![]() Join Date: Jun 2002
One more tool to my name !
Working on the lathe today and decided to make a camshaft installation tool. I always see them in Summit and Jegs and never really needed one before but figured a man can never have too many tools. So here it is ......
Chris Bowtie468 ![]()
![]() click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
Professional Grade
Looks awesome! well done man!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Wiseass secured himself a BAN
I usually use some extra long bolts laying around the shop to install cams.
Howzit?!?
Nice job! That looks heavier (thicker in the handle) than the one I bought off eBay... and that's a good thing!
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
man that looks nice. put me in line if you decide to make and sell those. do you know any Pontiff's? i have some friends who are brother chris and tim Pontiff from around you.
![]() ![]() Join Date: Jul 2002
Very nice!!!
Nice job.......how long did it take to make?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
how long?
Blue Beard, i did it between jobs during the day, but i'd say about an hour total. Now that i have a template for the faceplate, it shouldn't take that long!
Chris ![]()
registered IWATA user
holy crap 3 louisiana members in one post!
we have a lathe at the machine shop that i work at, i've only made a little dinky throttle cable connection extension piece for my carb. what do you call the piece/part/ccessory that makes the checkered grip on the handle? how do you do that?
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
Ob-Gyn Kenobi
its done with a knurling attachment on the lathe.. very easy to do...
'85 GMC Shortbox... I used to have a firm handle on life....then it broke off. |
Sean, the knurling tool is nothing more than 2 grooved wheels that turn against the workpiece. This is what gives you the diamond pattern.
Like Opper77 said, it really is an easy attachment to use.
Ob-Gyn Kenobi
sorry to butt in Bowtie....I know this is your thread...forgive me...
Also, most good shops will have a couple different tools to give you different sizes and patterns. We have 2 different sizes of diamond krurl, and a couple sizes of straight krurl (looks like just a bunch of longitudinal grooves when done) The key to using one of these >X<, is set your carriage feed to one of the higher seetings (the larger the feed, the coarser the diamond pattern) and set your chuck speed fairly low (I remember 20sfpm for some reason; 90 - 100 sfpm is a usual turning speed for steel..) A good pattern will take a few passes but the key for beginners is not to disengage the feed lever (like cutting a metric thread on a imperial lathe) ...just keep the tool in contact and stop the lathe where you want to stop the krurl.. reverse the feed direction (if this is not an option, reverse the chuck rotation), crank the tool into the workpiece a little more, and run back the other way when you get good at it, you can just keep it running continuously and pick it up every pass, but you need to be careful or you can ruin a good krurl easily... here's a few things I have made...
![]() BTW.. Thats a sweet job you done yourself !! Thanks pal, Chris Bowtie468 ![]() ![]()
