Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-13-2015, 03:48 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Improving "sketchiness" at high speed.
*As my usual, this will be a long post.
So my truck has started to reach the point where "good enough" just isn't safe, and certain areas need to be shaped up. Recently I re-did a bunch of stuff including my whole heads/topend, and my truck should be in the high-11's with the driver mod (provided my mystery-meat converter doesn't eat itself).
At 70-120+, things just get a little sketchy in the front. It likes to wander a bit up , things feel a little sloppy and some vibrations don't help.
(LS powered '66, 72 front suspension stuff/PS, hydroost)
I added single adjustable Qa1's end of last year and they helped control things a bit, and I did a new outer tierod end, pitman arm and alignment a while back as well. Under most conditions, these changes have made it pretty well mannered and easy to drive, but the wander never really changed.
I do have a front swaybar, and its bushings all look decent.
The steering gear seems to have aged poorly, so I'm guessing at least some fault lies there. I don't have any form of steering stabilizer, nor any kind of pressure modifying valve on the hydroboost.
I'm also wondering if its possible that the weightloss of the inner fenders changed the load on the front springs enough to change my front alignment. I didn't think ~35lbs would do that but I could be wrong.
Other thought? Lazy balancing, mistorqued lugs, wind?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-13-2015, 06:59 PM   #2
Super73
Super73's Avatar
Re: Improving "sketchiness" at high speed.
How much caster did you put in it when aligned? I don't use factory specs and put as much a posible. Makes a difference!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-13-2015, 10:05 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
My pile was a handful on the top end, and shutdown. In fact scary as hell. I would rather take the Nova at wheels 6' in the air launches 9.teens and trapping @ 145 rather than that truck through the traps at 107 and mid 12's.
So I put the sway bar back on (yes,, you read right SWAY bar) and put some weight on the rear (15 gallon fuel cell and raced with 15 gallons) It settled it right down on the top end and surely didn't jurt the launch. In fact just before I retired it last year it was running 10.6's @ 122 and was BOREING. Maybe if I had gone back to something making me crap my pants every pass I would have tolerate the STUPID problems it kept throwing at me.
Now that's just my pile and you may already have a sway bar. But don't be so quick to condemn them. It's a simple bolt on that is worth a 'try' ,, right?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-14-2015, 12:00 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Super73 - I've never done my own alignments besides the "out the door" guestimate alignments with a string and such. I have my local I trust (not a racing shop) do most of my wheel/tire/alignment stuff. I don't know how many *s its currently running.
I'm using a front swaybar kit already, I've never bothered to unhook it for launch yet. I see so much street time that it just drive better with it attached.
I also already have a 16-18gallon cell as far and low as possible.
Old 09-14-2015, 05:16 AM   #5
BigDan3131
BigDan3131's Avatar
Has the steering gear been tightened at the nut? You know what I'm talking about right to take play out of the wheel? You said you have a newer front end but did you replace all the bushings including the ones in the rear? Hopefully not with rubber ones. Since its a truck was it 4 wheel aligned?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-14-2015, 07:41 AM   #6
PGSigns
PGSigns's Avatar
I would do the caster mod and have it re-aligned and get them to put 5 or 6 degrees in it with about an 1/8" of tow. http://67-72chevytrucks.com/vboard/s...d.php?t=501241
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-14-2015, 10:59 AM   #7
Super73
Super73's Avatar
Jimmy
Exactly my thoughts. If it is factory caster settings, they don't seem to like 80mph +
Old 09-14-2015, 01:09 PM   #8
Ont67shortbox
is the power steering still hooked up.Mine used to float like crazy on the top end,came back,took the power steering belt off 100% improvement
Ont67shortbox is offline   Reply With Quote
Old 09-14-2015, 02:31 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The little "adjuster nut" on the gear itself? I haven't tightened that. Anytime I've asked about that in the other sections, everyone just says it ends up ruining the steering gear. I know its there to take up some of the lash in the gear. Would you say its worth trying?
The 71-72 front stuff was installed by the PO before I got the truck, though I've done my best to troubleshoot his install. Everything jives pretty well for the most part. I have not replaced ALL the bushings, only a few as-needed very very early in owning the truck 5+ years and before it had an LS motor.
I'm ASSuming it was a 4 wheel alignment, but I can't promise with certainty that it was.
I would do the caster mod and have it re-aligned and get them to put 5 or 6 degrees in it with about an 1/8" of toe. http://67-72chevytrucks.com/vboard/s...d.php?t=501241
Jimmy
I will do this...he may VERY well likely have used a stock #, as I didn't provide him a specific goal/tolerance to hit. I suppose unless he knew I wanted the extra tow, he wouldn't have done and done that on his own.
