12-21-2015, 08:56 AM | #1 |
73-87 DBW pedal bracket?
What is everyone doing to mount the DBW pedal in there 73-87 trucks?
I've seen Hart Rods killer throttle brackets for the 76-72 trucks and when I contacted him, he unfortunately doesn't make them for our trucks.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
12-23-2015, 11:27 PM | #2 |
Re: 73-87 DBW pedal bracket?
Depending on what year you have, I replaced my 2011 truck pedal for a Corvette pedal and used Hart Rod's plate and it works perfect! All I had to do was swap two pins in the plug for the pedal.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
12-24-2015, 12:52 PM | #3 |
Are the mounting locations different for each pedal?
Sounds like I'll be getting a pedal from a 03-06 truck (Pedal is still being shipped with the motor so I can't be sure until I get it). would love to get one of Hart Rod's adapters if it will work. I don't mind drilling if I need to, but as far as cutting or bending the bracket, I'm worried I won't be able to get it right.
12-24-2015, 04:41 PM | #4 |
The '04 DBW truck pedal I used had 2 bolt holes that lined up with the original pedal holes. Haven't had any issues using just two bolts.
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
01-07-2016, 02:15 AM | #5 |
There's a few people using the pedal from a late 90's 6.5 diesel on their Gen III setups. You have to swap a couple of wires in the harness but the pedal itself bolts right up in the 73-87(91) trucks. Here's a pretty good write up on it:
http://api.viglink.com/api/click?for...1%2520swap.pdf |
01-07-2016, 05:28 AM | #6 |
I used a '95 6.5 diesel pedal. bolted right in. had to repin the connector on a couple of wires IIRC. Looks completely stock
01-07-2016, 11:58 AM | #7 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-10-2016, 01:25 PM | #8 |
in my build somewhere i believe i got a pic of my dbw setup, i did some cutting and welding to make mine work, turned out pretty good
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
01-10-2016, 05:18 PM | #9 | |
These peddles (DBW) do not have much movement to reach 100% throttle
01-11-2016, 12:04 AM | #10 |
This is the pedal that came with my swap, what would be needed to bolt it up to my 87 Burb? Do I need to bend the pedal bracket or mod one of Hart Rod's brackets?
Thanks again
01-12-2016, 04:34 PM | #11 |
What about GEN IV pedals that don't make use of a TAC module?
01-18-2016, 10:53 PM | #12 |
http://67-72chevytrucks.com/vboard/s...3&page=1306-07 is a plastic pedal. post 302 shows what I did. Got the idea from glock35. Used the left hand original hole in the bottom pedal hole then drilled a new hole for top pedal hole.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303 My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw |
05-20-2016, 02:40 PM | #13 |
About to buy the 98 6.5 diesel pedal, if I re-wire the connector like the above link says, this should work with a 2004 gen3 PCM and TAC module right?
05-20-2016, 03:06 PM | #14 |
What year is your truck and pedal?
06-01-2016, 10:46 AM | #15 |
Ok bought a new pedal from Rock Auto, instead of taking a chance in screwing up my existing harness, I'm going to see of I can find another pedal harness to buy and modify, just in case something gets messed up.
11-14-2017, 01:03 PM | #16 |
Bringing this post back from the dead.
I never did try to re-work my pedal/harness wiring. I was too afraid of screwing something up. Has anyone been able to use one of Hart Rod's 67-72 brackets for a 73-87 truck with a little work? I have my pedal working in my truck now, but it sits way too high up, and is un-comfortable to drive for a long time.
11-14-2017, 04:06 PM | #17 |
As I understand it some of the the 72's use the later bolt pattern of the 73-87. The rework is to just drill another hole in the bracket. I think the current ones have both hole sets.
Saskatoon, Saskatchewan Canada |
11-15-2017, 08:50 AM | #18 | |
11-16-2017, 10:34 AM | #19 | |
I am worried that welding my pedal will get the pedal too hot and mess up the electronics in the pedal. Do I not need to worry about that? If not I have a friend who can weld for me and I may end up doing what you did.
11-16-2017, 12:23 PM | #20 | |
11-16-2017, 01:01 PM | #21 |
Thank you! I just talked to my friend with the welder and we are going to do this next weekend just like you did. I will post back when I'm done.
01-01-2019, 09:22 AM | #22 |
hello to all. does anyone have the rewire instruction? i want to try this.
04-24-2019, 01:11 PM | #23 | |
The problem I keep running into, is whenever I find instructions on re-wiring the connector for the pedal, I keep finding other instructions that say to do it differently. I saw a video on youtube where someone only had to swap one wire and he claims his works with no problems. https://www.youtube.com/watch?v=WX1X...index=2&t=102s Then I find other instructions that say two wires need to be changed. (second post from the bottom) https://ls1tech.com/forums/conversio...questions.html Then I have read about doing it and swapping 3 wires. 4th post from the top https://ls1tech.com/forums/conversio...91-chevys.html I am not sure which I should trust.
06-17-2019, 09:40 AM | #24 | |
J.R. Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010 Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer |
06-27-2019, 01:40 PM | #25 |
I did. I removed the wire from pin "E" and moved it to pin "A".
I also had to cut a small notch in the connector to make it plug in. The pedal now is perfect and I have been using it for a couple months now with no issues.
