Old 02-26-2016, 11:03 AM   #601
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Lost My 65
So I took out the rubber mount between the transmission and cross member to see if dropping the back of the transmission would lessen the vibration, and it did.
So I'm going to try a combination of dropping the pinion angle down with a wedge, and lowering the back of the transmission until they're parallel.
Thanks for your help.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-27-2016, 01:52 AM   #602
Captainfab
60-66 Nut
Re: Lost My 65
So it appears that the trans crossmember should have more of a drop in it? That crossmember has the same amount of drop as a factory crossmember that I measured. Although the engine mounts have an effect on the engine and trans angle as well. The truck I measured had the '60-'62 factory V8/auto trans engine mounts. They may be a little higher than your engine mounts. Don't know for sure.
Old 03-01-2016, 10:39 AM   #603
LostMy65
LostMy65's Avatar
Re: Lost My 65
Tilted the axle forward to get the pinion angle closer to parallel to the transmission - trying to get the slight vibration out. Not getting there.
Old 03-01-2016, 10:22 PM   #604
lowbuck
Re: Lost My 65
Lost my 65 Good video on drive shaft, pinion tail shaft angles.
https://youtu.be/gmV4qwLfOMY
lowbuck is offline   Reply With Quote
Old 03-01-2016, 10:48 PM   #605
sodly
sodly's Avatar
Re: Lost My 65
Sorry to interrupt here but wouldn't this thread be more appropriately located in the Projects and Builds section? I didn't take the time to read all 16 pages but it sure seems like a build thread from what I'm seeing. Nothing wrong with that but it doesn't really belong in this section. Moderator? Thanks.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 03-01-2016, 10:57 PM   #606
LostMy65
LostMy65's Avatar
Re: Lost My 65
It's far from a build thread.
But I'm fine with whatever staff thinks is best.
Thanks for the video, lowbuck.
It helps seeing a visual of what's happening.
I probably should get an Angle Finder and get the angles correct.
Old 03-01-2016, 11:25 PM   #607
sodly
sodly's Avatar
Re: Lost My 65
[QUOTE=LostMy65;7505769]It's far from a build thread.
Sorry. Please don't take offense at my comments. I'm just trying to figure out what is the subject of this 16 page thread? It appears that it focuses on one specific truck and its evolution over the last 5+ years. I guess if that's not build thread material, I don't know what is. Call me OCD or whatever but I prefer to have things in their proper place so as not to clutter up the general board with 16 page threads all about a single truck.
Neat story, btw!
WANTED:
Old 03-02-2016, 08:45 AM   #608
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: Lost My 65
I don't care exactly "where" this thread is on the message board and I don't think anyone else should either if they aren't a moderator. I think someone's picking nits here...
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 03-02-2016, 11:47 AM   #609
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Lost My 65
Just to clear things up, there is no hard set rule that build threads have to be in the Projects area. The Projects area tends to be where most would look for a build thread so most folks want them there. Others start a thread in the general area, not really seeing it as a build thread (like this one) that over time becomes one. We won't generally move them unless requested by the original poster.
As for now, unless LostMy65 requests to have it moved, it will stay as is.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-02-2016, 12:24 PM   #610
LostMy65
LostMy65's Avatar
Re: Lost My 65
Thank you.
Old 03-02-2016, 10:56 PM   #611
sodly
sodly's Avatar
Re: Lost My 65
No sweat. Sorry for the intrusion.
WANTED:
Old 03-09-2016, 11:55 AM   #612
chevy_mike
chevy_mike's Avatar
Re: Lost My 65
Moved to Projects and Builds per OP.
Old 03-09-2016, 12:06 PM   #613
LostMy65
LostMy65's Avatar
Re: Lost My 65
I guess I had better get started 'building'. ;-)
Thanks Mike.
