Old 01-25-2016, 09:06 PM   #1
Andy4639
Old member
Andy4639's Avatar
Talking I waited
As the old saying goes...good things come to those who wait!
Well I've been waiting for ever to put bags in my truck. I couldn't pass this deal up either not for $500.00 + a 4 hr ride. The ride don't bother me at all.
I hope I didn't throw away $250.00 deposit. Thursday I drive down to Atlanta to pick this up and pay him the rest.
It's not the E level but hey it's bags!
I can always add the rest later I guess.
I also will need to put the notch kit I bought back in the spring in it also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-25-2016, 10:55 PM   #2
PGSigns
PGSigns's Avatar
Re: I waited
Good looking setup. Should get you going just fine. I don't see the relays for the pumps or the pressure switch so ask about those.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-26-2016, 06:49 AM   #3
bbbc10
Diggin The SquareLife
Re: I waited
Hope you didnt throw away 259 deposit also.....never good to buy used air bags an the valves look like off brand of some type an not sure on compressors....
bbbc10 is offline   Reply With Quote
Old 01-26-2016, 07:38 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: I waited
He said, everything is in good condition. I know but I figured it was worth it.
Old 01-26-2016, 08:51 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: I waited
Looks like AirBagIt.com valves.
(look them up. not good reviews)
http://www.airbagit.com/Brass-Air-En...engine-8aa.htm
Probably the entire set-up came from them.
I would check the bags closely for dry-rot cracks.
Air compressors should have check valves on the hoses.
I hope this works out for you,... but I would pass on that type of air valves.
A manual valve set up would be better.
Member way2lo2 sells great air ride products.
http://stores.ebay.com/Street-Machin...=p4634.c0.m322
Keith
Convert to disc brakes.
Old 01-26-2016, 09:57 AM   #6
andrewmp6
Re: I waited
If those valves are airbagit throw them away.
Old 01-28-2016, 09:15 PM   #7
Andy4639
Old member
Andy4639's Avatar
The bags look fine to me. I couldn't see any cracks. The parts are Chassis Tech with ccp mounts on the front. The compressors both have check valves. The pressure switch is on the tank. The only thing he didn't have was the relays and the solenoid which I have several of both.
I need a good wiring diagram!
Old 01-28-2016, 09:38 PM   #8
lolife99
lolife99's Avatar
Re: I waited
AIM then Chassis Tech then AirBagIt.com.
All the same company.
Call them for your wiring diagram.
Keith
Old 01-29-2016, 03:20 AM   #9
andrewmp6
Re: I waited
Yeah aim aka chassis tech aka airbagit is the same company and they sell total junk,I would be scared to run anything they made.
Old 01-29-2016, 05:33 AM   #10
BigMike
BigMike's Avatar
Re: I waited
Here is one of the schematics that helped me
BigMike is offline   Reply With Quote
Old 01-29-2016, 09:26 AM   #11
Andy4639
Old member
Andy4639's Avatar
Thanks BigMike that's what I wanted.
I'm sure you all know more than me but I'm going to run this system first just to get my feet wet. I want to add the accuair e system later but have to have funds for that. The wife is already pissed about this stuff, wait till she findout how much that e system costs!
One thing I don't like so far about this, is the thought of cutting a big hole to route the 4 air lines into the cab.
Old 01-29-2016, 10:26 AM   #12
HafTon
HafTon's Avatar
Re: I waited
Congrats on breathing some air into your suspension. You might want to check shocks and location while you're under the truck too.
HafTon is offline   Reply With Quote
Old 01-29-2016, 01:29 PM   #13
bbbc10
Re: I waited
Should have waited for a better deal....an i dont see why you cut a big hole in the cab to run the air line....could have ran the air line on the frame.....good luck with the parts hope they hold up
Old 01-29-2016, 02:16 PM   #14
lolife99
lolife99's Avatar
Re: I waited
Only lines that need to come inside the cab are the 4 air gauge lines.
And they can be 1/4" or 1/8".
(the valves are electric)
The Viair diagram is great, but make sure you run an inline fuse to the battery.
