray in liner on the inner side panels, bare wood on the bed. Hay and yard waste are no problem. Heavy loads like engines, rocks, and masonry are set on a sheet of plywood to protect the planks.
GRX is offline   Reply With Quote
Old 07-01-2015, 09:07 AM   #30
lowbucktruck
lowbucktruck's Avatar
Save money and trouble... just get a sheet of plywood for Butters' bed. I hauled hay for years in our ranch trucks with nothing but a sheet of plywood in the bed. Best part is, the plywood is easier to remove than that spray-in liner.
"Two rules get you through life: If it's stuck and it's not supposed to be, WD-40 it. If it's not stuck and it's supposed to be, duct tape it."
lowbucktruck is offline   Reply With Quote
Old 07-01-2015, 05:21 PM   #31
Stu Pidd
I found rubber floor tiles on Craigslist and cut them to fit. Three-foot squares, they go in and out quickly.
Stu Pidd is offline   Reply With Quote
Old 07-01-2015, 06:18 PM   #32
ButtersTheTruck
That's a neat idea. I know one of my local feed stores sells rubber matting for horse trailer's that's lightweight and comes in any size you want, so I may check out what they have so I don't always have to hook up the flatbed.
One of the reasons we're hesitant to use plywood is that it tends to not have any grip, especially when wet. My husband climbs in and out of the truck to stack hay, and since western Oregon has two seasons (4 months of 'less likely to rain' and 8 months of 'always raining'), I wanted something he wouldn't lose his footing on. Fortunately the rubber matting for horses is generally ridged in some way, so it offers grip even when wet.
BTW my dad freshened up Butters' whites this morning, thought I would share a couple pics!
Old 07-01-2015, 06:31 PM   #33
leddzepp
Moderator
leddzepp's Avatar
Just buy a rubber mat and cut it to fit. When not in use, remove it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-01-2015, 06:49 PM   #34
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Butters is coming along nicely!
I have opinion either way on a liner, probably since I have never had one.. But i really do like the bed to stay the color of the truck unless you have a wood bed.. I guess tinting could be an option..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 07-01-2015, 10:42 PM   #35
jcblue
jcblue's Avatar
I just did the floor in line-x premium so wouldn't fade.. I did it so I wouldn't scratch the floor so bad
jcblue is offline   Reply With Quote
