02-15-2016, 08:53 PM | #376 | |
Re: GIANT 60-66 parts Stash Barn Find!!
On doors, I only have two solid 64-66 doors I think, and if I remember right, they are both Drivers side ones - no pass sides currently. When you ask for a rear wheel housing, I assume you mean Fleetside bed wheel tubs maybe? I only sell them in pairs if that is what you mean, and not sure but think I have at least one set. Already sold the only 64-66 roof panel I had to offer - sorry
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
02-15-2016, 08:57 PM | #377 |
I do have a 60 GMC hood - they are nearly nonexistent to find anymore and bring big money when they are real nice. Mine has been painted at some point, and wiped with a thin layer of putty or filler because it was black - very hard to block Black to perfect without doing this first. Not bondoed to replace rust though so pretty nice hood from what I recall - probably looking at around 400 or so on it - hard to buy any 60-61 GMC or Chevy hoods for less than that....
02-15-2016, 08:59 PM | #378 |
Not sure I have one or not - believe so, but need to find then test it first. Do you have all the wiring and switch already or just need the actual motor?
02-15-2016, 09:01 PM | #379 |
When you say "assemblies" do you literally mean just the actual metal squirter heads themselves that screw to the cowl and attach to the fluid hoses? I probably do have these somewhere but to be honest, you might be best to buy aftermarket ones because they will be cleaner and work better. I can look for you though
02-15-2016, 09:07 PM | #380 |
I don't know if you are still looking or not, but I do incidentally have a super nice original low mileage chrome 1963-66 stepside rear bumper and brackets. Let me know if you are still looking
02-15-2016, 09:08 PM | #381 |
I am sorry - don't have what you need, but know a guy in California who dismantles trucks who might. PM for his contact info
02-15-2016, 09:11 PM | #382 |
Cypher, I have a nice nice set on a short fleet bed I could remove and send you if I can find what I did with the other set I have - or sell you that set for that matter - one set was typically faded out and one set was more chrome-like and shinier so I was going to swap the less shiny set out for the shinier set and sell the more dull looking set. Let me know if you are still looking and if so I'll go dig up that other set and compare to mine to see if I want to mess with swapping or just leave the set I have as it is.....
02-17-2016, 09:02 PM | #383 |
Got any doors for a 65? Both driver and passenger? How much shipped to 15658?
02-19-2016, 12:35 AM | #384 |
Passenger side front fender?
Thanks, Scott |
02-19-2016, 06:01 AM | #385 |
Only have two driver doors for 64-66 right now - no pass sides. One is dented some under the lock area but solid, and can't remember if anything is wrong with the other - PM email or send textable cell # for pics
02-19-2016, 06:01 AM | #386 |
I'm checking with another guy for you Scott
02-19-2016, 09:17 AM | #387 |
02-19-2016, 10:22 PM | #388 |
Do you have a 64-66 automatic steering column?
02-22-2016, 02:06 AM | #389 |
Need
glove box insert, grommet 1 window crank Flywheel cover Choke knob Z bar? And clutch rod? Fan shroud not really anything detrimental I can think of Soon clutch stuff for a v8 |
02-22-2016, 03:41 PM | #390 |
Hey there Franklin - yes, I do have a couple of those - neither is complete w/ shift levers, indicator housing etc though - I have a 63-66 GMC and a 64-66 Chevy - either one is 175.00 and can be shipped with or without the center solid steel shaft (best if you re-use the center shaft you already have to save on weight and length)
So these are the black column itself with all three upper column pieces attached - you would buy a new TS switch, NS Switch, and your indicator lens, housing and turn signal / shifter arms and lower column bearing and just have the body shop paint the upper column pieces to match your truck. Now, I probably have some used parts to assemble the column without buying the above aftermarket items new, but these are all best to buy new if you want it to look like anything. Old turn signal and shifter arms are cruddy and rusty looking usually, and lower column bearings are always shot, so definitely want to replace that with a new one. NS switches are notorious for being broken and worn out inside, and you already know what happens when you install a used TS switch - so that's all I'm saying....send zip code and city for a shipping quote if interested
02-22-2016, 03:48 PM | #391 |
Shark, I don't think you want a used glovebox insert even if I had one - talk about something that would be ragged if you did find one - whew! I highly recommend you buying that new, and whatever grommet you are talking about too. Same for the window crank and choke knob for that matter - this is all super cheap stuff to get from LMC, The Truck Shop, Classic Parts, Jim Carter, etc....I have a clutch rod and probably the Z bar out of a 63 that a guy just took the manual 3 speed trans out of. 6 cyl trucks often has a metal 3 piece fan shroud, and V8's usually had a fiberglass one - the fiberglass one is reproduced so if you want a nice one, that is the way to go there. Most of the "survivor" fiberglass shrouds are not worth having because they are normally busted or at least cracked
02-22-2016, 07:19 PM | #392 | |
02-24-2016, 10:12 AM | #393 |
Any good 292 engines?
69 C20 - work in progress 91 Z28 - the weekend toy 05 Burb 2500 - DD and big block power |
02-24-2016, 10:59 AM | #394 |
There's 2 292s on craigs here in NOLA
Fiberglass repo fan shroud, got it. Want window crank to match ish Finding inserts are Really cheap Still waiting to here back from some people on the correct glove grommet Choke knob cuz I want matching temporarily till I can change them all Flywheel cover? 1-2piece? If 2 piece I think I might still have a piece on there.. If I put v8 in do I need a different one? |
02-26-2016, 01:12 AM | #395 |
How about a decent set of front inner fenders with steering column brace? 55082
02-26-2016, 10:12 AM | #396 |
no, dont have any 292's presently - if I hear anyone up here has one I'll be sure to let you know though. They are uncommon for some reason
02-26-2016, 10:15 AM | #397 |
I think I am out of inners right now but will do a re-check - there was a set in the bldg but seems like someone came and recently bought those if I am remembering right....will check
02-26-2016, 10:30 AM | #398 |
Moderator
Do you have an ashtray that's not rusted through? Mine has a hole in it. The dash side (or cover/handle) of mine is great. Or if you just want to sell the assembly.
02-26-2016, 11:02 AM | #399 |
ok! Let me know! Thank You!
02-26-2016, 12:45 PM | #400 |
65 Chevy shortbed.
Need tailgate and trunions. Need trim on sides of truck for whole truck. Need badges C10 that go on sides of cowl. Got any of that? Thanks.
70chevytruck |
