03-24-2016, 11:05 AM | #1 |
Anybody do an ls swap AND AAW classic update kit together?
If somebody has I have a couple questions about a couple wires, thanks
03-24-2016, 01:12 PM | #2 |
Re: Anybody do an ls swap AND AAW classic update kit together?
I am not doing them together, but I am installing the AAW kit now and the LS later this year.
03-24-2016, 01:59 PM | #3 |
I just did a wire harness and an ls swap. it wasn't an aaw but it was a universal gm harness.
03-24-2016, 03:18 PM | #4 |
Up to my elbows in a ls swap like that right now,along with vintage air and Dakota digital dash,yeah I know crazy.Have wires everywhere.so don't know how much help I would be.
03-24-2016, 06:10 PM | #5 |
I have done it.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
03-24-2016, 10:04 PM | #6 |
Here's my dilemma , I have intellitronix gauges goon in too, so that throws in a wrench. Where will my vss signal from Ecu hook on aaw harness?? Or go straight to gauges? Also there's a long unlabeled orange wire by heater wires ... Where does this go? Doesn't go to heater , and I've yet to get ahold of intellitronix or aaw customer service after 2 days of attempts all day...frustrating
03-24-2016, 10:18 PM | #7 |
1960 SWB “Pops” If you won't support our troops then stand in front of them! |
03-24-2016, 11:36 PM | #8 |
Looking at the aaw wire diagram a single orange wire will go to the cigarette lighter maybe that's it.VVS is set up different on mine but I would think it would go to the cluster not the aaw harness.
03-25-2016, 12:02 AM | #9 | |
03-25-2016, 08:51 AM | #10 |
VSS signal wire goes directly to the speedo gauge it doesn't hook into the AAW harness.
The long orange wire is probably for the glove box light. There are other orange wires in the harness under the dash but I think they are labelled. The instructions are quite good and are downloadable from the AAW website if you don't have the sheet that shows this long orange wire. I used AAW tech support a couple times and always got a person to talk to right away and answered my questions promptly. Good Luck with your build.
03-31-2016, 11:30 AM | #11 |
Thanks guys, I have the papers and diagrams. Kennuck- so I don't use the included purple and yellow vss wires at all you say? I go from swap harness vss signal straight to gauge?
04-01-2016, 09:59 AM | #12 |
You don't use those 2 wires and can remove them from the harness. Use the vss wire from the EFI harness.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-01-2016, 10:57 AM | #13 |
What do I do about a ground for the vss then?? Good info guys, thanks again
04-01-2016, 01:06 PM | #14 |
I think you are talking about the gauge? Just use a chassis ground.
04-01-2016, 03:15 PM | #15 |
Ahh, ok thanks guys I will see how this goes tomorrow!!
