Closed Thread
Old 01-25-2016, 08:28 PM   #101
Lanman1972
Lanman1972's Avatar
Re: Post Your Craigslist Finds
https://omaha.craigslist.org/pts/5381423169.html
C10/Z28 build anyone?
Lanman1972 is offline
Old 01-25-2016, 08:40 PM   #102
Lanman1972
Lanman1972's Avatar
https://desmoines.craigslist.org/ptd/5386586797.html
Need a Grill?
Old 01-25-2016, 11:04 PM   #103
Nitis
Nitis's Avatar
Another 4 eyed horn!!! Camper special factory air and that bronze color in California should be fairly rust free.
http://chico.craigslist.org/cto/5419095650.html
Nitis is offline
Old 01-26-2016, 12:16 AM   #104
budnikguy
budnikguy's Avatar
K5 anyone?!
http://inlandempire.craigslist.org/cto/5418408692.html
budnikguy is offline
Old 01-26-2016, 04:24 PM   #105
brownboyrocks
Found this in Austin, and went to check it out myself. The engine is clean and sounds great. The radiator looks new, but the engine and most of the main components are original factory parts -- even the AC system. (The AC/Heater blower isn't strong so that will need to be checked out, but I'm not too worried about that.) I took it for a drive and it corners great, has no problems getting up to 70 on the highway, and the brakes are tight. Stopping is no problem. Here's the issue with this truck... the sliding glass in the window look like they're just two piece of glass cut to fit just enough. There's no latch or rubber seals so they either need to be replaced or the whole window switched to a solid rear windshield. The driver's side vent window is missing or has become disconnected from the post-arm so it dangles when it opens. Most of the door and window seals are decent enough, but will need to be replaced to be used as a daily driver. Then, there's the paint. Some knucklehead thought it would be a good idea to cover the original olive green paint with a half-assed white/yellow two tone paint job. They even painted over some of the accent pieces like the Cheyenne decal on the front driver quarter panel. It has the original AM radio, all the original nobs, nice carpet, the seat has tears but is in good condition. The body lines are straight and the only missing trim is what goes around the rear tail lights.
I'd like to buy this as my daily driver. I told the guy I'd give him $5500, but not sure that's decent deal for a truck that's going to need some work before it can be a true daily driver. My main concerns are the rear windshield, the driver side vent window, and the crappy paint job. Everything else really does look, sound, and runs great. What do yall think?
Here's the text from the ad:
1972 CHEVROLET C10 FACTORY A/C ORIGINAL MILES ($6500)
MILEAGE :93039
EXTERIOR COLOR: YELLOW
INTERIOR :GREEN
TRANSMISSION: AUTOMATIC
FUEL:GAS
TITLE STATUS: CLEAN
Last edited by brownboyrocks; 01-26-2016 at 04:24 PM. Reason: Wanted to add a last question.
brownboyrocks is offline
Old 01-26-2016, 05:43 PM   #106
cypressbog
Go Pack Go!
This one's been for sale since last fall.
http://greenbay.craigslist.org/cto/5405926403.html
cypressbog is offline
Old 01-26-2016, 05:57 PM   #107
Wasted Income
Boosted Member
Wasted Income's Avatar
I used to live in South Range...that definitely looks like something you'd see parked at the VFW any given night.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline
Old 01-26-2016, 06:37 PM   #108
brownboyrocks
Here's another one in Austin that just popped up:
http://austin.craigslist.org/cto/5418803089.html
Old 01-26-2016, 06:38 PM   #109
brownboyrocks
Here's a 1972 Gmc short bed v8 auto - $5000
http://austin.craigslist.org/cto/5395345839.html
Last edited by brownboyrocks; 01-26-2016 at 06:56 PM. Reason: changed to fit the board .. 67 -72
Old 01-26-2016, 06:40 PM   #110
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
This has been for sale for a while, like since last fall. Looks like a decent truck to me. I would think it hasn't sold because there are too many nice trucks in the the Truck Rich Tri States of Washington, Oregon & Idaho that could be had for substantially less money.
http://bend.craigslist.org/cto/5408088939.html
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 01-26-2016, 06:47 PM   #111
cypressbog
Go Pack Go!
Originally Posted by brownboyrocks View Post
Let's try to keep this 67-72 only.
Old 01-26-2016, 09:36 PM   #112
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Atlanta area -67 Stepper project
http://nwga.craigslist.org/atq/5374798237.html
68 SWB Fleet
http://atlanta.craigslist.org/nat/cto/5384054784.html
D.PASSMORE is offline
Old 01-27-2016, 01:05 AM   #113
brownboyrocks
http://austin.craigslist.org/cto/5419348768.html
1972 Chevy C-10 Big Block *** - $8000 (Dripping Springs)
I am selling my C-10 truck I have had for years. This truck is an Arizona truck but it does have some rust on the rocker panels. This truck is an original truck with factory A/C , Tilt steering , power steering and disc brakes. I recently had a big block 462 built for the truck using a 1973 stingray 454. Has a QFT slayer 750 carb . Eldelbrock intake , Has a spitfire distributer. big lumpy cam. The truck has an electric fuel pump and electric fan with upgraded alternater and AC compressor.It has the new serpentine belt system , It also has a new Turbo 350 trans built to withstand 800 HP from winner circle transmissions in san Antonio with a 2600 stall converter. New dash , newer carpet original factory radio
(not cut-out ) new instrument bezel etc. The motor has less than 100 miles on it. It drove from the machine shop to the house and sat. I don't have any time to fool with the truck. Please text or call for any more info thanks. 830-sixone3-499eight.
