Old 03-05-2016, 06:46 PM   #1
bdwood
72 C/10 fuel tank relocation
I'm about to start a complete rebuild with a LS1 6.0. I am planning on using a tank from LMC. I would like to install an in tank fuel pump. Any suggestions on make and model?
bdwood is offline   Reply With Quote
Old 03-10-2016, 10:10 AM   #2
bdwood
Re: 72 C/10 fuel tank relocation
No advice. Must be a really dumb question!
Old 03-10-2016, 04:08 PM   #3
jmcleek
jmcleek's Avatar
i am a little slow what is LMC? Measure the space where you plan on putting the fuel tank max lingth x max with x mas dept .Also find the specks on the fuel presure that is needed to run the ls motor. it may be posible that something that came with that motor had a tank that will fit. do your research.
jmcleek is offline   Reply With Quote
Old 03-10-2016, 04:23 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
Being in the wrong section of the forum doesn't help either.
Try the LSX swap section in the 'Engine & Drivetrain' sub forum, or the main 67-72 Message Board, or research the FAQ section.
This might help with your 'really dumb question'.
http://67-72chevytrucks.com/vboard/s...d.php?t=457134
And this might be a better source for the tank if you're switching it from behind the seat - their quality is excellent and Dave is great to work with.
http://www.fueltankparts.com/67-72-e...-bed-fill.html
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-10-2016, 04:24 PM   #5
shores6
shores6's Avatar
I would look at Boyd welding's tanks. I've got one with an in tank fuel pump. Excellent quality. And they make them specifically for our trucks. You can get them here http://www.azproperformance.com/Boyd-Welding.html
shores6 is offline   Reply With Quote
Old 03-10-2016, 04:27 PM   #6
bdwood
Thanks BossHog69. Wrong section? That won't happen again cause I'm out of here!
Old 03-10-2016, 04:38 PM   #7
schmeed24
Check this out.
http://www.powerblocktv.com/episode/...p#.VuGQ0ZMrJBw
schmeed24 is offline   Reply With Quote
