02-05-2016, 08:31 AM | #1 |
Re: V-8 to I6 change
I'll start with a carb rebuild. I know its running rich. Then the fact that our highway dept has been messing with the stoplights doesnt help(lot of stop and go). As far as my driving habits, I dont race between lights etc. Just normal driving.
02-06-2016, 02:25 AM | #2 |
60-66 Nut
If that carb is any bigger than 500cfm it may be too big. Also Edelbrock carbs will not tolerate more than 5 -5.5psi of fuel pressure. If that is the sort of mpg you are getting, something is seriously wrong. I would swap it out for a 350 before I would go back to a 292. A 350 will get better mileage.
02-06-2016, 10:27 AM | #3 |
I changed a 70 Nova and a 69 Camaro from I6 to v8 many years ago. I could never imaging going the other way except for an OEM restoration.(if even that).
I say the others are right here, you have a problem with the engine or possibly the transmission. Also, a 350 will give better power than the 283 or a 292, therefore not have to work as hard=better mileage(under civilized driving conditions)
Brian 1969 c-10 (soon to be short bed) 1982 Malibu Wagon-For sale -SOLD 1964 k10 suburban project 1947 Dodge chop top rescue project-SOLD |
02-06-2016, 10:30 AM | #4 |
My carb is a 500cfm Carter. I used to have a pressure regulator on it but someone told me I didnt need it. It's an adjustable one. Should I put it v
back on? One other thing is I cant get it to idle at the 500rpm its supposed to. It may be timing but it keeps wanting to die on me so I have to keep the idle at 1000rpm. Im going to have a professional mechanic rebuild the carb and set the timing using the vacuum. |
02-07-2016, 01:54 AM | #5 |
60-66 Nut
First the timing needs to be set correctly and then the carb. If you can find a mechanic that knows how to work on old school engines you will be fine. There is a ton of info in the 'Engine and Drivetrain' section of this forum that can help you get your engine dialed in.
