09-19-2015, 11:42 PM | #1 |
Is a radiator swap worth it?
I recently put on a serpentine belt system off a 92 chevy truck and am thinking about changing out the radiator to an aluminum one with electric fans. I need to replace the core support due to rust from under the battery box and I was thinking about changing the radiator out at the same time. I found a 3 row aluminum radiator with 2 12 in electric fans on eBay for $150. Didn't sound too high. I think it would look cleaner without the fan and shroud in there, but don't know if it would be worth the money. Any thoughts? Thanks guys.
09-20-2015, 12:48 AM | #2 |
Re: Is a radiator swap worth it?
That sounds too cheap too me. I'd be weary of the quality. I just installed an Engineered Cooling Products radiator from ebay, still a cheap most likely imported radiator and it seems to be holding up. I also copied someone else's thread here and installed a Jeep Cherokee fan inside a stock shroud. I like it a lot. Moves plenty of air and looks super clean, the fan is inside the round part of the shroud so you cant really see it. I also live a cooler climate so I am not sure how this set up works in high temperature areas.
09-20-2015, 08:44 AM | #3 |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-20-2015, 09:58 AM | #4 |
The price does make me kind of hesitant, especially since it is $800 cheaper than some of the other radiators and includes the fans. Might be worth rolling the dice, if it is crap, I still have the old one I could put back in.
