Old 02-23-2016, 10:35 PM   #226
Bomp
Bomp's Avatar
Re: 1940 Packard 120 Convertible Restoration
Looks like someone liked silicon bronze.
Break it down. Bet you could build better doors.
Bomp is offline   Reply With Quote
Old 02-24-2016, 09:25 AM   #227
plainred65
plainred65's Avatar
More great work John, always impressive.
plainred65 is offline   Reply With Quote
Old 02-24-2016, 11:36 AM   #228
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
After watching you use your awesome skills. Those doors don't scare me. I'm confident you'll do something amazing.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 02-24-2016, 04:15 PM   #229
theastronaut
theastronaut's Avatar
Originally Posted by MP&C View Post
That door looks like a good project for Rock Hill! Come back with new inner door and new door skin...
Your work is looking stellar John, gives the owner a good perspective looking at the inner door next to it..
Appreciate it Robert! I think that would be too large of a project to take, and I'll probably be too busy watching and learning from the other guys. I might make a baffled aluminum breather box for the VW motor, it'll need one to vent the block at 8,000 rpm. I've been meaning to build one for a few months but just haven't taken the time to do it.
Originally Posted by flashed View Post
From what I have seen you do with the rest of the car I think you could build a door blindfolded .
I think the guy that patched the doors was working blindfolded.
Originally Posted by duallyjams View Post
The rust in the middle of the door is the water line from being submerged under water.
Wouldn't be the first submerged car that we've worked on. Had to rewire and redo the ac and brakes on a '67 427 Caprice that had been flooded.
Originally Posted by 67ChevyRedneck View Post
Can 1940 Packard doors even be found???
There are a few places that sells used Packard parts that may have a door. A coupe door would work, I'm pretty sure that they converted coupe doors to use on convertibles. There are caps welded on at the two spots where the window frame was cut off, then they leaded over the caps to blend the caps into the door. That would be much easier to replicate than fabricating well over 1/2 of the current door.
Originally Posted by Russell Ashley View Post
Makes me wonder if another restoration shop did the door like that. One thing for sure, the restoration that is in progress on this car now could be used as a text book on how to do it correctly.
It wasn't done by complete amatuers, their bodywork was very straight.
And before lunch. Packard or not, I bet it wasn't done this well when it was built.
Lunch which day? It is nice for the owner to have a car that's been apart this far, especially when they plan on keeping it in the family for generations. Being able to use modern products like epoxy primer, weld thru primer, and epoxy seam sealers means that the metal is sealed up better than anything ever appied at the factory. Having good products makes spending all this time worth it, you don't have to worry about if it will last.
At this point "better" still isn't saying much!
Thanks!
It would be amazing to find a rust free door shell...
theastronaut is offline   Reply With Quote
Old 03-03-2016, 04:27 PM   #230
theastronaut
I'm back from the Redneck Roundup in Rock Hill. Made new friends and learned a lot from watching other guys work on their projects and the various presentations throughout the weekend. I appriciate MP&C prodding me to sign up for the allmetalshaping.com forum, I wouldn't have known about the meet had it not been for signing up for the forum.
One of the things I learned more about was the "flexible shape pattern". I've seen pictures of them posted on allmetalshaping but didn't know anything about them. One of the presentations on Friday included a brief discussion on them so I thought that the passenger side fenderwell lip would be a good place to try one out.
The concept is to use reinforced shipping tape to make a non-deforming yet flexible pattern that shows how much shape a panel has so you can accurately determine how much shrinking or streching the panel needs. It also helps determine if an area of a panel has bends only- no stretching/shrinking needed to arrive at that particular shape.
I used a layer of blue painters tape as the first layer, being careful not to overlap anywhere. Then I used a single layer of reinforced tape on the spots I thought would need to be stretched, and a double layer (at opposing angles) on the area that I though was only bent- the inner flange. Once it's pulled off the panel (the painters tape makes it easy to remove) you use baby powder to kill the adhesive so it can be handled without it sticking to everything.
I didn't get a picture of it before I had removed it and used baby powder on it so I taped it back in place for a quick pic.
It doesn't look like much pulled off until you weigh down the spots that will lay completely flat, in this case the inner edge. If it will easily lay down with no wrinkels or bucking you know that that area only needs bending to arrive at its final form.
The ruffles along the outer edge won't lay flat. You can see that there is "more" tape for that section than a straight/flat piece so the new metal needs to be stretched in that area.