Also, make sure the air line and fittings are DOT rated.
Keith
Old 01-29-2016, 03:31 PM   #15
Andy4639
Old member
Andy4639's Avatar
And how does this get the lines to the gauges?
I have to cut a big enough hole to get the four lines in the cab. I guess I could mount the gauges under the hood.
Yes the lines and fittings he had are DOT approved the diagram does leave the inline fuse out but I plan on a radio cable with 50 amp fuse.
Old 01-29-2016, 04:00 PM   #16
Willie Makeit
Willie Makeit's Avatar
Re: I waited
used Chassis Tech parts? what could go wrong?
Willie Makeit is offline   Reply With Quote
Old 01-29-2016, 09:55 PM   #17
Andy4639
Old member
Andy4639's Avatar
Question Re: I waited
Well I got a little done today. I got the broke fitting out of the tank that I twist off. I bought a 2" nipple and tee to put the pressure switch and gauge in the same fitting. This is going to be a slow process!
He used grade 5 bolts for the plates. I'll swap them for 8's.
Question:
rear bag mounts he used just regular all threaded rod for mounting the bags, is this right are shouldn't I buy grade 8 bolts that are long enough?
Old 01-30-2016, 09:19 AM   #18
Andy4639
Old member
Andy4639's Avatar
Does this diagram work for 4 way switches to the compressor?
I think I understand it now. The compressor is basicly on anytime but the pressure switch keeps it from running as long as their is no leaks. The switches go to the selonoids and when one is operated the compressor will kick on. Right guy's, it took me a little but I think I got it.
Old 01-30-2016, 09:58 AM   #19
earl84
Re: I waited
Andy, don't let these naysayers rain on your parade. I guess their mom never told them if they don't have something nice to say, don't say anything.
earl84 is offline   Reply With Quote
Old 01-30-2016, 10:32 AM   #20
Ram-Man
Ram-Man's Avatar
Re: I waited
Yes the switches run the solenoids. Not the best but heres a link to the pic of the back of the gauge setup. https://www.airbagit.com/v/techzone/...Dual_Gauge.pdf
Ram-Man is offline   Reply With Quote
Old 01-30-2016, 11:29 AM   #21
lolife99
lolife99's Avatar
Re: I waited
Not raining here.
AIM/ChassisTech/AirBAgIt.com has been known for the last 20 years,... for selling junk, cheap parts.
They are also known for sending the wrong parts and chargeing HUGE restocking fees even when the mistake was theirs.
I was just trying to warn the OP about his purchase.
All of the top companies have switched to aluminum air tanks and quality switches.
To the OP,.. good luck with your purchase.
Keith
Old 01-30-2016, 01:17 PM   #22
Willie Makeit
Re: I waited
Not raining here.
each guy has to learn for himself. some even refer to it as a stupid tax.
Old 01-30-2016, 03:33 PM   #23
bbbc10
Re: I waited
Lol not raining on anything...just warning him of the parts and how nobody else would spend 500 and drive hours for that junk.
Old 01-30-2016, 07:45 PM   #24
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: I waited
I'm not worried about the ones saying it's not worth it. I'm not going for laying frame, that's not my goal. Just as I'm not going to put 2" lowered spindles on it yet. I may later but for now I want it to ride good and be able to lower it some at shows when I go.
I have built my truck for me not anybody else. I appreciate every ones opinions on the parts and they maybe right, but I'm going forward on this project. I have to decide if I'm going to mount all of it in the bed up by the cab are under the truck out back.
Ram-Man,
thanks for the wiring diagram that's what I had looked for but never found it.
Now for my next question. Would there be anything wrong with mocking the system up and trying it before installing it?
Old 01-30-2016, 08:51 PM   #25
SCOTI
SCOTI's Avatar
Re: I waited
Ram-Man,
"Laying frame" or not, low quality parts are what they were warning you about & can/will impact the end result/experiece (driving down the road & a cheap valve malfunctions; valves sticking when filling/purging; comps not funtioning when enabled).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
