Old 01-01-2016, 07:23 AM   #1
one3n3my
Angry Tailight issue
I replaced the old light sockets with these.
http://www.oreillyauto.com/site/c/de...l+light+socket
I soldered the wires together with the appropriate corresponding wire but the only light that is working is the brake light, no turn signal or actual lights for night driving.
Does anyone know what the issue could be and yes I have checked the fuses and those are fine.
1970 Chevy C10
one3n3my is offline   Reply With Quote
Old 01-01-2016, 07:52 AM   #2
haysonj
haysonj's Avatar
Re: Tailight issue
Did they work before you installed this? How is it grounded? That socket says its for a courtesy light. If you used one wire for the ground then only one half the bulb will work. If you have the wires right and the socket grounded to the body then you need to get a test probe and start checking wires for power back to the fuse panel.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-01-2016, 08:02 AM   #3
Grumpy old man
Grumpy old man's Avatar
Re: Tailight issue
The socket you used looks like it's made for an 1156 single filament bulb you need one for an 1157 2 filament bulb ,use the search on the top of the page and you will get all the info you need .
Old 01-01-2016, 10:56 AM   #4
one3n3my
Re: Tailight issue
It's only a 2 wire pigtail. So my question is how would I ground it to the truck? Because one wire is for the brake light and the other is a ground.
And no the lights didn't work before. I had to replace the whole wiring harness for the truck
1970 Chevy C10
Old 01-01-2016, 11:09 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tailight issue
Is one of the slots in the bulb holder deeper than the other one or are they both the same depth? That holder is for a dual element bulb otherwise there would only be one contact in the center of the base.
LockDoc
Leon
Old 01-01-2016, 11:14 AM   #6
Kennuck
Kennuck's Avatar
Re: Tailight issue
One wire is for running lights the other is for turn signal. It grounds through the housing. Make sure your housing is grounded to the box and the box is grounded to the frame.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 01-01-2016, 11:15 AM   #7
Kennuck
Kennuck's Avatar
Re: Tailight issue
Stop and turn are the same wire.
1970 Short Wide
Vintage Air
Old 01-01-2016, 11:18 AM   #8
one3n3my
Re: Tailight issue
LockDoc
They are both the same depth.
Kennuck, would I just need a ground strap to ground it? Just trying to cover all the bases to get it road worthy and then start updating everything through time.
1970 Chevy C10
Old 01-01-2016, 11:26 AM   #9
Kennuck
Kennuck's Avatar
Re: Tailight issue
If both slots are the same depth then it's not the right bulb holder. The link you posted clearly shows a two contact bulb holder which would be right for an 1157 bulb for tail lights. You may want to check that again.
If it has two contacts in the bottom with two wire out the back it should be for an 1157 and be the right one for this application.
The housing usually grounds to the box by the mounting screws holding it to the box. If there is not good contact here you can add a ground strap from the box to the tail light housing to be sure. Again make sure your box is grounded to the frame as well.
1970 Short Wide
Vintage Air
Old 01-01-2016, 11:29 AM   #10
1970 charlie
1970 charlie's Avatar
Re: Tailight issue
One wire is for stop and turn the other wire is for tail lights. And the ground is the case. Make sure you have a good ground or it will try find ground thru the other wire. The heavy fillament in the bulb is your stop and turn
1970 charlie is offline   Reply With Quote
Old 01-01-2016, 11:55 AM   #11
one3n3my
Re: Tailight issue
Thanks for the help. I have been stumped for the last few months trying to figure it our while sorting out the brakes.
1970 Chevy C10
Old 01-01-2016, 12:24 PM   #12
LockDoc
LockDoc's Avatar
Re: Tailight issue
If the slots are the same depth that is not going to work....
LockDoc
Leon
Old 01-01-2016, 12:28 PM   #13
LockDoc
LockDoc's Avatar
Re: Tailight issue
Here is the type you need....
http://www.ebay.com/itm/2x-Heavy-Dut...-/272038843584
LockDoc
Leon
Old 01-01-2016, 02:06 PM   #14
Kennuck
Kennuck's Avatar
Re: Tailight issue
Looking more closely at the link you posted, it does look like the slots are the same depth. This is not the right bulb holder. This says it is for a dome lamp which in most cases does need a ground wire because they are often mounted in a plastic case. You need the type posted by LocDoc
1970 Short Wide
Vintage Air
electrical, tail lights, wiring
