01-31-2016, 01:11 AM | #1 |
AAW kit installed / Lights Problems
Hello from So Cal!
I bout a AAW classic update kit for my 70 c10 and just finished installing it. Followed all instructions and took my time. Now I'm having some weird things going on with the lights. Funny thing is that the all lights worked fine with old wiring harness. I've been searching on the forums and troubleshooting and now feeling a bit lost. Any ideas or suggestions greatly welcomed. 1. Plug battery in and both rear tail lights come on and drivers side front parking lights turn on. 2. When I turn left turn signal the lights blink and windshield wipers also begin moving. They don't operate fully just slightly move. 3. When I click right turn signal on nothing happens. 4. When I turn lights to on both rear lights turn off. 5. Dome light inside doesn't work at all. Sigh any ideas? LoL |
01-31-2016, 09:26 AM | #2 |
Re: AAW kit installed / Lights Problems
I had the same problem as you with 1. 3. 4. 5. the headlight switch was defective. It was on in the off position and off in the on position. I called AAW and they sent me out a new headlight switch and that fixed it up. Great customer service from AAW.
The windshield wiper problem sounds like a ground issue to me make sure all your grounds are in place and making good contact.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
01-31-2016, 09:53 AM | #3 | |
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
01-31-2016, 10:28 AM | #4 |
Grounds can do some funny things for sure. However in my case the headlight switch was a real issue confirmed by bench testing with an ohm meter. After I received my new switch I disassembled the defective one and found the contacts bent and out of place causing the problem, likely occurred during assembly at the factory.
Check your headlight switch with an ohm meter for continuity between the main power supply and the power out to your park lights it should not have continuity when in the off position.
01-31-2016, 10:40 AM | #5 | |
01-31-2016, 01:36 PM | #6 |
If you read through the threads, then you may have read some of my comments. I would not do one more thing if I were you until I replaced the switch. I finally just cleaned up my original and now still use it. The dimmer in my original was giving trouble and I cleaned it up now is good. Nothing on AAW about the switches. There is only one manufacture that makes them and they are of poor quality.
White K20 |
01-31-2016, 01:57 PM | #7 |
I've got a new switch sitting on my bench you can test with.
'68 C10 SWB '85 K30 Blazer |
Tags |
aaw, lights |