I cut a blank out, using the flat section of the tape pattern to mark out the inner flange's curve. I probably would have made this in a straight section and used the brake to make the first bend, then stretched and shrunk each side to curve it. With the shape pattern, I already had the correct curve of the flange so I could go ahead and cut it to shape. Once the piece was cut out, I set up the bead roller with mis-matched dies to make a makeshift tipping die to get the curved bend started.
Initial bend and stretching.
I had some leftover 1/8" plate in the scrap pile that had the same radius as the fender opening. I smoothed the edge and bent it to the same shape as the opening so I could use it as a dolly to form the edge over. This supported the edge, and a piece of tubing hammered beside it made the flared edge.
It's roughed in, still needs some fine tuning to match the shape of the opening, and to match the proper gradual increase in flare from top to bottom.
Old 03-03-2016, 08:29 PM   #231
duallyjams
duallyjams's Avatar
won't be long you be holding one at your shop
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-03-2016, 11:48 PM   #232
MP&C
MP&C's Avatar
John, well worth the trip? I need to make it down to Will's myself one of these times......
Robert
MP&C is offline   Reply With Quote
Old 03-04-2016, 02:04 PM   #233
Low Elco
Good stuff, thanks for the lesson!
Low Elco is offline   Reply With Quote
Old 03-08-2016, 04:19 PM   #234
theastronaut
We're nowhere near well-equippted enough to have a metal meet like that!
Definitely, can't wait til the next one!
No problem!
Old 03-08-2016, 04:23 PM   #235
theastronaut
To finish up the quarter panel edge I made a set of templates off the driver side to match up the shape.
Before and after fine tuning the shape. The templates were spaced every two inches.
Fit to the quarter panel:
Shape matches the original panel:
Started repairing the inner fenderwell so I'll have a clean flange for the quarter to weld to.
Old 03-08-2016, 08:27 PM   #236
flashed
You make it look so easy and I would make a mess.
flashed is offline   Reply With Quote
Old 03-08-2016, 09:07 PM   #237
Advanced Design
Advanced Design's Avatar
Nice work on the complex shape. How did you shape it? Tipping wheel, stretcher, ?
Advanced Design is offline   Reply With Quote
Old 03-16-2016, 03:04 AM   #238
toolboxchev
Again nice work, I know that is time consuming a quickly becoming a lost art.
toolboxchev is offline   Reply With Quote
Old 03-20-2016, 01:29 AM   #239
swamp rat
swamp rat's Avatar
That was a tough one for sure!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-23-2016, 08:04 AM   #240
theastronaut
Sometime I make messes too, I just don't post them!
I set up the bead roller with mis-matched wheels to make a makeshift tipping die, not to tip the edge but to "thin" the spot that would be bent the tightest. I made one pass over the marked line to slightly weaken the line, this made it easier to fold the edge as tightly. I alternated between the shrinker to pull the inner flange into the proper shape, and the stretcher on the outer flange, doing a little at at time while the rest of the shape was by using simple t-post dollies and tubing to create the rounded edges. I tried to "sneak up" on the shape since it wouldn't be as easy to take away shape as it was to add shape.
Thanks!!
It was definitely one of the more involved pieces. I enjoyed the challenge of making it though!
Old 03-23-2016, 08:07 AM   #241
theastronaut
I have started on the rear half of the inner fenderwell. There is a dip in the upper part of the fenderwell lip and I want both the front and rear to be solid before I go about straightening that out.
I used the "dirty thumb" method of making a template for the shape of the lower edge.
New piece welded in.
Old 03-23-2016, 08:10 AM   #242
theastronaut
The rear inner body mount brace was in bad shape along the bottom so I made a new section to repair it. I had added a couple temporary braces to hold the back of the car in place as the brace had become weak and sagged with the weight of the body on it.
I mentioned flexible shape patterns earlier so I'll show how I made it and how to read it once it's made. Start by adding a layer of painters tape, its not as ridged as other tapes and the weaker adhesive makes it easy to remove.
Then add a layer of reinforced shipping tape. I also added a second layer with the strands turned 90* to the first layer so that the tape can't stretch later when it's removed.
Peel it off and sprinkle the adhesive side with baby powder to reduce the adhesive's grip. You can see that it retains the shape of the part.
Now the pattern can be laid flat on a countertop to see exactly what areas will need stretching or shrinking. One thing to note- areas that only need bending will lay flat as well, such as the side of the pattern with the raised bead pressed in. That side lays flat because that shape is only bent in one direction (the same way you'd fold a piece of paper). Only the areas needing shrinking or stretching (compound curves) will show up in the pattern. There are two spots sticking up right in the middle of the bend. This show how much and where the metal needs to be stretched to attain the correct shape on the new panel. Knowing exactly where and how much to stretch/shrink saves time and guesswork when you start to make the new piece.
