Old 10-20-2015, 07:31 PM   #51
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: New member with a 1960
I think you have the wood prep covered!!
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-21-2015, 09:02 AM   #52
Dans1960SWB
I just bought this 60.
Dans1960SWB is offline   Reply With Quote
Old 10-21-2015, 10:01 AM   #53
The1960APE
The1960APE's Avatar
I do need some advice regarding the bed, in the mid section (Tire Area) of the bed it measures about 49-1/2 wide, at the front and rear of the bed it is right at 50 which leads me to the assumption that the center needs to go outwards, is this correct? I see no way to bring the front and back inwards, I was thinking of building a jig and using a bottle jack to push the center area outwards and brace it out until the bed floor is installed. What do you guys suggest?
The1960APE is offline   Reply With Quote
Old 10-21-2015, 12:08 PM   #54
forestb
forestb's Avatar
How do the center cross sills fit? I would tell you to try to line the holes on the center cross sills up with the holes on the L shape brackets that are supposed to run along the side of the bed but it does not appear as if your truck has them. How are you going to keep your bed attached without the L shaped rails sitting on top of the wood?
forestb is offline   Reply With Quote
Old 10-21-2015, 04:22 PM   #55
The1960APE
The1960APE's Avatar
Yea....I'm going to need some help here... Can you show me a picture of what you are talking about? Obviously somewhere along the line my L brackets were discarded!
Old 10-21-2015, 04:33 PM   #56
The1960APE
The1960APE's Avatar
After looking, there are no holes in my bed for angle strips?
Old 10-21-2015, 05:12 PM   #57
TJ's Chevy
TJ's Chevy's Avatar
Truck is looking good! Nice job.
Old 10-21-2015, 05:52 PM   #58
forestb
forestb's Avatar
The angle strips are welded to the sides of the bed and lay on top of the wood. I don't have any pictures on hand but if you look at one of the threads about bed wood you will find what I am talking about. Both step sides and fleet sides have them. Have you checked to see if the top of your bed sides are straight I could not imagine those being bowed also.
Old 10-22-2015, 10:43 PM   #59
The1960APE
The1960APE's Avatar
This is before poly, the wood is flat as glass, I've got 35 hours of sanding from 80 grit to 220
These photos are after 3 applications of denatured alcohol and wood dye sanding after the first two applications and linseed oil after the third.
In 48 hours I will start the poly process!
Old 10-26-2015, 05:03 AM   #60
The1960APE
The1960APE's Avatar
These are after 3 applications of poly, light wet sanding after each, only 7 more to go! LOL
Obviously you are going to see a little trash in the finish until the final wet sand, and buff but I am really happy so far, the wood has a ton of characteristic
Old 10-26-2015, 07:41 PM   #61
61_FL_Apache
Who Me?
You're and animal on that wood!! Nice job!!
Steve
Old 10-27-2015, 07:52 AM   #62
The1960APE
The1960APE's Avatar
Thank you sir, I have done my years share of sanding...LOL I hope do be finished by the end of the weekend except for the final sanding and buffing, I want to let it cure for a couple of weeks first.
FINALLY I got the e-mail where most of my front end parts are in transit besides ball joints and steering rebuild kit (on backorder)
I ordered the LS Swap headers and motor mount/frame mount kit also. Getting ready to order truck wiring harness and engine harness.
The LS goes to the shop at the end of the week for bottom end rebuild, head work/port etc and blower install.
We are moving right along again!
Old 11-03-2015, 10:48 AM   #63
The1960APE
The1960APE's Avatar
Here are some mock up photos, remember the poly has to cure before sanding to 3000 grit and buffing so it's got some imperfections right now
Old 11-03-2015, 12:07 PM   #64
62stepside longbox
62stepside longbox's Avatar
Lightbulb Re: New member with a 1960
Nice work. That truck has some of the best patina I've ever seen
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 11-03-2015, 03:45 PM   #65
joe dirt
joe dirt's Avatar
make sure to poly all edges and underneath as well,...it will seal up the wood and help stop warpage...looks good,..that semi gloss or high gloss?
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 11-04-2015, 01:29 PM   #66
The1960APE
The1960APE's Avatar
It is all sealed, that is a high gloss, it still needs wet sanded and buffed!
Old 11-24-2015, 09:03 PM   #67
The1960APE
The1960APE's Avatar
Progress
Old 11-25-2015, 02:21 AM   #68
Captainfab
60-66 Nut
Very nice
Old 11-25-2015, 09:04 AM   #69
The1960APE
The1960APE's Avatar
Originally Posted by Captainfab View Post
Very nice
Thank you very much sir! WOW the hours involved...
Old 11-25-2015, 10:53 AM   #70
66ChevyMax
66ChevyMax's Avatar
Love the wood!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 11-30-2015, 10:02 AM   #71
The1960APE
The1960APE's Avatar
Thanks,
I think I found some ball joints...hopefully and if so we will start moving again!
Old 12-02-2015, 09:39 AM   #72
The1960APE
The1960APE's Avatar
My backordered ball joints arrived... We can get back on this junk! It should be on 4 tires by the weekend, then brake lines/booster/MC
what are some good resources for pre bent lines?
Old 12-02-2015, 10:43 AM   #73
flashed
Summit Racing would have them.
flashed is offline   Reply With Quote
Old 12-02-2015, 12:21 PM   #74
The1960APE
The1960APE's Avatar
I ended up using Inline Tube, they knew the Wilwood MC and PV I am using and sold me a direct fit kit, super knowledgeable fellow I spoke with!
Old 12-03-2015, 04:18 PM   #75
The1960APE
The1960APE's Avatar
I got my Brake Booster bracket ordered from Captainfab, pleasant fellow to deal with!
