Old 01-09-2016, 04:45 PM   #26
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 64 Stepper Project
Christmas was good to me. We are still in California.
I just posted one pic even though I have two of each steps, lower cab mud guard, CaptainFabs power steering bracket etc:
Bunch of "stuff" lower A-Arm u-bolts, rear axle brake line clamps (CPP), Trailing arm bushings . . .:
Fuel Line parts:
Master brake parts, line and CaptainFabs bracket:
Old 01-09-2016, 04:48 PM   #27
The Rocknrod
Moderator
15" Steering Wheel:
Eaton 30 Spline Posi, Richmond Gear Ring & Pinion, Master install kit:
Mossier 30 Spline Axles, lugs:
Old 01-09-2016, 04:50 PM   #28
The Rocknrod
Moderator
I had a great set of hood hinges, sent them to Cadilac plating to get them Yellow/gold zinc plated, then clear-coated:
Old 01-09-2016, 05:05 PM   #29
The Rocknrod
Moderator
Almost forgot - the front of the hood has some pin holes in it after blasting and epoxy priming, so I bought the upper and lower front hood sheet-metal so that should take care of that.
Old 01-11-2016, 12:45 PM   #30
The Rocknrod
Moderator
Trying to locate the two seals that are top of the front fenders at the firewall cowl area.
Old 02-06-2016, 01:50 PM   #31
The Rocknrod
Moderator
Update - I went with a POL Trac Bar as the Early Classic would hit the frame when it was all the way lowered (just in case)
Old 03-06-2016, 12:13 PM   #32
The Rocknrod
Moderator
Got my rear disc brake kit in, came with most everything needed (one side shown).
Old 04-22-2016, 04:20 PM   #33
The Rocknrod
Moderator
Also bought an electric emergency brake set-up.
Old 06-04-2016, 09:57 AM   #34
The Rocknrod
Moderator
Still working in Cal. but found Ricks Radiator in Azuza and bought a Aluminum Desert Cooler by US Radiator - at a KILLER price.
Old 07-30-2016, 07:22 PM   #35
The Rocknrod
Moderator
"Finally" got the powdercoating work back (almost four weeks) and began assembling the goodies. Upgraded to the larger lower control arm U Bolts as well.
Old 08-18-2016, 06:20 PM   #36
The Rocknrod
Moderator
Installing the rear end, trailing arms, track bar, sway bar etc. Got the fuel and brake lines installed.
Old 08-18-2016, 07:50 PM   #37
Johns66
After you get do e with yours come back to woodway, I'll sell you some more parts to go with the hood you bought and you can help me put mine together.
Looks good.
John
Johns66 is offline   Reply With Quote
Old 08-19-2016, 08:14 AM   #38
The Rocknrod
Moderator
Looks good.
John
Hey John, I lost your number. PM me it. I DO need some parts.
You need help?
Old 08-19-2016, 08:53 AM   #39
ol_skool_chevy
ol_skool_chevy's Avatar
Very nice truck
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 08-19-2016, 09:14 AM   #40
66ChevyMax
66ChevyMax's Avatar
Wow, Gauges and Chassis looks great, glad to see the purple gone!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 08-19-2016, 12:00 PM   #41
Bomp
Bomp's Avatar
Man, you're serious on doing this truck right.
Bomp is offline   Reply With Quote
Old 08-19-2016, 12:42 PM   #42
The Rocknrod
Moderator
It's a sickness.
Old 08-26-2016, 11:19 AM   #43
The Rocknrod
Moderator
Getting Ready to send it to paint.
Old 08-27-2016, 10:24 PM   #44
thepartsguy
thepartsguy's Avatar
Very cool
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 08-27-2016, 11:19 PM   #45
66ChevyMax
66ChevyMax's Avatar
Gonna be a sweet ride!
Craig
Old 09-20-2016, 09:33 AM   #46
The Rocknrod
Moderator
At the paint shop now.
Old 09-25-2016, 04:30 AM   #47
phraza
phraza's Avatar
Epic build!
Looking forward to seeing the color
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline   Reply With Quote
Old 09-25-2016, 08:24 AM   #48
Very Nice. Where did you find the steering wheel?
Old 09-25-2016, 08:40 AM   #49
The Rocknrod
Moderator
They're called American Retro steering wheels. Got this one from Speedway.
Old 09-25-2016, 01:33 PM   #50
Thank you. That is really good looking