Old 01-27-2016, 01:07 AM   #114
brownboyrocks
1971 gmc truck - $16500 (copperas cove)
New paint, new custom pinstripes, new wheels and tires, flowmaster exhaust with bell flowers, new tonneau cover, new interior to include leather seat, new bumper, lenses, and grill. 350/350, runs and drives perfect, everything works. call for more info. Tony
Old 01-27-2016, 01:11 AM   #115
brownboyrocks
1971 Chevy C10 pickup truck - $12500 (Dallas tx love field airport)
Selling a very clean 71 C10 Cheyenne long bed. It has a 350 v8 and 350 auto transmission. AC and heat and new hei distributor and new edelbrock carb.
Factory power disk brakes, tach, am fm radio, new exhaust, power steering, all new CCP lowering springs 3&4 inch drop. New BOSS wheels with low profile 20's and a nice tonneau cover. If this truck was a shortbed it would easily be over 20k. Asking 12,500 and worth every penny. At this price it won't last. These trucks are becoming very sought after.
Will trade for other cool classic or modern cars, boats, real estate, etc.
http://austin.craigslist.org/cto/5374437224.html
Old 01-27-2016, 01:23 AM   #116
brownboyrocks
1972 Chevy K10 4X4 Truck - $17500
1972 Chevy K10 4x4 Truck - all original,completely rebuilt original engine, automatic transmission, power steering, power brakes, original ac and heat, 4"lift, New BFG all terrain tires, new shocks, too much to list. Truck runs, drives and looks great! $17500 Serious inquiries only, no emails or text!! Please call 830-672-1200 or 210-396-0781
http://austin.craigslist.org/cto/5405239890.html
Old 01-27-2016, 09:20 PM   #117
Synestran
Looks to be a nice truck but most around here are priced at around 5k or so...Granted this one is pretty darn clean looking.
Synestran is offline
Old 01-27-2016, 11:03 PM   #118
jocko
jocko's Avatar
That's a nice truck, but I'm tired of seeing it listed about 10 different ways in every city in tx when I do a CL search.... And I love ochre.
jocko is offline
Old 01-27-2016, 11:04 PM   #119
jocko
jocko's Avatar
I'm dying to know if it has parchment door panels (i.e. if perhaps it might be a hidden highlander...) Has the 72 DG4s on it and I smell plaid... Regardless, seems to be a good deal at $3500 for a C20 CustomD Custom Camper with a big block. Sacramento sure has a lot of nice old trucks on the market all the time.
http://sacramento.craigslist.org/cto/5419529155.html
jocko is offline
Old 01-27-2016, 11:12 PM   #120
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I think I looked at this one in Marysville on my way to my cabin. It wasn't for sale then. I don't remember it having parchment anything. It had a black interior. It also had woodgrain lower trim.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is offline
Old 01-28-2016, 11:05 AM   #121
Aruba1
Originally Posted by Aruba1 View Post
Hurry up and get this. In Montgomery, AL. Runs and Drives. 5 Speed gearbox, 307 CI. $1,000!!!! No affiliation. 1969 C20. Seems like a lot of rust on passenger floor though but the price is fine.
https://montgomery.craigslist.org/cto/5415822183.html
Update: During conversation with the seller I found out it's a 4 speed gearbox and he said he will be updating the Ad. He thought all these trucks came with 5 speed ;-)
Aruba1 is offline
Old 01-28-2016, 11:22 AM   #122
73737373
Scrap value alone is about $400-$500. So you're getting all that for really, $500-$600. Sounds like a good deal.
73737373 is offline
Old 01-28-2016, 11:35 AM   #123
dubds10
Stalker Nate
Scrap is $30/T so more like $200 max. I'm finding some prices are starting to drop again for the rust buckets as they are usually in line with scrap prices in my market. $500 on that truck is ok, not much more due to rust though.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline
Old 01-28-2016, 12:04 PM   #124
Aruba1
I think it's a good deal by itself because of the low scrap value. Here in Alabama scrap yards are paying between $3-4 a hundred so that is $108-144 for a 3600 lb truck.
Aruba1 is offline
Old 01-28-2016, 02:32 PM   #125
73737373
Interesting....that's an awful lot of labor cost built into that asking price. Given the cost of paint jobs/restorations etc etc, he's not totally unreasonable. Have seen worse for much more. If I was close, would certainly set an appointment w/the guy to check it out.
73737373 is offline
Closed Thread