Old 03-23-2016, 08:11 AM   #243
theastronaut
The finished brace, and I made a new section of the rear inner fender.
Old 03-23-2016, 08:21 AM   #244
MP&C
MP&C's Avatar
Nice work John!
Robert
Old 03-23-2016, 06:10 PM   #245
Bomp
Bomp's Avatar
Extremely nice work, totally jealous.
What is the time frame on a patch panel part?
Old 03-23-2016, 08:34 PM   #246
theastronaut
Nice work John!
Thanks!
Depends on the complexity of course. The front of the fender opening/quarter panel still isn't quite finished as I'm not happy with the way the lower edge fits the rocker near the door jamb. That was a complex shape that I wanted to go slow with to "sneak up" on the final shape. It would have been easy to over-shape it, which would have been difficult to reverse. Start to finish I probably have at least 6-8 hours in the front lip, not counting the quarter panel or welding the two together. I should have made the folded lip in two smaller sections to speed it up and only had one short weld seam to deal with.
One thing that stuck out from the metal shaping meet was that if you're a proficient welder then you can get by with making smaller and easier to make panels.
The tail end of the inner fender with the two short beads didn't take long since it's flat. Most of the time is in laying out the pattern correctly and fitting the finished panel to the car. Took maybe 30 minutes to cut a blank and add the two beads. Trimming it to fit the body, accurately laying out and adding both the square and round holes for the fender mounting clips, drilling for the plug welds, prepping the overlap areas with weld-thru primer, and getting the edge trimmed so there is minimum gap at the weld seam is where most of the time is spent. I welded it in this afternoon and started grinding the welds. Took around 4 hours to go from a blank to welded in place. I'll spend another ~15 minutes smoothing the welds before I move on to welding in the body mount, and zipping up the plug welds.
Adding the beads is the quick/easy part. Once I got a feel for how much to pre-stretch the parts started going pretty quickly with less distortion to work out after rolling the bead. Parts like the floor pans that were flat with a bead rolled pattern were quick to make. Fitting them took a lot of time, especially with the body mount depressions and offset for the rocker overlapping, and the shape/folds of the edge up front. I didn't have anything to go by for those areas so I had to mock it all up to make decisions on how to make those details.
The heavier gauge body brace patch that had more shape, it took roughly 3-4 hours from cutting it out, blasting it, making a pattern, cutting out a new blank, forming it, welding it together, then smoothing it up. The flexible shape pattern helped speed up the process by showing exactly where and how much to stretch the blank.
Old 03-23-2016, 08:56 PM   #247
flashed
You constantly amaze me as I have never seen anyone make panels like you do .The cars and trucks I have seen rebuilt were with readily available repop parts , not one off custom parts like you do and you are so willing to share and teach us ,great job.
Old 03-25-2016, 07:21 AM   #248
notsolo
notsolo's Avatar
Really Beautiful, Metal Artwork, Awesome Skills thanks for sharing.
notsolo is offline   Reply With Quote
Old 03-25-2016, 11:21 AM   #249
Bomp
Bomp's Avatar
Thank you for the detailed response.
What you get done in one hour takes me 1 day.
Theres a lot of discipline in finishing out parts all the way to the end. Let alone the knowledge.
Keep it up,
You're able to salvage the bug?
Any updates on Goldilocks?
Old 03-26-2016, 12:32 AM   #250
theastronaut
Appreciate the comments guys!
Greg, the VW will be back on the road eventually. I think the longblock is salvageable along with the carbs. The decklid is the only part that got hot enough to warp, and it's only a spot right in the center so I think I can straighten it out.
No progress on Goldilocks. I've thought about getting the frame rolling, putting the sheetmetal together, and making an inventory list so I could advertise it. I'd love to keep and finish it and I probably will, it's just not a priority at the moment. I want to build a shop of my own and that could be some cash to throw at it and less space taken up inside once the shop is up.
For those that aren't friends with me on Facebook or following on Instagram, my '64 VW had an engine fire this past Sunday afternoon. It was practically my first car- took my drivers test in it at 15 years old, drive it 100 miles round trip to Greenville Tech my last year there, been all over the place to shows in it, and was my daily driver up until a couple years ago. Still had 90% original paint, absolutely no rust, and was matching numbers. I had just finished building and installed a ~130 horsepower 1679cc engine and had only made it about 2-3 miles on the first test drive. The oil drain plug either hit or scraped something hard enough to loosen it and oil dumped straight on the header. It took almost two full sized fire extinguishers to get the fire under control until the fire department arrived. It's fixable but will take a lot of work to make it nice again.
