01-20-2016, 10:27 PM | #11 |
Member of the longbed union.
Re: 75 Dually build
Also check the light sockets for ground. They are known to go bad. Anyway to unplug the harness from the steering column and add 12v straight to each wire. That should let you know if it's either broken wire in column or turn signal switch.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Tags |
air bags, alcoas, chevy, dually, lowered |
