Old 11-09-2015, 12:00 PM   #1
Krex
Original Dana 44 or Swap in Dana 44 w/disks
Question for everyone
I am in the process of doing a disk swap on my 1970 K20
Current axles is Dana 44 with drums BOM data is 603036-8 Standard 4.09 gears correct for year 1970 K20
Axles swap is a Dana 44 with disks BOM data is 603793-1 Standard 4.09 gears from a 1977 K20
So here is the question..... Should I swap everything from knuckles out to keep my BOM data correct for the year or should I not bother and swap the whole axles which would be easier for the rebuilt process since I am current driving my 70 k20 as a daily driver?
I know doing the complete swap will give me extra strength at the ujoints moving from 1310 to the 1350 ujoints
Krex is offline   Reply With Quote
Old 11-09-2015, 04:52 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Original Dana 44 or Swap in Dana 44 w/disks
If you don't care about the bom being right, I'd just replace what's necessary to get the 77 axle road worthy and swap the whole thing in. Much quicker and more efficient.
You can always save the original axle incase you want to sell the truck with matching boms or something like that.(doubt that would help the value much)
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 11-09-2015, 09:08 PM   #3
Mike C
Mike C's Avatar
I'd just swap.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-09-2015, 09:36 PM   #4
Krex
That is what I was going with... I just had 2nd thoughts before I started rebuilding the 77 axle.
Old 11-09-2015, 10:31 PM   #5
swamp rat
swamp rat's Avatar
If ya did just swap from knuckles out then sold the truck the next owner may run into issues figuring out what he's got, i'd swap the whole axle.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
4x4, dana 44, k20, swap
