01-22-2016, 12:15 AM | #176 |
Re: The Snortin' bull
Just layin' some more pipe. I know these picture's are kinda boring though I have found that in the forum's we pick up subtle little helpful thing's in the picture's. Just need to trim and fit and finish off the tailpipe's. Install header flange to pipe gasket's maybe tip's and exhaust is done.
The Snortin' Bull |
01-22-2016, 12:43 AM | #177 |
Looking good, nice progress.
01-22-2016, 11:36 AM | #178 |
The Snortin' Bull |
01-24-2016, 09:52 PM | #179 |
rear pipe's together from mufflers back to rear behind bumper area.
The Snortin' Bull |
01-28-2016, 12:07 AM | #180 |
Exhuast is all in and hung.Used Remflex gaskets at headers , pipe is 2.25" aluminized steel.Mufflers are Jones Exhuast.Moved suspension thru far and lowest position no interference.Front down pipes get close to the ground when aired down though.Might to redo those in future.
The Snortin' Bull |
01-30-2016, 08:38 PM | #181 |
Went to fire the truck up today.Chased some leak's around though one at the carb would not stop. Got a little to gorilla like with this fitting.My day was done. For now.
The Snortin' Bull |
01-31-2016, 11:22 PM | #182 |
I ended up using 1987 c-10 power steering gearbox.Same for the idler arm.The donor front crossmember was 1987. The center link is stock using CPP tire rod adapter sleeve's for a little bling.These adapt ausing both early and later tie rods end's .Sorry for the late response though all was coming together.
The Snortin' Bull |
02-01-2016, 03:57 AM | #183 |
Like your pipe work.
Looking great. I am looking forward to when I can eventually build my pipes.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
02-01-2016, 02:20 PM | #184 |
Thank you, The pipe's and the small thing's are time consuming .
The Snortin' Bull |
02-03-2016, 12:39 AM | #185 |
Repaired the fuel feed into BG Demon carb. Ready again.
The Snortin' Bull |
02-03-2016, 11:43 AM | #186 |
SAVING ONE TRUCK AT A TIME
Nice. Time to get it on the road.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
02-03-2016, 12:56 PM | #187 |
Yes it is , Shake out the bug's, get it aligned. And continue with misc. I am getting excited.Time is what i have to find though.Work and life keep me busy.
The Snortin' Bull |
02-07-2016, 12:01 AM | #188 |
Fully aired down. The truck was planned out to be able to cruise at full aired out. I did not build it to lay frame but to almost appear to and still slow cruise in show atmosphere. The pinch welds are just over an inch off the ground under the cab rocker's.
The Snortin' Bull |
02-07-2016, 12:03 AM | #189 |
a bit of an engine starting tool kit ready to go.
The Snortin' Bull |
02-21-2016, 01:48 AM | #190 |
So like a lot of the forum member's have said life get's in the way 2 week's go by with gas in the tank and key's in the cylinder. Today I started the GMC up .Broke in the cam and etc.Drove down the drive way a couple time's .Got a couple of video's though need a "golden" token from admin to post?
still got work to do.
The Snortin' Bull |
02-21-2016, 09:19 AM | #191 |
truck is looking good.
02-21-2016, 11:02 AM | #192 |
Truck looks great.
02-21-2016, 10:32 PM | #193 |
Thank's,Gettin there.It was a rush to go down the driveway and back.
The Snortin' Bull |
02-21-2016, 10:35 PM | #194 |
GMC, The Bull is out in the weather now.Put in the final door surround weatherstrip on the cab.Sill plate's also.
The Snortin' Bull |
02-21-2016, 10:38 PM | #195 |
I am on the fence to put on a rear bumper or not. Even though the exhaust tip's are hardly showing I still tipped off with a chrome pencil tip. Yosemite Sam street sweeper's I call them.
The Snortin' Bull |
02-21-2016, 11:20 PM | #196 |
Wow, looking really good.
My vote is for a bumper, always. |
02-21-2016, 11:44 PM | #197 |
Looks great. I enjoyed reading your build. I like your style, dig those hubcaps!
02-22-2016, 07:05 PM | #198 |
A link to Video of truck on the driveway . https://vimeo.com/156134915
The Snortin' Bull |
02-22-2016, 07:08 PM | #199 |
The Snortin' Bull |
02-22-2016, 07:09 PM | #200 |
I like the rig's you have posted on the forum also.
The Snortin' Bull |