Its hydroboosted so I can't disconnect my power steering unless I don't want brakes
Old 09-15-2015, 11:04 PM   #10
Kyle@FTP
Jimmy
Some smart fellers in here. I would start here as well. The truck wasnt designed to do 80mph. In the long drawn out front suspension we are doing, we designed in a bunch of static caster so in shut down when the nose drops its still stable as could be.
Kyle@FTP is offline   Reply With Quote
Old 09-16-2015, 12:58 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Great segway for me to ask; when should I expect my prototype? Heheheh
Old 09-16-2015, 09:32 AM   #12
Kyle@FTP
As much as I would say its being shipped that would be far from the truth. I have consumed by the day to day of the shop and getting customer trucks out the door. We tried to have the first version in metal for the open house next week and didnt even come close!
But it is coming.
Old 09-16-2015, 12:21 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Good thing...my truck isn't getting any slower
Old 09-16-2015, 12:40 PM   #14
vin63
It's Better With Nitro
vin63's Avatar
More than likely, not the weight, but the aero effect of no longer having the inner fenders to maintain a low pressure area under the hood. As you go faster without the inner fenders, the air pressure increases under the hood, creating lift.
As an example, I first ran my 1963 Chevy II without inner fenders when I competed in local bracket classes (high 12 second passes). When I stepped up to run Super Gas in the mid 1980s, at 120+ mph, I had to install inner fenders to keep the pressurized air from sucking the air/fuel out of the carburetor (not sealed to the cowl scoop). The other benefit I found was the car was a lot more stable at speed.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-16-2015, 01:20 PM   #15
BMERDOC
BMERDOC's Avatar
I agree with the guys here. Make sure that box is tight and then more positive caster and more negative camber. The factory specs are atrocious. 1/16th toe per side (1/8" total).
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 11-13-2015, 10:37 AM   #16
OutlawDrifter
i think a custom alignment will definitely help out, total agreement with the guys above.
also consider, at 100mph, i bet that thing is also trying to lift off. the body was never designed for down force. some kind of splitter or air dam on the bottom of the bumper would help out.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 12-17-2015, 06:40 AM   #17
74CustomK20
74CustomK20's Avatar
Vents in the fender well coming to outside the body to get rid of the pressure?
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-23-2015, 07:50 PM   #18
ptc
ptc's Avatar
Front end geometry is #1, then steering is next. I hope you are not using a stock steering box????? As for the hydroboost, yes you can still use it with the pump, just try bypassing the steering and plug those lines. Use manual steering at the drags. Your NOT turning!!!!
Areodynamics plays a critical roll at high speeds.... imagine what this truck would look like in a wind tunnel???? I think a rolling 'brick wall' would be a good description. If you cant reduce drag or release pressure then keep it from coming into the body in the first place.... pan the bottom at least past the front wheels. Close the leading edge of the wheel openings with lexan.
Have you ever looked under an F1, indy or even a GTP car? everything is enclosed!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 12-25-2015, 03:27 AM   #19
Super73
Super73's Avatar
I am sure I could stand some aero adjustments.. but 145 mph things "feel" good. Might go faster though..
Old 12-26-2015, 08:35 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm using the ps gear from the '70's donor truck that the front end is from. I think the gear was replaced in the 90's with a parts store rebuilt. I'm using that until she gets the RnP. The weird part is that if you isolate each part of the steering system, its all individually nice n tight.
Disconnecting the ps every time I tracked it would be prohibitively annoying, and messy. I'm still convinced some sort of orifice reducer or one of those adjustable flow regs is at least partially needed for that end of things. (and the over boost is a different sensation from the general high speed sketchiness).
The aero definitely needs work. The truck is on this borderline between quick street truck, and very quick street truck but a whole chunk of things need to happen to really take it there safely, and it looks like some work on the aero is gonna be in that group.
Old 01-27-2016, 07:30 PM   #21
ptc
ptc's Avatar
This should be OK, I was thinking the stock 60's truck box!!!! thats a NO NO.... lol
If you made your lines so they have quick connect couplers in them, then they could be easily swapped out in minutes.... see pic!
Aero stuff really works wonders, and its cheap as long as you stay away from carbon fiber!!!!
Old 01-29-2016, 02:56 PM   #22
Super73
Super73's Avatar
Hey I have a stock manual truck steering box
Old 02-01-2016, 06:34 PM   #23
ptc
ptc's Avatar
DUDE!!! ---- you have to evolve!~!!
Old 02-02-2016, 11:37 PM   #24
Hollow65
Hollow65's Avatar
No power steering here, just my noodle arms. Truck is fine at 130. No front sway bar either. I did have steering slop but tightened at the box. I think I heard it called a worm gear?
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 02-03-2016, 02:26 AM   #25
Super73
Super73's Avatar
I will, its called rack and pinion when I go round tube front.
