03-02-2016, 03:15 AM | #1 |
Diesel tanks used for gas
I there wondering if someone can help me on this.
My truck was converted to LPG and the complete twin tank gasoline system removed.(brackets , filler hose the lot) I have found a truck with a twin tank set up but its diesel. Can I use it for gasoline (filler hose,sender complete to selection valve). If not can I use some of it? |
03-02-2016, 09:03 AM | #2 |
Re: Diesel tanks used for gas
They should work. They may or may not have a fuel return line. It's not always needed but if you wanted it, all you would need is new sending units.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
03-03-2016, 01:03 AM | #3 |
My '82 3/4 ton started life as a diesel and as I recall all I had to do was put the fuel nozzle restrictors in the filler necks to get by our smog laws ! Oh and I had to blank out the Diesel Fuel Only on the fuel gauge ! pretty simple swap as I recall !
03-03-2016, 02:12 AM | #4 |
I would flush the tanks as well.
Anthony |
03-03-2016, 11:26 PM | #5 |
They work fine with gas in them on mine. Definitely flush them...
1990 K5 Blazer (sold) 1983 SWB C-10 to K-20 Conversion |
Tags |
gas tank |
