07-26-2015, 04:30 PM | #1 |
Fuel leak down?
I have a 454 with a Edelbrock 1405 carb and OEM fuel pump. If I let the truck sit for more than a week or so, I lose prime to the carb and have to crank the starter for several seconds before it will start. Have I got a problem or is this normal?
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
07-26-2015, 05:05 PM | #2 |
Re: Fuel leak down?
It sounds like the fuel is just evaporating from the bowl. Mine does the same thing if it sets for a couple of weeks, especially in hot weather. Running a 1 inch plastic spacer under the carburetor will help insulate it from leftover engine heat which can boil the fuel in the bowl, after you shut it down. The only other thing you can do is run an electric fuel pump to fill the bowl as soon as you turn on the key.
"Negative people always seem to have a problem for every solution" |
07-26-2015, 05:12 PM | #3 | |
Re: Fuel leak down?
07-26-2015, 05:51 PM | #4 |
Re: Fuel leak down?
It is normal.
07-26-2015, 06:52 PM | #5 |
Re: Fuel leak down?
I had a motorhome at one time that I installed a pump inline for two reasons, first was to overcome vapor lock & second was to prime the carb after a long down time. Just wire it to a toggle switch & use as needed.
Good luck Andy |
07-26-2015, 07:24 PM | #6 |
Fabricate till you "puke"
Re: Fuel leak down?
Nothing to add....damn nice pup, that you have in the avatar Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-26-2015, 08:52 PM | #7 |
Re: Fuel leak down?
Thanks Longhorn. He was 10 weeks old in that pic. He is now 9 months old and 92 lbs. He is half Czechoslovakian Shepard and half Belgian Malinois. He has a bit of an attitude!!! I also have a female American Shepard who is 10 years old and 85 lbs and a male Boxer who is 2 years old and 60 lbs.
07-28-2015, 09:02 PM | #8 | ||
"I ain't nobody, dork."
Re: Fuel leak down?
Yup... nowadays everybody is used to newfangled Fuel Injected rigs that fire right up.
Gary
