Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-15-2016, 09:12 PM   #76
57taskforce
All about them K’s
57taskforce's Avatar
Re: 72 k/20
Tyler
Old 02-15-2016, 09:13 PM   #77
57taskforce
All about them K’s
Re: 72 k/20
I'll post a better explanation soon.Ive still got a ton of grinding and metal finishing to do and the welds aren't nearly as gnarly as the camera makes a few of them look.(that's what they all say right?) The floor panels on both sides required a fair amount of tweaking as you can see, but what else is new?
Tyler
Old 02-15-2016, 10:19 PM   #78
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k/20
Nice K20 and great work on it so far! It's getting really hard to find a decent K20 to start with anymore!
Ryan
1969 Chevy milk truck
Old 02-15-2016, 10:40 PM   #79
swamp rat
swamp rat's Avatar
Re: 72 k/20
Thanks for the update!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-15-2016, 10:52 PM   #80
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k/20
Strong work Tyler! Hope to see it in person soon.
Old 02-15-2016, 11:05 PM   #81
undertaker72
undertaker72's Avatar
Re: 72 k/20
Tyler that truck has came a long ways since I sold it to you you have done a good job it's great to see the progress what's with the extra set of ocher and white doors is that something you're going to get rid of
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 02-15-2016, 11:18 PM   #82
57taskforce
All about them K’s
Re: 72 k/20
Thanks guys! It's coming along slowly but surely. Still lots of loose ends. So as you can see I swapped the front fender even though I straightened the original it wasn't in too good of shape at the lower rear corner so I elected to use another fender I had stashed away. I scored the set of doors in the last picture from my neighbor for $20. The driver has got a very small amount of rust (and I mean small) in the lower rear tip but otherwise they are straight and rust free. The green pic is for Russ. Unfortunately my father in law robbed the mirrors but you can see where the holes are. If you'd like I can take some measurements. I'll update some more over the next few weeks as the rear metal work comes together. I've also gathered up a very nice set of olive '72 door panels from Pete and I got really good oe black steering wheel for it as well. Need to find a reasonably priced 4 speed tilt column before it goes in.
Pete: If your gonna be in town let me know maybe we can work something out. I need to get those nl2 parts from you.
Kevin: Yep she's come a long way pretty slowly! I'm not sure what I'll do with the doors yet. They aren't 72's so I can't decide whether to slap them on there or not. I'll probably sell either the orange set or the ochre set once I decide which one I'm gonna run on the truck.
Tyler
Old 02-16-2016, 06:26 PM   #83
Russ33
Re: 72 k/20
Tyler ,If you could take a few measurements for me that would be great and take a pic with a tape measure laying on it would also work. Thank you very much. Russ
Russ33 is offline   Reply With Quote
Old 02-16-2016, 06:46 PM   #84
57taskforce
All about them K’s
Re: 72 k/20
Give me a day or two and I'll get them for you.
Tyler
Old 03-05-2016, 10:33 PM   #85
YBNORML
YBNORML's Avatar
Re: 72 k/20
Hey Tyler, thanks again for the mounts. I thought you might appreciate a pic of the bad one, not so bad anymore.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-06-2016, 12:48 AM   #86
57taskforce
All about them K’s
Re: 72 k/20
Jason, that turned out pretty damn nice! Glad you could put them to use.
Tyler
Old 09-24-2016, 03:02 PM   #87
57taskforce
All about them K’s
Re: 72 k/20
It's been a while since I've updated but I've got the ole beast running like a champ. New fuel pump, carb rebuild, and full tune up and she screams. I've been driving it around pretty frequently over the last few months and it's a running son of a gun. I replaced the driver side brake caliper and flushed the whole system. It runs and stops pretty nice. I don't believe it's a factory spec 350. From about 5 mph It will burn the rears off all the way thru second
I haven't done much on the body this summer. I've been in the middle of getting a new house finished up and my family will always take precedence over these old trucks. It still needs can corners and rockers finished up but I'm gonna pull it into the shop this winter for a full tear down to the frame, not gonna be a full show quality resto but a nice straight driver. I acquired a hydraulic clutch setup from an 80s truck and I've got some other things in the works.
