Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 01-20-2016, 06:32 PM   #1
calvin78612
calvin78612's Avatar
Bird Poop
After cleaning it off it has left a stain of sorts. I have tried an over the counter bug and tar remover with no luck. Any suggestions ?
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 01-20-2016, 09:59 PM   #2
franken
Re: Bird Poop
Sorry, rumor has it that stuff is toxic to the finish. Kill the critters and buff off the damage.
Old 01-21-2016, 02:16 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Bird Poop
Bird poop etches the paint and will leave an outline in the paint. It will take a polishing compound and a buffer to clean most of it off the paint.
Frank
Old 01-21-2016, 06:18 PM   #4
cdowns
cdowns's Avatar
Re: Bird Poop
if you use windex on freshly pooped on paint you'll get good cleanup results the main thing is to keep it handy cause letting it sit for days till you try cleaning is futile
Old 01-21-2016, 08:02 PM   #5
piecesparts
Re: Bird Poop
I keep a spray bottle of detail spray in my vehicles. It is better for the paint, than windex and it removes bugs and poop. However,if you have poop that has set out in the sun and you did not get it removed early, you will have an etching problem. I would also discuss the use of a good paint sealant/wax at this time. That will help you more than anything.
Frank
Old 01-21-2016, 09:23 PM   #6
calvin78612
Re: Bird Poop
Thanks for the replies ! I will try a polishing/ compound ( any recommendations ). Tried the detail spray first, then the over the counter spray w/ no help. Looks like it is time for a truck cover for the interim until I can build a carport.
84 step side
87 swb
Old 01-25-2016, 12:38 PM   #7
piecesparts
Re: Bird Poop
I use 3M Finnesse-It to polish paint, however that is coming to an end of production life and others are out there that do the same. Check with your local paint suppliers or a body shop to see what they are now using and what it is priced at.
I have a supplier that goes to all of the swap meets in our area and he sells stock at a lower cost than over the counter sales usually do.
Frank
Old 01-27-2016, 12:00 AM   #8
calvin78612
Re: Bird Poop
I used maguires polishing compound with pretty good results. It is a black paint job so as you polish it seems to somewhat disappear as you look at different angles. All in all I can live with the results, and thanks to everyone's responses', any more feel free to chime in.
84 step side
87 swb
Old 02-12-2016, 03:22 AM   #9
OhioChevy
Re: Bird Poop
I have used clay bar and spray with good results on bird poop after cleaning the poop off with a cleaner. Just be sure to NOT drop the clay because it will pick up any dirt if it hits the floor. If you drop the clay bar throw it into the waste basket. After claying you will need to polish the car/truck again with good polish because the claying will remove all polish that was there before.
Ray
OhioChevy is offline   Reply With Quote
Old 02-12-2016, 08:46 AM   #10
calvin78612
Re: Bird Poop
You know, I looked at the clay bars but wasn't sure. I have a couple more spots so I may just try the clay. Thanks Ray.
84 step side
87 swb
Old 02-12-2016, 09:34 AM   #11
piecesparts
Re: Bird Poop
The most important of this whole thing, is that you have a good protective wax or sealant on the paint. That will protect you to an extent, until you take the poop off. Note: that the poop needs to be removed in a short order time. The stomach acids will etch the paint, especially in hot weather and sunshine.
Frank
Old 02-12-2016, 10:29 AM   #12
calvin78612
Re: Bird Poop
Yep, I keep a cover over it for now until I can build some type of carport.
84 step side
87 swb