Old 03-09-2016, 12:42 PM   #614
LostMy65
LostMy65's Avatar
Re: Lost My 65
Either the heavy piece of diamond plate steel in the bed, or a combination of that and old weak springs, the truck can't hardly handle a load. A guy I met yesterday gave me these heavy springs. I figured I give them a try.
Old 03-09-2016, 02:45 PM   #615
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
Those look like 1 ton units...
You might consider swapping the springs out for a HD set of air springs.. AKA "bags"...
I had a set on my 3/4 ton. I ran separate lines to Shrader valves on my license plate and they worked fantastic.
Projects..
440CID 2X4 Pontiac
Old 03-09-2016, 09:28 PM   #616
LostMy65
LostMy65's Avatar
Re: Lost My 65
Yeah, bags with Schrader valves is definitely on my list for the future.
These were free, so I figured I might as well install them.
The truck has air shocks, and the only way I could keep the tires from rubbing on the fenders was to keep the shocks aired up. Which gave me a stiff ride.
These bigger Springs have my butt up higher than I want, but the wheels I have are only 25" tall.
If I was to go to 28" tires, the wheels would be an 1-1/2 closer to the fenders.
These will tide me over.
Old 03-09-2016, 09:46 PM   #617
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
I used 30 spline 10 bolt axles from a nova diff..
Installed those into a, narrowed for the axels,
86 C10 8.5 inch 10 bolt. Redrilled for 5 on 5 and
used truck drums..
this setup put the same wheels you have square in the center of the wheel well. .. :-)
Projects..
440CID 2X4 Pontiac
Old 03-09-2016, 10:00 PM   #618
LostMy65
LostMy65's Avatar
Re: Lost My 65
When I went to swap in the 3.73 rear, I popped a drum off to check the brake shoes. The springs looked clean, and the shoes were good, so I went with that, also because I couldn't get the other drum off. :-(
Well yesterday, when I pulled the wheels off to install the bigger coil springs, I figured I'd pop off the other drum.
Backed the star all the way off and still couldn't it off.
Three flat bars wedged in between the drum and the backing plate, and it finally popped off.
Good thing. I've never seen shoes so bad.
Old 03-10-2016, 12:06 PM   #619
likaroc13
Rollin' Old Skool
Re: Lost My 65
Glad you pulled that drum I bet!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-10-2016, 12:55 PM   #620
Bomp
Bomp's Avatar
Re: Lost My 65
Thats interesting.
Wonder what caused the shoes to split like that.
defective brand? heat? age?
Thanks for showing.
Bomp is offline   Reply With Quote
Old 03-10-2016, 05:29 PM   #621
LostMy65
LostMy65's Avatar
Re: Lost My 65
Here's a shot outside with the heavier Springs.
Too high in the back. I'm fine with it for now.
Old 03-10-2016, 07:03 PM   #622
Re: Lost My 65
It looks good. Just throw some cargo in there and it will take care of that rake.
BTW, I do like the rake.
Old 03-10-2016, 08:00 PM   #623
LostMy65
LostMy65's Avatar
Re: Lost My 65
Still haven't resolved the vibration issue.
Below is a pic of the way it was at first. #1
And then the way it is now with three heavy washers under the back of the axle perches. #3
In all positions, I haven't really noticed a significant change in the type, intensity, or duration of the vibration.
And it still occurs right around 37mph or 1900 rpm.
My thinking is it has to be the driveline itself.
If it was the pinion angle, I'd expect the vibration to change in some manner. But in all three positions in the pic below, the vibration remains the same.
Old 03-11-2016, 01:23 AM   #624
Captainfab
60-66 Nut
Re: Lost My 65
Yeah #3 is how it should be. Have you checked your tires for separating plies? I have had tires start to separate, causing a vibration at certain speeds.
Old 03-11-2016, 09:29 PM   #625
Blessed66
Blessed66's Avatar
Re: Lost My 65
I approve of this suggestion.
Current Projects:
1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion
1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently.
Blessed66 is offline   Reply With Quote
