Old 05-01-2015, 11:52 PM   #626
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Porterbuilt Dropmember
Delmo on the cover of the new StreetTrucks magazine with one of the coolest converted 4x4 K5 blazers ever built.
Full Porterbuilt level three Dropmember, 4-link suspension, LS engine, Accuair, Hill's Rod and Custom inner fenders, DelmoSpecial 22/24 Custom wheels and so much more.
Get your copy today!
Keith
Convert to disc brakes.
Old 05-06-2015, 09:15 PM   #627
bharrison1
bharrison1's Avatar
I have a 73-87 Dropmember V3.2 my question is will this fit 60-66 and 67-72?Thanks
bharrison1 is offline   Reply With Quote
Old 05-07-2015, 09:40 AM   #628
aggie91
I'm just glad to be here!
aggie91's Avatar
The 73-87 frame rail is about 3/4" taller at the crossmember than the 63-72 frames. It is the same width, but the inner frame support brackets will be too tall.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-07-2015, 09:57 AM   #629
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I put a factory 73-87 crossmember in my '68, worked fine.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-07-2015, 10:50 AM   #630
lolife99
lolife99's Avatar
The Dropmember's inner frame support is a different height on the 67-72 vs the 73-87, since the frame rails are slightly taller on the 73-87 trucks.
This has no affect when using an oem crossmember, since there is no inner frame support.
Keith
Old 05-07-2015, 11:58 AM   #631
C10_ustacould
Good info to have!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-07-2015, 05:38 PM   #632
Slick67
Sofa King Crazy!!
Slick67's Avatar
Not only the front crossmember, but the trailing arm crossmember has the same inserts. So that wouldn't fit either.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-07-2015, 10:23 PM   #633
bharrison1
bharrison1's Avatar
Old 05-20-2015, 12:23 AM   #634
rip2174
did the write up from Porterbuilt on oil pans every come about?
rip2174 is offline   Reply With Quote
Old 06-12-2015, 07:15 PM   #635
C10Greg
Just wondering about that myself. Any new info?
C10Greg is offline   Reply With Quote
Old 06-12-2015, 07:41 PM   #636
C10Greg
Nate, I also have a question about your LS Motor Mounts. Is is possible to run a series of holes together so that the engine could be moved forward or backward in small increments? The holes that I am talking about would be just like the series of holes you now use on your trailing arm crossmembers. Here is a link to a picture in case I am not making any sense.
https://www.azproperformance.com/Por...ossmember.html
Old 02-05-2016, 09:21 AM   #637
SLY-C10
SLY-C10's Avatar
extreme drop...
SLY-C10 is offline   Reply With Quote
Old 02-05-2016, 10:54 AM   #638
lolife99
lolife99's Avatar
VERY nice!^^^
Keith
Old 02-06-2016, 12:12 PM   #639
SierraMtns
SierraMtns's Avatar
Originally Posted by PBFAB.COM View Post
Few more pics of the Ford stuff.
Nate,
I have been looking all over for build info on the 4bt that's in this unibody.
Do have any info?
SierraMtns is offline   Reply With Quote
Old 02-08-2016, 12:49 PM   #640
Hart_Rod
Hart_Rod's Avatar
I'm about to wrap up my 68 C10 build and was wondering if anyone has any suggestions/ideas/pictures of how you route the front air lines to the bags? I'm using the standard flexible lines, but do not se a clean way to do it. Thanks in advance, and OBTW, here are some pictures, .
#Shifted #ChubTubz #HartRod #Seafoamgreen #503Green
Hart_Rod is offline   Reply With Quote
Old 02-08-2016, 01:00 PM   #641
lolife99
lolife99's Avatar
Are you not wanting to drill a hole and run the tubing thru a rubber grommet?
Not sure what you are looking for.
You can buy "bulkhead" PTC fittings that would mount in the frame rail.
https://www.grainger.com/product/EATON-WEATHERHEAD-Bulkhead-Union-2ZKY6?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/2ZKY4_AS01?$smthumb$
Keith
Old 02-08-2016, 01:05 PM   #642
lolife99
lolife99's Avatar
This is a clean install also,...
http://67-72chevytrucks.com/vboard/s...d.php?t=390299
Keith
Old 02-08-2016, 01:13 PM   #643
Hart_Rod
Hart_Rod's Avatar
That's a nice fitting Keith! Pricey too! . I will have to check into those.
I have no problem drilling a hole in the frame. I'm just trying to figure out if people are coming from the front side of the front crossmember (red) or from the backside of the front crossmember (blue). If you come from the front, you have to loop the air lines 180. If you come from the backside, you have to contend with the brake lines and the shock mounts. Either way, I don't see and easy or clean way to do this.....
Old 02-08-2016, 01:15 PM   #644
Hart_Rod
Hart_Rod's Avatar
It is, but I'm not doing the steel lines...
Old 02-08-2016, 09:48 PM   #645
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here's a pic I took at Delmo's a few months back.
ChuckDriver is offline   Reply With Quote
Old 02-10-2016, 09:59 AM   #646
Hart_Rod
Hart_Rod's Avatar
Thanks JJ! Those helped a lot. I think I have it figured out. Will post pics this weekend.
R/
Old 02-10-2016, 10:10 PM   #647
Advanced Design
Advanced Design's Avatar
Thanks for that picture ChuckDriver. On a different subject, does anyone know what accessory drive this is? VA?
Advanced Design is offline   Reply With Quote
Old 02-10-2016, 11:46 PM   #648
Longhornss
That is a billet specialties Tru Trac
http://www.billetspecialties.com/tru.../ls-chevrolet/
Longhornss is offline   Reply With Quote
Old 02-11-2016, 01:55 AM   #649
Advanced Design
Thanks Longhornss.
Old 07-21-2016, 02:11 PM   #650
Woodnears
I am just gonna leave these here for yall to check out!
I am getting so close I can taste it!
Woodnears is offline   Reply With Quote