I'll get a few a few pics up soon.
Tyler
Old 02-18-2017, 09:47 PM   #88
57taskforce
All about them K’s
Re: 72 k/20
Pics incoming!! I've not been working on my K/20 much in the last year (bought a new house, had another kid, work was busy) life got in the way. However now that things are settling down some I'm gonna get back at it. I've got it worked out where I can keep the truck in the shop at work long term... you guessed it I'm driving it to the shop tomorrow evening. From there I think I'm gonna pull it all the way down and build it back up. I didn't quite finish the metal work so that will be first priority. From there I'm gonna clean it all up paint the frame and drive train, hydraulic clutch, new springs, shocks, gonna center the 14 bolt with new perches, etc. basically I think I've made the decision to more or less go thru the whole thing. Last summer I did go thru and tune the motor up and it does run and stop very well. I also replaced the turns signal switch and got all the lights working as they should. Here's some pics of how it looks now.
Tyler
Old 02-18-2017, 09:52 PM   #89
57taskforce
All about them K’s
Re: 72 k/20
Tyler
Old 02-18-2017, 09:57 PM   #90
57taskforce
All about them K’s
Re: 72 k/20
Tyler
Old 02-18-2017, 10:02 PM   #91
57taskforce
All about them K’s
Re: 72 k/20
Ive got everything to make it a complete truck so hopefully it won't be to bad getting the nickels and dimes to get it finished.
Tyler
Old 02-19-2017, 11:30 AM   #92
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k/20
Thanks for the update Tyler. Let me know what I can do to help. I've got some parts put aside for you and there is no rush on those. Hope the baby is doing well.
Old 02-19-2017, 05:09 PM   #93
57taskforce
All about them K’s
Re: 72 k/20
Thanks Pete my kids are great, I hope your family is doing well! We are planning to come your way early in march. I will let you know more as the time gets closer.
Tyler
Old 02-19-2017, 06:20 PM   #94
undertaker72
Re: 72 k/20
tyler , that ol girl has came along way since the day we loaded it down here , glad to see the updates and the work progressing
I aint nobody DORK
Old 02-19-2017, 09:34 PM   #95
57taskforce
All about them K’s
Re: 72 k/20
Thanks Kevin, it has come a long way. I drove it to the shop today. About 15 miles. That's the longest I've driven it at one time since I've owned it. Mostly I've just been putting around the farm in it. It did really good, ran flawlessly.
Here it is in its temporary home. More pics to come in the coming weeks.
Damn iPhone posted it sideways
Tyler
Old 02-21-2017, 10:37 PM   #96
57taskforce
All about them K’s
Re: 72 k/20
Here's a few battle shots from this evening. The first is from yesterday afternoon when I started tearing it down. The rest are progress as of tonight. Hope to have the cab off and on the stand by Friday. Next week I hope to yank the drive train and begin fixing the frame up and getting it ready for paint.
Tyler
Old 02-21-2017, 10:50 PM   #97
Dieselwrencher
Re: 72 k/20
The frame looks really clean on it! It's coming apart fast!
Ryan
Old 02-21-2017, 11:01 PM   #98
57taskforce
All about them K’s
Re: 72 k/20
The back half is real nice... the front especially by the steering box is a bit of a mess. Mainly just a Half ass crack fix. I'll have better pics of it after I hit the frame with the heated pressure washer.
Tyler
Old 02-23-2017, 01:02 AM   #99
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k/20
Find anything fun in the cab like old beer can pull tabs or .22 rounds?
Old 02-24-2017, 10:27 PM   #100
57taskforce
All about them K’s
Re: 72 k/20
Yea Pete, there was so much crap in there when I first brought it home, bullets, 20+ year old pvc cement, old beer cans, and a whole lot more junk.
Got a good bit more done over the last couple days. Gonna head to the shop tomorrow morning to use the heated power washer to clean the frame and drive train. I'm gonna pull the motor next week and begin working on a few frame issues next week.
Tyler
