Old 09-17-2015, 05:23 PM   #126
crossfire84
crossfire84's Avatar
Re: LIL ERV the 50
Curious why you decided to lose the Corvette seats after figuring out the arm rests, mounts etc? I DO agree the Silverado seats have a fatter, squatter look more in keeping with the rounder general shape of the AD trucks. Do you plan to design a center console afterall? Will there be an under dash valance for AC or anything?[/QUOTE]
The Corvette seats, If you look at post 108 you can see the head rest is way up in the back window. It really shows from the outside. I'm still not sure what i'll use for seats yet. Been to the junk yard a week or so ago and found some black Audi seats really sweet.
Center console. That depends on the seats, Vette seats are narrow lots of room. Silverado seats much fatter so no console.
Valance for A/C. No, I have an under dash ac unit that i'm going with.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 11-04-2015, 06:02 PM   #127
crossfire84
Re: LIL ERV the 50
Finished up the rolling chassis every thing hooked up and painted, C4 rear end fresh refill and new bushings, Drive shaft in, 6SPD in and filled, Engine ready to fire. The body and tin is in the paint shop now.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 11-04-2015, 06:09 PM   #128
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
looks good
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-04-2015, 08:17 PM   #129
oldman3
oldman3's Avatar
Re: LIL ERV the 50
Yes, that thing looks great...Jim
oldman3 is offline   Reply With Quote
Old 11-05-2015, 04:31 AM   #130
crossfire84
Re: LIL ERV the 50
thanks guys
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 11-15-2015, 12:43 AM   #131
YukonXL04
YukonXL04's Avatar
Re: LIL ERV the 50
Originally Posted by crossfire84 View Post
A arms on the truck after mod.
A before shot.
And after.
In this before and after shot. Is that at ride height? Seems high for 6" front drop. But that's about the height I would want. I saw the jack under the front so I wasn't sure.
Also what wheel and tire size and offset are you using?
I have a line on a free C10 setup but wondering how to decide how much drop I'll need.
YukonXL04 is offline   Reply With Quote
Old 11-15-2015, 09:15 AM   #132
crossfire84
Re: LIL ERV the 50
In the before shot the jack held the front up so new tires would hit fender lip.
Wheels are 17" x 7" with 4.5" back space.
The drop, I have 3" drop spindles I did remove the 3" drop coils and replaced them with 1.5" drop coils because the BBC really pushed the front down. I would have kissed every speed bump out there.
Free c10 setup. If I were to do this again I would cut the saddle in half remove the amount needed reweld it together, I seen this done before and looks like a lot less work.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 11-15-2015, 11:14 AM   #133
YukonXL04
YukonXL04's Avatar
Re: LIL ERV the 50
Awesome. Thanks for the info. If I use it I plan to shorten the saddle to fit. I'm just not sure if I can get away without cutting the A arms or not.
Old 11-27-2015, 11:10 AM   #134
CaliforniaDaddy
CaliforniaDaddy's Avatar
Re: LIL ERV the 50
man that serp setup is sweet!! I need to goto junkyard this weekend.
This is off a 95 chevy 1500 5.7L ?
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.”
CaliforniaDaddy is offline   Reply With Quote
Old 11-27-2015, 05:00 PM   #135
crossfire84
Re: LIL ERV the 50
off a 92.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 11-28-2015, 11:18 AM   #136
Baldeagle SR
Re: LIL ERV the 50
If you cut the saddle 4 in wouldn't you have to do a lot of frame work to get it to fit? Thanks Rich
Baldeagle SR is offline   Reply With Quote
Old 11-29-2015, 10:06 AM   #137
crossfire84
Re: LIL ERV the 50
From what I've seen people do is after the saddle is cut they will do 1 of 2 things, use wheels with a 2" greater offset or put on shorter a-arms.
I am not a fan of cutting the frame.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 11-29-2015, 11:54 AM   #138
YukonXL04
YukonXL04's Avatar
Re: LIL ERV the 50
It looks like the stock 85 wheels will fit with the saddle cut and shortened. The outer measurements tire to tire fit just inside the fender. With 1/2 removed should be enough clearance for the tire to tuck a little bit. I'm just not sure if I want to keep it stock or start modifying it yet.
Old 11-29-2015, 12:27 PM   #139
Baldeagle SR
Re: LIL ERV the 50
Thanks for the info. I cut the frame on my 56 GMC and added a Camaro front clip. The hardest part was getting the front clip and bumper to fir right. It does ride and drive nice.
Rich
My build http://67-72chevytrucks.com/vboard/s...d.php?t=576185
Old 01-31-2016, 12:35 AM   #140
jhnpldng
jhnpldng's Avatar
Re: LIL ERV the 50
I'm subscribing to this one. I'm dying to know how it's going to ride and handle with the shortened a-frames. Seems like it might change something. Maybe a bit choppy on the ride. Dunno.
I just bought three ADs from my neighbor and one looks to have an 80 something front saddle/suspension under it. The bodies not on it and I don't know if it ever was after the mod. I think it's something they didn't research and that stock wheels/tires would be sticking out and probably hit the front fenders on a good bump. My neighbor didn't do the work. He got them that way and all of it was probably done before internet days. Tape measures did however.
Collecting is the easy part. Get er done!
jhnpldng is offline   Reply With Quote
Old 01-31-2016, 08:59 AM   #141
crossfire84
Re: LIL ERV the 50
Up date, still in painters prison most of paint is done. My guest bed room is full of box sides and small stuff and rear fenders. My wife is ok with it so far!
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-02-2016, 05:37 PM   #142
crossfire84
Re: LIL ERV the 50
Its back home after 9 months in the paint shop. It was worth the wait. A few pics of it coming home.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-02-2016, 10:54 PM   #143
joedoh
joedoh's Avatar
Re: LIL ERV the 50
outstanding! that color reminds me of porsche riviera blue, one of my absolute favorite colors
Old 07-03-2016, 09:46 AM   #144
crossfire84
Re: LIL ERV the 50
Thanks, its 1955 TarTan turquoise.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-03-2016, 04:43 PM   #145
joedoh
joedoh's Avatar
Re: LIL ERV the 50
I thought it might be a tri five color! riviera blue is really close. I had a minitruck that we jambed out in riviera years ago, the guy who bought it primered it in riviera but never finished it any more than the jambs and bumper
Old 07-03-2016, 07:23 PM   #146
crossfire84
Re: LIL ERV the 50
Started on inside with sound barrier and wiper install.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-05-2016, 07:47 PM   #147
crossfire84
Re: LIL ERV the 50
Windshield in,seat belts in, steering column in, master cylinder and hyd clutch in.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-05-2016, 10:37 PM   #148
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
nice, coming together. congrats.
Old 07-05-2016, 11:20 PM   #149
oldman3
oldman3's Avatar
Re: LIL ERV the 50
Looking better each time...Jim
Old 07-06-2016, 05:27 AM   #150
crossfire84
Re: LIL ERV the 50
thanks
LIL ERV the 50-3600
C4 rear
Porter built a arms
