09-21-2015, 02:50 PM | #1 |
Radiator support
Anyone have a good picture or diagram of how
the radiator support grommets fit to the frame?
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
09-21-2015, 05:12 PM | #2 |
Re: Radiator support
lmc catalog has a good reference. at least i think they still do
1967custom |
09-23-2015, 12:00 PM | #3 |
Depends on the year of your truck, this is a 69-72 version.
(Don't mind the rust and cobwebs...) Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
09-23-2015, 12:39 PM | #4 |
the 67-68 is basically the same except that the rubbers are more like hockey puck shaped
1967custom |
09-23-2015, 12:56 PM | #5 |
Thanks... exactly what I needed. I saw the LMC diagram,
it has all the parts, but it doesn't show how they assemble together.
09-23-2015, 02:00 PM | #6 |
I'll add this, there's a LOT of confusion about which grommets to use when swapping things around. Well, I just mounted a 68 chevy support and 68 chevy grill on my 70 jimmy and I used the 69-72 grommets. They looked like what came off of the jimmy so it's what I ordered.
Some people will say to use the grommets that match the core support, but I feel you need to use what matches the year frame you have. At the very least, that is what worked for me. Good luck, Roger
09-23-2015, 03:29 PM | #7 |
I have this job coming up. Don't forget about the square washer that goes on top of the radiator core support. Your carriage bolt fits through it.
I think I have a pic on photobucket....I will look for it. I guess I don't have that on photobucket. This one looks better though. http://67-72chevytrucks.com/vboard/a...1&d=1198315001 Last edited by In The Ten Ring; 09-23-2015 at 03:46 PM. |
09-23-2015, 03:43 PM | #8 |
He's right, the square washer goes on top of the core support.
Here's my old bolt and washer. Rg
09-23-2015, 03:49 PM | #9 |
My square nuts were crap! Passenger side it was rust-welded to the carriage bolt head and I had to grind the bolt head down to the washer to get it off.
09-23-2015, 04:01 PM | #10 |
You got that right! They were a bear to get off, I had to hacksaw the one on the passengers side off after tearing away the old mount.
Rg
09-23-2015, 07:52 PM | #11 | |
I should dump the outer fender on that side also but the rear of it could still be a patch panel for someone. |
