12-23-2015, 09:03 PM | #10 |
6>8 Plugless........
Re: Swapping a 69 Chevy body onto a 97 Cummings chassis
If you're referring to the tan colored piece, that is the tappet cover. The box with the tube coming out of it is the breather. That is the only breather on the engine. There is a packing in there to help seperate oil from excess crankcase pressure as it exits the block. A road draft tube is usually attached there with a spring clamp and it is routed in between the starter and engine block stock. 3/4" hose to be exact.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
