12-03-2015, 10:25 PM | #1 |
6>8 Plugless........
What are good bang for your buck speakers these days?
I've been trying to buy some speakers for my 72 but there seem to be a lot of options these days. I don't want to get some horrid sounding ones and I don't want super expensive ones. Currently I have some new Pioneer 3 way 6x9's to go behind the seat. I also have a new classic sound center speaker. But I don't think 3 speakers will be enough. I have a 50wx4 stereo. I might add a mild sub and amp later too. Anyone have any suggestions? Thanks Ryan.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-04-2015, 07:50 PM | #2 |
Re: What are good bang for your buck speakers these days?
Volumetrically optimized enclosures are key. A low dollar driver in a proper enclosure sound better than a high dollar driver in an improper enclosure. Download the program WinISP and input the data for your driver.
12-04-2015, 10:16 PM | #3 |
Driver=Amp?
12-23-2015, 01:42 PM | #4 |
The audio driver is the components that convert the electrical signal to sound (pretty much the speaker itself). The amp just amplifies the electrical signal to the proper power rating for the speaker.
infinite-foamies is just trying to say that its the enclosure that really makes or breaks the speaker. A low quality speaker can sound great in a proper enclosure and a high quality speaker can sound awful in a bad enclosure. Obviously a high value speaker will sound best in a proper enclosure. Im assuming that the program that he linked takes the specs from the speaker and calculated the best enclosure for the application. I have had good luck with Kenwood and Pioneer speakers in my car and didnt break the bank. Spent around $100 replacing all my speakers and the sound quality is amazing compared to the OEM equipment. I currently have 2 Kenwood 6x9s in the doors of my car and Im surprised at how well they sound, highs and bass sound great. Im not even using an aftermarket headunit, just the factory headunit which outputs nowhere near the speaker power rating and still sounds awesome. Last edited by willem445; 12-23-2015 at 01:50 PM. |
12-28-2015, 09:47 PM | #5 |
For the lower cost stuff, Powerbass and Planet Audio really sound good. If you don't mind spending a little more then look into Infinity or Polk audio.
12-29-2015, 11:27 AM | #6 |
I miss this truck.
I just put a set of Polk DB651s in the rear doors of my '08 Crew cab, with a set of Alpine SPS610C in the front doors (Tweeters in the A-Pillars). Very pleased with this setup. Getting ready to start a new thread looking for budget bass setup to fill out the bottom end.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. Last edited by Tynee; 12-30-2015 at 09:10 AM. Reason: Fixing part numbers |
01-03-2016, 09:59 AM | #7 |
I'm on the outer fringe here.....lol. I actually like using custom enclosures with Caddy Bose speakers. These things are adequate sounding in Caddy's however, once you push them hard with an amp they really sound good! The 2007-up Bose Caddy's like the CTS series have some amazing sounding 6.5 and 5.25 midbass drivers. The center dash speaker is a 4" full range loudspeaker which I've ran with 75W and the a-pillar tweets I've pushed with 50W ea. I've ran a combination of these speakers (3-ohm rated each-weird In know but its Bose...) bridged in series using a big 4-channel JL Audio amp from a swapmeet and I had about $150 in components and about that much in wiring....lol-that I don't skimp on. All the speakers were junkyard sourced. BTW I also used a GM theftlock CD player....stock flat EQ curve since the amp had its own EQ adjustments. I could have gotten even pickier with a nice passive EQ setup but I wanted to keep with a small budget just for kicks.
01-14-2016, 01:15 PM | #8 |
I've always been a huge fan of Pioneer speakers and have used them in all my vehicles in the past. The only thing I don't like about them is that there isn't enough bass for me so I always end up getting an amp and subwoofer for the back. I've had really good luck with the MTX brand.
12-12-2016, 03:59 PM | #9 |
Audiopipe seems to be really good bang for the buck.
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
12-12-2016, 09:55 PM | #10 |
Chevys Kick A$$
I really like Alpine as well as Pioneer and Kenwood as well just kind of depends on personal preference is all. All of them are decent and won't break the wallet.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
12-14-2016, 12:00 AM | #11 |
When you get down to comparing brands watch out for huge peak amp numbers. Pay attention to the rms(root means square) amp number because that is real working/sounding number.
Butyl rubber surround probably flexes best and lasts a long time. Waterproof cone material is best Neodimium (rare earth) magnets are the strongest. Sony does a good job in meeting the above requirements through ebay for a reasonable cost. |
